Ok now that you kids are done with your OCD malarkey has anyone used the gold paint from Summit called Placer Gold? I need a picture please. I like the fact it al ready in the spray can ready to use, instead of having to set up a spray gun and mixing etc. Wheels are about to get prepped for paint as soon as I find one wheel I need as one of the ones I was gonna use has a chunk out of the edge. Here’s a couple pics you guys might like, Mike loves to fabricate stuff, and made a tool to spin and polish the wheels. I will post pics of done wheels when done. These pics are just of the wheel being fitted to this dohicky thingy lol.
"BIG DADDY" VIDEO http://www.youtube.com/watch?v=QnFIVLuwO9A ~MaryAnn~ AKA "Stickybuns" 1969 Firebird 400 Convertible 1978 Bandit T/A Tribute 1977 RED TA I'm the FiredUp PY bad girl
Machining after clear coat is asking for troubles also, it leaves a sharp edge of paint only at each spoke which will chip and peel more easily than it should. Each cut will need to be deburred upwards to taper the paint edge.
Plenty have used the Placer Gold paint. It's based on the same paint code as Firebird used but every company wanted their own name. Will it match your current restored, 40 year old original or repro rims, possibly not but as close as you'll get without custom mixing. |
1. The Aluminum where you paint CANNOT be perfectly smooth. 2. You do NOT want to use a " non catalyzed " paint ( one stage from a paint spray bomb) 2 stage paint with a catalyst bonds to activator to the color AND to the substrate being painted IF it has a good " tooth" surface. This information is for cars being driven. Obviously a show only car gets pampering. 3. Spray clear coating. You want to use a catalyzed 2 part clear for spot repair, med dry time. This is thinner than your finish clear or high solids clear on a restoration. Eastwood has a 2k spray can clear I have used and it works well, no mixing, just shaking up the can. 4. I have taped off the spokes with high heat tape and powder coated the color before with good results. 5. You Cannot powder coat clear over a spray bomb paint, even if it is high heat, or catalyzed, with good results. |
Score - found this. I hope it is exact or close to the gold used on the 77 SE's.
https://tamcopaint.com/products/gm-g...39747812294736 |
| The Following User Says Thank You to Hesster1977 For This Useful Post: | ||
