#41
May I suggest these repros from Replica Plastics?
Others have said that the nose is crap, but the corner pieces look to be better than nothing. ![]() http://www.replica-plastics.com/prod...ontiac/page/2/
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
#42
Thanks for the tip. Those do look a little rough. I wonder how they look finished?Can the original surrounds be saved or are they too brittle to last with new paint?
#43
DO NOT bother with any originals. They will eventually crumble. Since Motorealm refuses to make anymore of the corner pieces, I'm afraid these are the only alternative. Since they are so small, these should work with basic bodyworking skills. I will have to buy a pair of these for mine...
#44
![]() Quote:
#45
That's positive. I hope they fit better than their nose on my car. Even though it is well constructed, it needed several hours of sanding and shaping to get it to appear like OEM fitment.
#46
Thanks for the info Canamman. Guess we don't have much choice. My car has never had any accident damage so I hope the reproduction parts line up reasonably well. if you have any pics of when you did yours LMK and I can send you my email address.
#47
I used the Replica Plastics units on my 73 Grand Am sedan. Like most fiberglass parts they require fitment but are pretty good for the price.
#48
Photo does not work..
#49
Any chance of getting some pictures posted of your GA for us to see?
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme. |
#50
Off topic.
stobin, is your last name Tobin? I knew a Tobin in central Illinois. Bought a 72 Firebird off of him. Had plates that read - NIBOT (and some #) ![]()
#51
#52
Hi Larry,
From the picture I see you used the Replica Plastics LeMans assembly on your GA sedan. How much body work did you have to do to them? I saw the Grand Am nose assembly and turn signal housings on their site, but they did not look too well finished. Am I incorrect on this? I do like the fact their nose assembly is made in three pieces. The Motorealm part is a one piece nose assembly from what I have seen. However, the finish seems to be better on their parts. Can everyone that has used either chime in with their opinion of the parts they used.. With Motorealm being fiberglass, and I assume Replica Plastics being plastic. Which one will age better over time? I hope to be able to do this just once so these are important questions for me. ![]() Thanks for any info submitted here! |
#53
I believe the nose on Larry's car is from a 75 Grand Lemans and not a Replica nose.
I bought an InDesign nose, back before Motorealm took over. It's the same nose as the Motorealm. I'm very happy with it. I still haven't finished the complete installation. I just did enough so the car could be driven. The fit is very good, and it was pretty easy to put it on. Here's a pic: ![]()
Steve F. |
#54
Those are Grand Am turn signal housings on my sedan. It did not have a nose when I bought it so I put a Grand Le Mans front end on it. I actually made bumper fillers for the blank spaces-they are not in the picture yet. I bought the whole Replica Plastics front end. I liked that it was 3 pieces. It was actually white gel coat fiberglass. I bought it for my white 2 door but sold it with the car. It would take way more fitting than a Motor Realm front end but was less than half the cost. I have more time than money sometimes so I went that way.
#55
![]() Quote:
#56
Woo Hoo, got my replacement nose from Motorealm today. They will be making the 73 turn signal housing again shortly!!!! Got those ordered to too! Tell them Rick, "73 for me" told you if you need some.......
#57
Just an update. Things are progressing little by little. Almost done with the nose fitment and have been cleaning under the hood trying to preserve what I can an refinish what needs it. Turn signals went on the fritz so i have to chase down that issue. Flasher still work. Any recommendations?
#58
Bad bulbs, dirty sockets, or open circuits will not allow one side to flash, but the good side will work as normal.
#59
Hi Guy's,
Long time since my last post. The 73 Grand Am has not made much progress but I hope to start again soon. I was diagnosed with pancreatic cancer and spent over a month at the Mayo Cancer Clinic in Phoenix having a Whipple procedure to remove the cancer. It was caught early and I am now home recovering. According to the doctor's my prognosis is very good. It will be awhile before I can do heavy work, but I am ordering parts and detailing small parts too. With God's blessing I will be back to my original weight and strength by spring so I can continue wrenching on my Grand Am. Rick "73 for me" |
#60
Wow, bad break but glad to hear you are on the road to recovery!
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
