Old 02-24-2020, 01:34 PM
berniearlta's Avatar
berniearlta berniearlta is offline
An update: Repaired all dash wiring, found that ignition switch was bad. Rebuilt carburetor, replaced fuel pump, and primed oil pump. I filled the carburetor bowl and it started immediately. I took it on it's first real drive in at least 15 years. Couldn't be happier!
Now I am trying to locate a correct factory radio. On the build sheet box 98 reads RADIO ----. The code for it is UN9 RADIO SUPR. G. Does anyone know which radio came factory? AM? AM/FM, OR THE RED DOT STEREO? HELP
  #42
Old 02-24-2020, 01:59 PM
unruhjonny's Avatar
if there is a blank in the radio box, I'd suspect it was a car with no radio;
I have spoken to a couple guys who ordered their cars around that time with no radio - apparently like them, most were pissed when they received their car intending to add their own aftermarket radio, and they noticed the car came with a windshield with no built in antenna!
I believe there was an option to have the car built for a radio, but without a radio option...
It might be worth sending away to PHS for a packet on your car, as that should spell out precisely which radio (if any) it came with.
I'm just a little confused, because you seemed to suggest before that it had no build sheet, but had PHS, while your last post seems to suggest you have a build sheet.
1970 Formula 400
  #43
Old 02-24-2020, 02:29 PM
This is what I have. It's a copy of what I was told was a build sheet. I believe it's just a copy of an old PHS documentation that the other owner had.
  #44
Old 02-24-2020, 02:31 PM
unruhjonny's Avatar
That's a build sheet.
If the details in the top right corner match your vin, then that's possibly better than what PHS can give you.
I have heard though that depending on where along the line that build sheet was used, it may be missing information that you're looking for.
I would guess, without knowing cars from that year as well as mine, that this was the option code for having all the provisions for a radio in place, even though it would have had no radio in place;
Cars without a radio had a plastic block off plate installed.
There is a reproduction available, but it's a 1978-1981 radio block off, so it's a bit bigger than the radio opening for a 1970-1977 Firebird.
EDIT:
BINGO!!
https://www.78ta.com/Pages/rpo.htm
(look near the bottom of the page)
UN9 Radio Accommodation Package
1970 Formula 400
  #45
Old 02-24-2020, 02:37 PM
Here is a better look. Also TGA TINT W/ANT.
  #46
Old 02-24-2020, 02:40 PM
unruhjonny's Avatar
yup.
The RPO 'UN9' would have included 'U76' which is essentially a windshield with an antenna lead... early on in the second gen run, GM more or less tuck it to cheap buyers if they didn't order a radio by putting in a plain windshield, and making the owner of hte new car either order a really expensive replacement windshield with the built in antenna, or cut their car to mount an aerial.
1970 Formula 400
  #47
Old 02-24-2020, 03:07 PM
U76 is there. Along with UN9, And TGA. I'm confused as to why RADIO was left with ----
  #48
Old 02-24-2020, 03:41 PM
I would say the original buyer was planning on adding his own (high power) radio/tape setup. So why pay for a radio?
Just needed the hookups, because he planned to take the original radio out when he got it.
Was a popular thing back then.
(Marantz, Kenwood,etc)
  #49
Old 02-24-2020, 04:27 PM
I would like to thank you all for sharing your experience with these cars. This past Saturday I took it on it's first drive outside of my neighborhood. I never got on it, just testing the waters. I will say that the bottom end torque of this car is amazing.
ID:	532923   Click image for larger version
  #50
Old 02-29-2020, 06:34 PM
78Macho 78Macho is offline
Wow, your car looks great! Congrats on your first ride and getting it running so quickly! Drive it like you stole it....
  #51
Old 02-29-2020, 06:48 PM
Thank you, waiting on nice weather for some more test drives. I plan on going through the cooling system. The original radiator is there and needs to be recored. I would like to have the water pump rebuilt, I can't find a kit though. Member frankyboy455 sold me a 1976 Delco am/fm radio this morning. I am also going to remove the factory Walker exhaust from my other 76 and install on this one along with factory manifolds. It's all in time.
  #52
Old 02-29-2020, 09:05 PM
starlightblack's Avatar
starlightblack starlightblack is offline
Another great T/A saved from dormant storage! Enjoy!!!!
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
  #53
Old 03-02-2020, 02:17 PM
napster's Avatar
napster napster is offline
Great find! Good luck with it.
  #54
Old 10-16-2020, 05:41 PM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
Getting a little off track, but in 1975 I went in to order a new 76 Trans Am at Thomas Pontiac in Daphne Alabama as soon as they started taking 76 orders. I wanted a Starlite Black TA and was told that black was not available. So I ordered a Firethorn Red with black interior 400 auto. Two months later Starlite Black paint was available and was I pissed. I have some AMA papers somewhere in the garage from that time period that states all of this. Early 76 colors that I remember were Cameo White, Sterling Silver, Goldenrod Yellow, Carousel Red and Firethorn Red. I don't remember a blue on a TA, but I do remember black was a late addition to the colors for 76 because I could not order it and they refused a special order. Some pics of the Firethorn I was forced to order with a rare silver bird, most were gold. Another of the black one I bought later.
Name:	76 TA.jpg3.jpg
ID:	551554   Click image for larger version
Name:	New 76 TA Sharon & Doug.jpg
ID:	551555   Click image for larger version
Name:	1976 Trans Am 5.jpg
  #55
Old 10-16-2020, 09:44 PM
muscle_collector's Avatar
great pics. still got the ta and the girl?
  #56
Old 10-16-2020, 10:06 PM
That TA is long gone. The girl is still with me, almost for fifty years now.
Have this TA now.
Name:	Hootout 2020.jpg3.jpg
  #57
Old 10-19-2020, 11:54 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Your memory is spot on! Black wasn't announced until late October 1975 and it didn't reach production until mid-to-late November 1975. And "gold' decals weren't available until black was introduced. My dad had an early Firethorn Red T/A much like yours and his was equipped with the silver/red/black decals.
You mentioned the documents above. If you ever found them, I'd love to see them.
