Closed Thread
Old 02-02-2020, 04:51 PM
GTOGEORGE's Avatar
Got my engine stripped an loaded in the back of my car, going to KRE to drop it off, maybe I’ll check out a certain Pontiac Hemi head!
GTO George
  #42
Old 02-06-2020, 02:58 PM
GTOGEORGE's Avatar
Block is done and pistons and parts are ordered..........talk about FAST and quality work!
looks like .010 0ver......4.32 bore.
GTO George
  #43
Old 02-14-2020, 06:48 PM
GTOGEORGE's Avatar
Going over my main bearings the front main (no.1) has a little wear on the top half, had some brass color showing. Called King Bearing sent them pics to get their opinion. They said it’s wearing a little probably because if the yank on the crank from the blower but not a biggie. So because I have it apart I will probably replace no.1 main bearing. They said it would have been good another year easily!
GTO George
  #44
Old 02-15-2020, 10:04 AM
Did you check out the Hemi head?
  #45
Old 02-15-2020, 11:26 AM
GTOGEORGE's Avatar
Yes they (hemi heads) were there but not a whole lot to see different, KRE did have the valve train set up there but they were still waiting on some parts. They did say it should be up and running by April-ish! I’m going back next weekend to pick up my block and parts. I’m also going to ship my carbs to AED to have them reworked.
GTO George
  #46
Old 02-25-2020, 01:53 PM
GTOGEORGE's Avatar
I picked up my block at KRE, while I was there they were honing a spare block/engine for Tommy Youmans (the Quickest and Fastest Pontiac door car).....just incase. Got my block home put it on my engine stand, then I ordered a set of King main bearings (STDX), I'm going to replace the top half only (for no.1 main), the bottom was good. I want to be able to drop my crank in.......a 4 car garage and never enough room! LOL! Small steps but its getting there. Also I'm getting my wife engine ready for her Trans Am......... went from a .030 over 400 (its for sale) to a .060 over 421........a 1/4" stroke should give that TA with a Blower a tad bit more GRUNT!
GTO George
  #47
Old 03-04-2020, 01:25 PM
GTOGEORGE's Avatar
So I pulled my carbs off yesterday to ship them out to APD and look what I found under the carbs, I have no idea where it came from......doesnt look like it came from the carbs but I'm glad I had the screen in!
Im shipping my carbs off today, then ill ship off my blower restraint (DJ Racing Safety Equip.)......money....money......money!
GTO George
  #48
Old 03-04-2020, 01:39 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Yikes, wise idea with screen.
Preparation, preparation......plan for worst, but take the best!
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
  #49
Old 03-04-2020, 03:34 PM
GTOGEORGE's Avatar
GTO George
  #50
Old 03-04-2020, 04:45 PM
firechicken's Avatar
firechicken firechicken is offline
Talk about dodging a bullet...good save by thinking ahead!
  #51
Old 03-11-2020, 11:01 AM
GTOGEORGE's Avatar
So I'm waiting on my NEW Ross pistons I'm thinking.......and I hate doing that BUT they are going to be a little larger .01, I'm wondering on the weight increase and if I have to have my crank rebalance......? Ill weigh them who i get them and compare to the old pistons.
GTO George
  #52
Old 03-11-2020, 02:49 PM
GTOGEORGE's Avatar
Along with waiting on my pistons I'm working on my 3 gal fuel cell. Now it takes me around 3.5 gal (min) of alky to drive to the staging lanes make a pass and drive it back, obviously my 3 gal fuel cell isn't enough (absolutely no room for a larger fuel cell). So a while back ago i bought a Cruz Pro F60 fuel gauge......it basically does everything. Now all i needed was an alky friendly fuel level sending unit that would fit on top of my 3 gal fuel cell (not easy). I finally found one at Radiumauto.com.....cool, all i need to do is reconfigure my fuel cell lines which i can't do because the holes are drilled and it is what it is! I was able to buy a 3 gal fuel cell blank (no holes) at JAZ, now all i need to do is drill the holes (fuel fill hole, regulator return line, vent line and the fill line coming from my rear fuel cell) where i need them and I'm all set. What will happen now is when my fuel level get to a certain level (set by me) it will refill from the fuel cell (5 gal) in the trunk automatically and I will also be able to tell the amount of fuel in my cell in case I want to fill it from the drivers compartment.
GTO George
  #53
Old 03-11-2020, 03:23 PM
GTOGEORGE's Avatar
So I'm adding some pics.
GTO George
ID:	534283   Click image for larger version
  #54
Old 03-11-2020, 05:12 PM
GTOGEORGE's Avatar
I didn't like this pic of my old fuel cell so I took another one after I removed the cell.
Ya.....I know its dirty! LOL!
GTO George
  #55
Old 03-15-2020, 10:42 AM
GTOGEORGE's Avatar
While I’m working on my fuel cell I decided to check out different head studs since I’m going to buy a set anyways. I found some A1 Technology 1/2” studs for a good price and they are rated higher then the normal ARP 8740 studs (190,000 psi), they are rated the same (215,000+ psi) if not a tad better as the ARP2000 studs (220,000 psi).
GTO George
  #56
Old 03-15-2020, 11:09 AM
GTOGEORGE's Avatar
Too continue on with the stud thing I always thought that the ARP 8740 where sh_t studs and always wanted better. I didn’t like the idea of going to 9/16” studs and if I had my ways I’d have a better stud for a Pontiac race engine. I tried once but couldn’t get enough racers to get on board (the more studs made, the cheaper they are). If I was starting from the get go i’d have 14mm studs in my engine......all kinds of choices then......the junk jap engines have all the good stuff! LOL!
GTO George
  #57
Old 03-20-2020, 01:15 PM
GTOGEORGE's Avatar
OK.......im waiting on my new head studs to be dropped off today, I got my Ross pistons yesterday took them out of the box......they look great put them on my scale and they came out 3-4 grams heavier called Moldex they said don't worry I'm good no rebalancing needed......COOL! Now I can start reassembling my engine!!
  #58
Old 03-20-2020, 04:31 PM
GTOGEORGE's Avatar
Got my A1 technology heads studs in the mail today.....they are a little long but looks like they will work. They are like a ARP2000 stud in strength.
GTO George
  #59
Old 03-21-2020, 06:52 AM
mysticmissle's Avatar
george you already had the block honed to new pistons?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
  #60
Old 03-21-2020, 12:41 PM
GTOGEORGE's Avatar
No they honed the block first or before I got the pistons.
GTO George
The Following User Says Thank You to GTOGEORGE For This Useful Post:
Closed Thread
