#41
![]() Quote:
Snow already? Wow , well I guess there's always next year....
My Half AN Injun..... |
#42
#43
I sent Charlie a File I created from your info so he is all set now. Thanks anyway.
Tom V.
#44
![]() Quote:
Thankfully mine looks OK for now but I already have 10 lbs. of stuff in a 5 lb. bucket, so fitting bigger, better stuff would be a real challenge. |
#45
I would imagine besides the extra heat from the restriction working against you, that you could just turn the boost up to compensate for the drop in pressure. Then it would be just a matter of how much efficient boost/psi your turbo is capable of? I no expert but that would be my guess on that deal..
#46
![]() Quote:
I don't see my cam in there, but if I were to pick one that is close to it , it would be this one : R284/388 CTA.
#47
![]() Quote:
#48
![]() Quote:
Heres some numbers for you Charlie. Your current cam goes from .020" to .050" cam lift quicker open/close rate on intake than exhaust rate (from .020-.050 is 33 deg spread on intake vs 36 degree spread on exhaust) odds are the opening rate is quicker than the closing rate with either lobe for valve control.(maybe) I'd rather see the faster opening rate on the exhaust side and slow the intake opening/closing rate. I would also decrease intake duration and further delay intake opening letting intake close about where it is now. Present cam is 284/278 at .020" 251/242 at .050 114 LSA 110 ICL Proposed cam is 278/278 at .020 242/245 at .050 115 LSA 113 ICL Seat timing IO IC EO EC------------------------------------------------ Present--- 32 72 77 21 114 LSA 110 ICL 53 degrees overlap-------------- Proposed-- 26 72 77 21 115.5 LSA 113ICL 47 Degrees overlap------------ .050 timing------------------------------------------------------------ Present---15.5 55.5 59 3 114LSA 110ICL 18.5 degrees overlap----------- Proposed-- 8.0 54 60.5 4.5 115.5LSA 113ICL 12.5 degrees overlap-------- Keep in mind this is assuming that INCREASING intake lash(only) lowers EGT. IF increasing lash on exhaust (only) lowers your EGT then I'd juggle the exhaust timing numbers and keep the intake timing points the same as proposed. |
