I may do the 1966 Manual Center Carb later but the basic info from Rochester and how they reported the information is there.
If I find significant differences between the Manual and Auto carbs I will post it. Tom V.
TURNS OUT THERE ARE SOME DIFFERENCES BETWEEN THE PREVIOUS CARB POSTED
and the one I am posting now. CENTER CARB 1966 421 engine Syn Trans The 1966 Pontiac Tri-Power Carburetors information, as requested. (For verification of the Carburetor Calibrations that you have on your 1966 Engines. I will post the Center Carb: 7026074 info now. Same format, again, from the Rochester Products People in the way the information is presented by them. Air Horn Number: 7031588 (1) Venting: Internal 7007199 Vent Tube External Venting: Idle Vent Support: None Needle Seat: 7026305 Size: .120 Float Valve: 7022779 Pull Clip: 7006474 Float Assembly: 7012028 Spring: None Fuel Level: .625" at 6.0 psi Mech. Setting: .594" Drop: 1.97" (to sharp edge of seam at toe of float) Pump Assem: 7032280 (synthetic) RET Spring: 7004597 Size: .025" DUR Spring: 7011385 Size: .045" Pump Rod: 7025575 Length 3.06" Pump Jet: drill (2) Size: .026" Jet Location: In Cluster CAP cc/10 strokes: 18.0 - 21.0 Rod Set: .952 from air cleaner flange surface to top of pump rod Power Piston Assy: 7012266 act spring 7012265 Oz 8 Color (green) Power Valve Assy: 7011989 Power Rest: 7010148 Size: (.048) Metering Rod: (blank) Spring: (blank) Rod Size, Power (blank) Econ: (blank) Cut-In down at: 11 "Up" at: 8 all in at 6" hg MM. Jets: 322 cc, 60 degree, 7008662 "C" 7013333 Idle Compensator Assy: (140 degree (+ - 10 F) Opening Temp Choke Housing: (2*) (Some of the next 14 lines available for the Choke Description are blank) Here are the ones with Info: Valve No: 7033443 Angle: 20 degrees Cam No: 7020541 Choke Link: 7019524 Length: 2.671" wo Kick: .143 - .183 Second Step: .090 .100 Vacuum Break: 25 degrees + - 1.5 degrees (.168 - .192) Float Bowl (Finish) Float Bowl and Body Number: 7031576 Venturi Size: 1-3/16" Cluster: 7032380 (4*) Boost Size: 1/8 Nozzle: 7012877 rel .049 - .061 Idle Tube: 7011031 "C" Size: .031 Channel Rest: 7011523 Size: .046 Hi-Speed Bleed: drill (2) Size: .028 L.I.A.B: None Idle Bleed: None Top Bleed: .039 over idle tube Side Bleed: .033 Insert: (2) 7008866 (trumpet) Radial Tubes: (blank) Size: (blank) Crossover Chan: .125 Main Well Chan: None Throttle Body Assem: 7031569 Body & Bowl Assem: (blank) Thr Body No: 7031597 Bore: 1-11/16 Thr Valve: 7008903 Angle 10 degrees Idle Needle: 7029605 angle: 20 degrees Idle Needle Orifice: .074 - .078 All drilling info is blank Port Punch Length: .187 Width: .030 Port Punch Loc: .177 Top Valve Top Slot Other: 7032290 throttle body gasket 7020778 thr shaft lever assy 7024885 throttle lever No Hole in thr valve thr shaft offset .017 - .023 no spark port info Test Specification 7022221 Min Air: .45/ lbs min Idle Air rate: .55 lbs min Box Balance 17" Hg - 3" Hg (Note all 2 BBL carbs are tested at 3" of mercury (TV) Remarks: 7013333 idle comp assy 140 degrees F + - 10 degrees F opening temp (1*) 7021007 air horn gasket 7031590 nut - fuel inlet bend pump lever tang to open idle vent with .020 gage between thr valve & bore on side opposite idle needle. (2*) 7026097 vacuum break control assy 7026098 remote choke coil assy (3*) Service Pump Setting 1-21/64 + - 1/64 from top of die cast air horn ring to top of pump rod (4*) .026 dia hole aspirator to main well bleed date 3-19-1966 (notice the date change TV) Customer 1966 2G Pontiac (SYN) 421 engine A/C -NON A/C Center Tom V.
