Old 03-21-2017, 01:22 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Originally Posted by pggto View Post
Hi BJ, Did you get the dealer shipping record with the car?
Paul,
Yes, I did; thanks for posting it. This is such a well-documented car.
BJ
Old 03-23-2017, 05:35 PM
OVERULD's Avatar
Jim, thanks for the date codes. I'd love to have those old plates if you don't mind parting with them. Would look cool to display with the car at a car show.
BJ
Old 03-23-2017, 05:45 PM
OVERULD's Avatar
Got the hood scoop wire mesh inserts painted today.
Also got a test panel for the second pass at matching the paint done. I think we have a good match!
The spot on the driver side front fender turns out to be rust! Looks like we'll be cutting that out and patching. That means blending color across the hood and top of the fender, then clearing. We have to patch the passenger front fender after removing the antenna, so we'll try to keep it the same on that side. We won't do any color on the sides of the car except down on the bottoms of the fenders, the rockers and the quarters.
What was the purpose of this plastic piece at the base corners of the windshield?
It is missing on the driver side but you can see the screw that held it. Are these available from anyone?
BJ
Old 03-23-2017, 06:52 PM
njsteve's Avatar
njsteve njsteve is offline
They were designed to deflect water from the edge of the windshield's bottom seam. The originals were a flimsy, easily broken, piece of black plastic. They do make a repro but it is even poorer quality than the original piece.
Old 03-23-2017, 09:18 PM
77 Canamman's Avatar
NOS Left 3062232:
http://www.ebay.com/itm/1974-1981-Fi...1Yv-Wu&vxp=mtr
right side used 3062231:
http://www.ebay.com/itm/1970-1981-FI...BYKyf~&vxp=mtr
Pair used:
http://www.ebay.com/itm/USED-WINDSHI...RYLQUd&vxp=mtr
used right:
http://www.ebay.com/itm/USED-WINDSHI...JYxE1b&vxp=mtr
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 03-23-2017, 10:55 PM
OVERULD's Avatar
Thanks Canamman! I just ordered the NOS Left one and the used right one (last one you posted). Appreciate the links!
BJ
Old 03-24-2017, 11:26 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Wish I had seen this thread earlier BJ. Love your new project; I owned a 73 Grand Am the same color combo in 74. I wish I had caught you before you did any sanding or cutting of the paint. There is a way to bring back the older single stage paints WITHOUT any abrasive materials, compounds, polishes, buffing, etc. We're using it on 36k mile original paint 79 Camaro right now.
I don't know where I would chance taking off the body side moldings. You could very well end up painting 80% of the entire car this way. Good luck and eagerly following.
Old 03-25-2017, 12:42 PM
OVERULD's Avatar
Thanks Jerry! Would love to hear your process for restoring the older single stage paints. We did that test spot on the top of the driver side fender because we knew we had to do a rust repair there. We test polished a couple places with 3M #1 and #2 compound, followed by some glazing with wax and got some good results. What process are you using on that 79 Camaro?
BJ
Old 03-25-2017, 11:13 PM
Jerry H.'s Avatar
BJ
I'll forward the link when I'm in my office. It's on my other computer.
Old 03-26-2017, 07:39 AM
Bentwheelbob's Avatar
A few more thoughts...
1) I do master cylinders in 50% gloss powder coat. Strip it down, send it out and then reassemble.
2) Norwood rebuilds and replated hood latches and they are beautiful.
3) AMK sells the little green clips that hold the cowl seal in place.
4) Be sure to send the filler panels when you send the inner fenders for powdercoating. Goodmark makes replacements that are very good.
Old 03-26-2017, 08:25 AM
Judge273's Avatar
Judge273 Judge273 is offline
BJ, getting dirty on a resto-survivor project is cool. Having fun I bet!
Mike/Illinois
Old 03-26-2017, 03:02 PM
OVERULD's Avatar
I'm having a blast Mike! Just struggling with how far I want to go right now. I'm busting at the seams to drive this car over the summer and do a few shows. I'm probably going to minimalize the project somewhat so I can enjoy the car for awhile. Like Bob and Steve have said, mission creep is very insidious!
BJ
Old 03-26-2017, 04:56 PM
Jerry H.'s Avatar
BJ
Here is a link to the 53 page article. Easy read, lots of those pages are pictures!
http://www.autogeekonline.net/forum/...ge-paints.html
Old 03-25-2017, 01:24 PM
OVERULD's Avatar
Some more progress pictures.
MPR got the hood removed and the inner fenders out, so now we have some more access to the engine compartment for detailing.
The inner fenders look good,
What was this - maybe some undercoating overspray?
Here are some photos of various places in the engine compartment. We have some oxidation and surface rust - looks like some salt exposure from the Utah and Wisconsin roads over its lifetime, but overall, the subframe and core support look to be in good condition. I plan to use a Steam Jenny pressure washer to clean the underside and engine compartment, then use sponge brushes to touch up paint as and where needed. We'll replace some hoses and vacuum tubes, and do some general cleaning while we have good access.
