Old 06-15-2016, 09:12 AM
The Boss's Avatar
The Boss The Boss is offline
My internet now is $39.99 but will go up $20 when I drop TV. Already have Prime, already have Netflix - I'm not seeing a downside from the $169+ that I pay now for the gold package!
And go racin' in the street.
  #42
Old 06-15-2016, 10:24 AM
shawn e.'s Avatar
shawn e. shawn e. is offline
https://www.amazon.com/Channel-Maste...A8ZB5RQNFC6ZAH
What I have.
"Don't let fatigue make a coward of you."
  #43
Old 06-15-2016, 02:18 PM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
While I despise the cable bill and my family cell phone bill, I don't need this level of additional complexity in my life at this time.
You did ask for the downsides
From Amazon:
Question: How many TVs can I connect to a single antenna?
Answer: i have 3-tv hooked-up to the same antenna BUT i hafta use 1-preamp TOTAL for all rooms & 3-hdtv converter or control boxes ( 1- in each room ) to be able-to watch diffrent channels in each room .., " but ITS DO-ABLE if u take the time to do it right !
Question: wiring from cm 3020 to tvs
Answer: The antenna has the coax adapter on it. If you need to go to one TV only, just hook to the antenna and then to the back of the TV with coax cable. If you need to go to two or more TV's a splitter will be required, and possibly a booster or amplifier depending on how strong your signal is. The more you split, the more signal you loose. The booster would go in line on the coax before the splitter and need 120v supply as well. They also have them that would send power to the antenna and wire in pretty much the same way. RG-6 is the best coax to use, and with a $20 tool, you can make the lengths you need yourself pretty cheap. If you go this route, make sure to use the compression type F connectors and keep your lengths as short as possible. Also I must mention that ANY antenna you install needs to be grounded properly as it is going to be a large lightning rod on your roof. If the rod you use to mount the antenna doesn't go all the way to the ground, you MUST run a heavy copper wire from the pole to ground. Hope this answers your question.
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
  #44
Old 06-15-2016, 02:55 PM
David Jones's Avatar
Kinda my thoughts too Jim. I'd be starting from basically scratch with 7 TV's in finding something else that worked...or kinda worked. Not for the faint of heart or those electronically challenged. Charter has me.....I pay the bill and pick up a remote. Expensive (relatively) but simple. At about $120 a month I suspect most of us piss that much away during a month doing other things and don't think a thing about it.
  #45
Old 06-15-2016, 03:49 PM
rohrt rohrt is offline
If your going to run and antenna and you have several TVs the best way to do it IMO is to run a pre-amp right on the the best/biggest yagi antenna that will fit on the roof. Aim it for the best signal. Use an app like this to find where your antenna's are at.
http://www.antennapoint.com/
Use a compass app on you phone to aim it.
Then use a good quadsheild coax to a 8-way splitter.
Run coax to each TV. (assuming you can)
The 8 way splitter will really knock down a lot of db(-10.5 db). So you may need another amp. Easy way to do some checks is with different splitter and they try a 2-way(-3.5) splitter and then 4-way splitter(-7db). With many of the digital TV's now they have a signal strength meter on them.
  #46
Old 06-16-2016, 02:01 AM
cuz68's Avatar
cuz68 cuz68 is offline
Unhappy
I have charter also, cable, internet, land line phone = $140 per month, I live in a dead zone also. I get pised every time the bill comes, I have 4 boxes and wont to give up all but the net.
Cuz68
  #47
Old 06-16-2016, 02:41 AM
mechanickeith's Avatar
Dropped the tv service in 2011. Only have cable for the internet. & that's creeping up in cost. Looking for alternatives. Don't watch tv anymore. Get my news off of the computer.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #48
Old 06-16-2016, 10:24 PM
FirebirdHank's Avatar
I dropped cable at least two if not three years ago. Really don't miss it much. I have five TVs, all of them hooked up to antenna. What I did was get a cheap antenna for each TV. They cost under $30 for each one. No wiring problems, just hook it up and set it behind the TV and watch all 20 some free channels. I don't get all those "reality" channels but I guess that is my lose. Not sure what I've done with that extra $100/month but I'm sure it has gone to a good cause.
  #49
Old 06-16-2016, 11:35 PM
Bob Hall's Avatar
Bob Hall Bob Hall is offline
I've been thinking about this for awhile as we have Comcast Triple Gouge for $200/month. I don't care too much about the home phone. I do need the internet for work and I have the blast 150 service. The only thing we turn the TV on for is the History Channel's Vikings. Does anyone know if HULU keeps current during that show's season?
1947 Ford Coupe
1972 Pontiac Luxury LeMans (Sold to Nephew)
1984 Chevrolet Monte Carlo SS
2003 Chevrolet Monte Carlo SS Jeff Gordon Edition
2017 Dodge Challenger SXT Black Top Edition
  #50
Old 06-17-2016, 02:48 AM
dataway's Avatar
dataway dataway is offline
HULU is hit and miss, depends on the show. Sometimes they show up a few days after they air, other times it's a week, other times it's after the whole season is done. They seem to have a different contract with every show. We use them a ton instead of cable.
  #51
Old 06-19-2016, 08:29 PM
Bentwings Bentwings is offline
Well, I have not had TV for over 15 years.....don't even miss it. I hate watching an hour show that has 20 minutes of commercials for stuff I'll never even look at. Tired of watching John Wayne movies. I saw al of the in the theater.
It's just too much money down the drain. It's more enjoyable fixing my streetrod or even working on my diesel dually.
  #52
Old 06-19-2016, 09:57 PM
critter's Avatar
critter critter is offline
I did.
Set up a media server in my house and watch old movies I've collected. I had an antenna. I have Apple TVs and watch Netflix and Amazon Prime. The latter only because I want the free shipping but neither Netflix or Amazon is a world beater. I might dump one this fall and get Sling TV so I can watch the college football I want.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
  #53
Old 06-21-2016, 10:17 AM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
I got rid of cable about 2 years ago, no turning back.
I have a paper thin antenna in the attic that is amplified and get about 30-35 channels.
Once I have some extra cash I will get a larger one.
Having netflix, amazon prime is much cheaper and better than our old cable
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