Info on inlet needle valve pull clip on end carbs from 1963 says none used.
Info on inlet needle valve pull clip on end carbs from 1966 says clip #7006474 is used. Was there an issue with sticking inlet valves on end carbs before the use of the pull clip? What year did they add the clip? |
7026074 Carb, Kenth look at the top of the sheets, the first few lines of info.
Each specific carb number is listed there vs looking at the bottom of the page which is confusing in its statements at times. Tom V.
The specs in your post on the 7026074 correlates more to the 7026075 389/421 M/T center carb which uses #62 main jets an no holes in the throttle blades? |
Errors on this large amount of information CAN happen during the initial phase. Patience and we will have accurate information. Thanks Kenth for identifying the errors identified in my typing to date. Tom Vaught
7024078 Front Carb very similar to 7024178 Front Carb
FRONT CARB 1966 421 engine (A/T & Syn Trans) The 1966 Pontiac Tri-Power Carburetors information, as requested. (For verification of the Carburetor Calibrations that you have on your 1966 Engines. The Front Carb: 7024078 I will follow the same format as the Rochester Products People in the way the information is presented. Air Horn Number: 7013884 (1) Venting: Internal 3/16" dia in scoop External Venting: None Support: None Needle Seat: 7027846 Size: .086: Float Valve: 7022782 Pull Clip: None Float Assembly: 7012028 Spring: None Fuel Level: .750" at 6.0 psi Mech. Setting: .640" Drop: 1.97" (to sharp edge of seam at toe of float) Pump Assem: 7020584 (synthetic) RET Spring: 7004597 Size: .025" DUR Spring: 7011385 Size: .045" Pump Rod: 7013276 Length 2-3/4" Pump Jet: drill (2) Size: .030" Jet Location: In Cluster CAP cc/10 strokes: 15.0 - 18.0 Rod Set: .600 from air cleaner flange surface to top of pump rod Power Piston Assy: None act spring (blank) Oz Color (blank) Power Valve Assy: None Power Rest: None Size: (blank) Metering Rod: (blank) Spring: (blank) Rod Size, Power (blank) Econ: (blank) Cut-In down at: (blank) "Up" at: (blank) MM. Jets: 426 cc, 60 degree, 7008671 "C" Choke Housing: None (The next 14 lines available for the Choke Description are blank) Float Bowl (Finish) Float Bowl and Body Number: 7013258 Venturi Size: 1-5/16" Cluster: 7016687 (3*) Boost Size: 1/8 Nozzle: 7015151 rel zero Idle Tube: None Size: (blank) Channel Rest: None Size: (blank) Hi-Speed Bleed: drill (2) Size: .034 L.I.A.B: None Idle Bleed: None Top Bleed: None Side Bleed: None Insert: (2) 7008866 (trumpet) Radial Tubes: (blank) Size: (blank) Crossover Chan: None Main Well Chan: None Throttle Body Assem: 7027776 (2*) Body & Bowl Assem: (blank) Thr Body No: 7013262 Bore: 1-11/16 Thr Valve: 7027791 Angle 15 degrees Idle Needle Orifice: All drilling info is blank So here is the last part of the document (mostly just final Info) Other: 7013264 thr shaft & lever assy 7015106 throttle body gasket thr shaft offset .027 - .033 no spark port info Test Specification 7022221 Min Air .95/ lbs min max Box Balance 18" Hg - 3" Hg (Note all 2 BBL carbs are tested at 3" of mercury (TV) Remarks: (1*) 7013249 needle seat screen 7013250 pump shaft & lever assy cast baffle in air horn 7021007 air horn (2*) 7013783 throttle lever return spring "dag" treatment on throttle valves. throttle valves in vertical position at wot. (3*) 7024953 pump squirter deflector installed over cluster date 9-3-1963 Customer 1964 2G Pontiac 421 cu in A/T & Syn (Front) Pow. Pak for Pow Pak assys 7024172 & 7024174 Model 7024078 Similar to 7023078 Tom V.