Found the wire that used to run the big Tach on the steering column seen in some of the older photos of the car.
What is this - a filter in the vacuum line? Why does it go to such a small diameter? Looks like it disappears into the firewall. Any idea what this goes to?
Got a much better photo of the Cowl Tag. Notice the light stamping of the paint codes. You can barely see what looks like two "66" stampings for upper and lower color. Pretty sure that 66 was the correct color stamp for Fire Coral Bronze according to the paint chart posted earlier. Was it common for the Norwood plant cars to have this faint stamping or is mine an exception?
We've got some parts showing up now! Vinyl Stripes from Phoenix Graphics, Breather Elbow from Bob (Thanks again Bob!), new battery tray, new Stainless Drip Rail Molding, New front Bird emblem, cold beer.
Some hardware and badging waiting clean-up
That pesky antenna is gone now! New windshield with built in antenna on the way!
BJ
Old 03-25-2017, 08:06 PM
Lightbulb
BJ
That is the vacuum source for the HVAC system. The check valve is still available:
http://www.ebay.com/itm/497853-GM-NO...BYTYBm&vxp=mtr
Old 03-25-2017, 10:13 PM
OVERULD's Avatar
Originally Posted by pontiacstogo View Post
Below the steering column is black cover panel that must be removed first - it is retained by two plastic locking screws accessed from directly below the panel. Once that's removed there are two long bolt headed screws holding the dash cover panel on - one on each side of the steering column. Then remove the small phillips head screws located in the top of the dash cover panel (above the gauges) - four of them I think. Lastly, remove the bezel around the cigarette lighter. At that point you should be able to remove the dash cover panel completely. From there you'll have easy access to all of the gauges.
Thanks for the reply - sounds similar to the process on my old GTO. How about the radio - is there a way to remove it without dropping the dash or removing the center console?
Originally Posted by Bentwheelbob View Post
Mission creep is setting in...you're just one or two rationalizations away from pulling the engine and stripping the car to the subframe. I think you should just go ahead and do it. Clean up the cowl and firewall, get the core support looking good, paint the subframe and suspension components....I did the Gold Car that way without pulling the front clip and it turned out great. If you ask MPR to use a sponge brush things might get ugly. BTW - your organization system looks great. Good idea.
On the underhood finishes, tell your powdercoating guy to do the inner fenders at 50% gloss, brackets and pulley's at 60% gloss, and air cleaner at 90 % gloss. You better get an AMK catalog so you can order a bunch of new tinnerman's and bolts.
Bob, you are correct about Mission Creep (and also productivity at my real job!) I really don't want to pull the engine right now. I'm trying to get the car ready for the Annual Peach Blossom BOPC show coming up in May. Some stuff will have to wait until this coming winter. I want to see how it looks after I hit with the steam cleaner. I can't take any credit for the organization ideas. Those are all MPR's who owns the shop. He is a solo paint and body shop and does all the body work for the local Police Department and a large regional pest control company - which keeps him busy. So this project is being worked in to his regular schedule. Thanks for the info on the paint finishes. He already has an AMK catalog - buys in bulk!
Thought that's what it was. Thanks for the clarification and links.
BJ
Old 03-26-2017, 09:10 AM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Not sure - my radio and 8 track work but I've never had them out (or ever really used them). The radio can be R&R'd without dropping the dash, but you may have to remove the console to get it out?
BTW - I sent my gauge set out to Pete Serio for a restore and re-calibrate and it was money well spent, if for no other reason that I now have accurate oil and temperature readings.
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
Old 03-26-2017, 09:22 AM
njsteve's Avatar
Ever read the children's book: "If You Give a Mouse a Cookie"?
That is the definition of mission creep. :-)
The original master finish was a flat black just for shipping rust prevention. The paint usually disappeared after a few months, and turned to surface rust. I don't know if you are going for the survivor/preservation route or the regular restoration route. You have to have the master cylinder completely disassembled to have the body powder coated. If it is leaking, I'd send it off to Whitepost for a sleeve/rebuild job.
I just had my inner fenders powder coated in semi glass black and they came out perfect - just like the original finish.
Old 03-25-2017, 01:35 PM
OVERULD's Avatar
I'll need some help with what color and finish on engine compartment paints for things like the inner fenders, master cylinder, core support, brackets, air breather, engine block, etc. Anyone have a good list?.
Also, we found the wiring connector for the transmission kick-down switch all nice and bundled up behind the dash. We've tested the switch and after several manual cycles, we were able to see it operating properly on a volt/ohm meter. We hooked up the wiring, and did a driving test (before we removed all the parts in the post above!) and did not feel it kicking down. So - what's next in the troubleshooting?
Finally - how do you remove the dash on this generation F-body? I've had the dash out of my old GTOs a few times, but never done so on a Firebird, so looking for some help there so I can get the radio out for testing/reconditioning, and so I can replace some bulbs in in the instruments and gauge cluster.
Thanks,
BJ
Old 03-25-2017, 03:13 PM
Peter
