#41
In bad weather, you were supposed to change the scoops and put the std air cleaner back on. Wonder how many owners did that? A RAII, 4sp, 4:33 gears in the snow
“If you ain't first, you're last” - REESE BOBBY |
#42
No, they didn't have flaps in '68. Of course, you could add them today if you wanted to use the '69 system...just add money and a lot of it...
I really think it would have to be some serious rain to cause a problem. I have taken mine to the car wash to spray some of my dirt road off of it after I get into the city, and while I don't spray water directly into the scoops, I've never had any water pooling in the pan. By the way, the pan I got from brians has drain holes in it so that helps but I really think it's hard for much water to enter there.....especially rain water.
Greg Reid Palmetto, Georgia |
#43
A few more of hood bend. I can’t see any real crease. I may be wrong but it appears to just be outside edge mainly of drivers side.
#45
Comparing sides it looks like drivers side where hinge mounts is bent up. You body experts should be able to assess that.
#46
Looks like a hard place to un-wrinkle.
#47
Yes it does. The inside or top of hood isn’t like that.
I’m just wondering if I should just by a repro hood considering they’re around $400. I think I’d be money ahead but guessing. Maybe get the hood tach option. |
#48
I don't know how the repop hood fits. Might do a search. Not a lot of really good fitting sheet metal out there but not sure at all on the hood.
#49
Me neither. If mine is fixable I’d prefer to keep it.
#50
They may be ok. I'm sure someone here knows.
One thing about that hood is that the basic design and fit is the same for 3 year models and they made a crap load of them. Not hard to find solid used ones if you are not adamant about using only a '68 hood...and even if you want a '68 you could probably find one. Most people can't tell the difference and all the differences are in the bracing and the underside of the scoop-insert attachments, totally hidden when it's closed.
#51
The reproduction hood from Ames is an exact match for the 68 hood....bracing and all. Excellent fit and quality. My original was kinked as well. I did not want to fix it and then risk it kinking again later.
#52
I think I screwed up
I was browsing eBay and thought I found an air cleaner. Bout it and now looking closer at it I’m not sure it’s right.
Seller said for 68 gto 400. I guess I could take the paint off the lid since chrome under and use it temporarily if it’ll fit. If I screwed up, what do you think this goes on? |
#53
Good to know on hood. I’m in California so not sure what shipping would run.
#54
Thoughts?
If can get by with it, then fine but I may have to resale if way off.
#55
I have lots of pics posted on the GTO forum with details showing how to trim the hood for the ram air pans so feel free to ask any questions if you decide to go down that route. |
#56
Can you find a part number on that air cleaner base? Look for something that starts with 979xxxx
#57
Of course I’m still in need of the correct one. There’s a single base restored on there but $375 and no lid. I’ll have to hold off for a bit better cost. |
#58
This I am positive this came off a 68 Firebird 400. If its the same as a GTO I would be willing to sell it. Could not find a part # on it.
#59
Phs shows this
Dual stage hd so is this still a single snorkel or open?
#60
Ok now I’m puzzled
This is an odd one. Did the air cleaner assembly differ from standard to allow the extra layer of foam around the paper filter?
From what I read 68 gto used same unit as 68/69 Firebird 400 ho. |