Lots of differences with this 1965-66 GTO Carb
REAR CARB The 1966 Pontiac Tri-Power Carburetors information, as requested. (For verification of the Carburetor Calibrations that you have on your 1966 Engines. I will post the Rear Carb: 7025179 info now. Same format, again, from the Rochester Products People in the way the information is presented by them. Air Horn Number: 7013885 (1) Venting: Internal 3/16" dia hole in scoop External Venting: None Support: None Needle Seat: 7027846 Size: .086: Float Valve: 7022782 Pull Clip: 7006474 Float Assembly: 7012028 Spring: None Fuel Level: .730" at 6.0 psi Mech. Setting: .640" Drop: 1.97" (to sharp edge of seam at toe of float) Pump Assem: 7032280 (synthetic) RET Spring: 7004597 Size: .025" DUR Spring: 7011385 Size: .045" Pump Rod: 7028763 Length 2-3/4" Pump Jet: drill (2) Size: .030" Jet Location: In Cluster CAP cc/10 strokes: 16.5 - 19.5 Rod Set: .600 from air cleaner flange surface to top of pump rod Power Piston Assy: None act spring (blank) Oz Color (blank) Power Valve Assy: None Power Rest: None Size: (blank) Metering Rod: (blank) Spring: (blank) Rod Size, Power (blank) Econ: (blank) Cut-In down at: (blank) "Up" at: (blank) MM. Jets: 390 cc, 60 degree, 7008668 "C" Choke Housing: None (The next 14 lines available for the Choke Description are blank) Float Bowl (Finish) Float Bowl and Body Number: 7029684 Venturi Size: 1-5/16" Cluster: 7016687 Boost Size: 1/8 Nozzle: 7015151 rel zero Idle Tube: None Size: (blank) Channel Rest: None Size: (blank) Hi-Speed Bleed: drill (2) Size: .034 L.I.A.B: None Idle Bleed: None Top Bleed: None Side Bleed: None Insert: (2) 7008866 (trumpet) Radial Tubes: (blank) Size: (blank) Crossover Chan: None Main Well Chan: None Throttle Body Assem: 7029685 (2*) Body & Bowl Assem: (blank) Thr Body No: 7025611 Bore: 1-11/16 Thr Valve: 7027791 Angle 15 degrees Idle Needle Orifice: All drilling info is blank So here is the last part of the document (mostly just final Info) Other: 7029686 thr shaft & lever assy 7015345 throttle body gasket 7029688 Thr Lever thr shaft offset .027 - .033 no spark port info Test Specification 7022221 Min Air .95/ lbs min max Box Balance 18" Hg - 3" Hg (Note all 2 BBL carbs are tested at 3" of mercury (TV) Remarks: (1*) pump shaft & lever assy, cast baffle in air horn, 7021007 air horn Remarks: (2*) 7013249 needle seat screen (3*) 7029689 throttle lever return spring "dag" treatment on throttle valves. throttle valves in vertical position at wot. date 3-26-1966 Customer 1965-6 2G Pontiac GTO 389 cu in A/T & Syn (Front) Pow. Pak for Pow Pak assys 7024172 & 7024174 Model 7025179 Similar to 7024174 lots of changes on this one TV GTO listed for the first time in the sheets I am posting Tom V.
I'd like to see the 1965 Calibrations as well. Thank you
Bill Strobel Owner Independent Towing 1965 GTO Nightwatch Blue/Aqua 2005 GTO Quick Silver/Red Fayetteville, NC Do It Right or Don't Do It All |
We still have several of the 1966 sheets to post and then the 1965 info will be next.
More than a few 65 sheets also. I hope the Pontiac Guys are learning from this exercise. Tom V.
Is the needle/seat on the 1965 rear carbs the same as 1966 that you have posted ?
The Rear Carb uses the same calibration (same needle and seat, as well as other parts) on the 389 1965 engine and the 389 1966 engine. Carb number 3025179 (Manual Trans Engines).
Tom V.
Tom: Thanks for the quick response. Is the needle/seat available as a nos part, or from parts stores made by other manufacturers?
At one time, the Needle and Seat was available as part of the Rochester Tri-Power Kits
from NAPA. I have not followed those parts for many years. I do not rebuild carbs for people. Dick B, John Hargrove, and others do a fine job with that task. Being a Holley Guy, I have lots of rebuild parts for the popular Holley High Performance Carbs I own. Somewhere in the shop is ONE SET of NAPA carb kits for my 64 GTO if I ever put the original carbs back on the car. Not likely in the near future. So maybe too much info vs just saying talk to Dick B, Jon H, and the carb builder in Ohio. Not my deal. Rochester carbs even though I probably have 100 cores in bins I have collected over the years. I will have to go thru my lists and make a search for correct Air Horns, Main Bodies, and Throttle Bodies for the Tri-Power Systems and put them up for sale. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 03-10-2020 at 10:58 PM. |
Perhapes Dick Boneske and John H. might respond to my question !
They have a wealth of knowledge and between the two of them I would say you have a high probability of getting your questions answered.
This thread/topic is solely to post up info on the Tri-Power Carburetor Build Part Numbers and drill info for the carburetors. Maybe you could start your own topic/question addressed to both of them. Words above too long for the topic line. Tom V.
(For verification of the Carburetor Calibrations that you have on your 1966 Engines. I will post the Front Carb: 7025178 today. I will follow the same format at the Rochester Products People in the way the in the way the information is presented. More changes on this one than expected. Air Horn Number: 7013885 (1) Venting: Internal 3/16" dia in scoop External Venting: None Support: None Needle Seat: 7027846 Size: .086: Float Valve: 7022782 Pull Clip: 7006474 Float Assembly: 7012028 Spring: None Fuel Level: .730" at 6.0 psi Mech. Setting: .640" Drop: 1.97" (to sharp edge of seam at toe of float) Pump Assem: 7032280 (synthetic) RET Spring: 7004597 Size: .025" DUR Spring: 7011385 Size: .045" Pump Rod: 7028763 Length 2-3/4" Pump Jet: drill (2) Size: .030" Jet Location: In Cluster CAP cc/10 strokes: 16.5 - 19.5 Rod Set: .600 from air cleaner flange surface to top of pump rod Power Piston Assy: None act spring (blank) Oz Color (blank) Power Valve Assy: None Power Rest: None Size: (blank) Metering Rod: (blank) Spring: (blank) Rod Size, Power (blank) Econ: (blank) Cut-In down at: (blank) "Up" at: (blank) MM. Jets: 390 cc, 60 degree, 7008668 "C" Choke Housing: None (The next 14 lines available for the Choke Description are blank) Float Bowl (Finish) Float Bowl and Body Number: 7029684 Venturi Size: 1-5/16" Cluster: 7016687 Boost Size: 1/8 Nozzle: 7015151 rel zero Idle Tube: None Size: (blank) Channel Rest: None Size: (blank) Hi-Speed Bleed: drill (2) Size: .034 L.I.A.B: None Idle Bleed: None Top Bleed: None Side Bleed: None Insert: (2) 7008866 (trumpet) Radial Tubes: (blank) Size: (blank) Crossover Chan: None Main Well Chan: None Throttle Body Assem: 7031091 (2*) Body & Bowl Assem: (blank) Thr Body No: 7013262 Bore: 1-11/16 Thr Valve: 7027791 Angle 15 degrees Idle Needle: None Idle Needle Orifice: All drilling info is blank So here is the last part of the document (mostly just final Info) Other: 7013264 thr shaft & lever assy 7015345 throttle body gasket 7011897 Lever Front Carb Act 7029689 Spring-thr. Ret. Lever thr shaft offset .027 - .033 no spark port info Test Specification 7022221 Min Air .95/ lbs min max Box Balance 18" Hg - 3" Hg (Note all 2 BBL carbs are tested at 3" of mercury (TV) Remarks: (1*) 7013249 needle seat screen 7028757 pump shaft & lever assy cast baffle in air horn 7021007 air horn gasket (2*) 7013783 throttle lever return spring "dag" treatment on throttle valves. throttle valves in vertical position at wot. (3*) 7029689 throttle lever return spring "dag" treatment on Throttle Valves Throttle Valves in Vertical Position at WOT date 3-26-1966 Customer 1965 - 1966 2G Pontiac & GTO 389 cu in Syn (Front) Pow. Pak for Pow Pak assys 7024172 & 7024174 Model 7025178 Similar to 7024178 Tom V.
If you post up the carb tag numbers off your 1965 Carbs when I do the 65 Carbs I will
prioritize those carbs for posting the info on them when I finish the rest of the 1966 carbs. There are still new floats out there that people have purchased over the years. I also have a supply of used floats that might still function properly for you if you cannot find a new float. A bad float is not a good thing on a historical 1964 GTO. Tom V.
FRONT CARB
The 1966 Pontiac Tri-Power Carburetors information, as requested. (For verification of the Carburetor Calibrations that you have on your 1966 Engines. I will post the Front Carb: 7025078 today. I will follow the same format at the Rochester Products People in the way the in the way the information is presented. Air Horn Number: 7013885 (1) Venting: Internal 3/16" dia in scoop External Venting: None Support: None Needle Seat: 7027846 Size: .086: Float Valve: 7022782 Pull Clip: 7006474 Float Assembly: 7012028 Spring: None Fuel Level: .730" at 6.0 psi Mech. Setting: .640" Drop: 1.97" (to sharp edge of seam at toe of float) Pump Assem: 7032280 (synthetic) RET Spring: 7004597 Size: .025" DUR Spring: 7011385 Size: .045" Pump Rod: 7028763 Length 2-3/4" Pump Jet: drill (2) Size: .030" Jet Location: In Cluster CAP cc/10 strokes: 16.5 - 19.5 Rod Set: .600 from air cleaner flange surface to top of pump rod Power Piston Assy: None act spring (blank) Oz Color (blank) Power Valve Assy: None Power Rest: None Size: (blank) Metering Rod: (blank) Spring: (blank) Rod Size, Power (blank) Econ: (blank) Cut-In down at: (blank) "Up" at: (blank) MM. Jets: 446 cc, 60 degree, 7008673 "B" Choke Housing: None (The next 14 lines available for the Choke Description are blank) Float Bowl (Finish) Float Bowl and Body Number: 7029684 Venturi Size: 1-5/16" Cluster: 7016687 Boost Size: 1/8 Nozzle: 7015151 rel zero Idle Tube: None Size: (blank) Channel Rest: None Size: (blank) Hi-Speed Bleed: drill (2) Size: .034 L.I.A.B: None Idle Bleed: None Top Bleed: None Side Bleed: None Insert: (2) 7008866 (trumpet) Radial Tubes: (blank) Size: (blank) Crossover Chan: None Main Well Chan: None Throttle Body Assem: 7031091 (2*) Body & Bowl Assem: (blank) Thr Body No: 7013262 Bore: 1-11/16 Thr Valve: 7027791 Angle 15 degrees Idle Needle: None Idle Needle Orifice: All drilling info is blank So here is the last part of the document (mostly just final Info) Other: 7013264 thr shaft & lever assy 7015345 throttle body gasket 7011897 Lever Front Carb Act 7029689 Spring-thr. Ret. Lever thr shaft offset .027 - .033 no spark port info Test Specification 7022221 Min Air .95/ lbs min max Box Balance 18" Hg - 3" Hg (Note all 2 BBL carbs are tested at 3" of mercury (TV) Remarks: (1*) 7013249 needle seat screen 7028757 pump shaft & lever assy cast baffle in air horn 7021007 air horn gasket (2*) 7013783 throttle lever return spring "dag" treatment on throttle valves. throttle valves in vertical position at wot. (3*) 7029689 throttle lever return spring "dag" treatment on Throttle Valves Throttle Valves in Vertical Position at WOT date 3-26-1966 Customer 1965 - 1966 2G Pontiac & GTO 389 cu in Syn (Front) Pow. Pak for Pow Pak assys 7024172 & 7024174 Model 7025078 Similar to 7024178 (except for jetting ) Tom V.
