Old 06-24-2020, 07:23 PM
taff2's Avatar
taff2 taff2 is offline
'Sanding' rear main seals to get a good fit? In this day and age? Come on ,there must be a better product out there, if not someone should be making it. A seal should drop in and be fit and forget.
I seem to remember that a 2 piece Ford Viton lip seal set up was used back in the day? I've got one somewhere in a pile of Pontiac parts I bought a few years back. I also still have half a dozen of the old asbestos type rope seals, maybe I'll try one of those -the Graphite rope seal I last used ,leaked a tiny bit.
  #42
Old 06-24-2020, 07:47 PM
Formulajones's Avatar
I've used the BOP 2 piece seal numerous times and I've never had to do anything to make it fit correctly. Went in and fit perfect every time, and never a leak.
https://youtu.be/XqEydRRRwqE
  #43
Old 06-24-2020, 11:56 PM
Dragncar Dragncar is offline
Want to sell a couple of those asbestos seals ?
I think the one piece BOP seals only have issues on blocks that have been align bored. One you cut the cap it shrinks the seal part of it while the main bore is perfectly round. Hard to see a way around it. I have a one piece and a graphite on the way but would rather use the cancer causing stuff.
  #44
Old 06-25-2020, 07:27 AM
HWYSTR455's Avatar
Just to clarify, you don't sand the seal, you sand the crank.
  #45
Old 06-25-2020, 10:02 AM
bigkel's Avatar
bigkel bigkel is offline
both on 1960 389,s . 2 piece viton and one piece both plenty of miles and no leaks
  #46
Old 06-25-2020, 10:08 AM
Otherwise the crank will sand the seal for you
  #47
Old 06-25-2020, 10:46 PM
I'm confused....If that's the case, then why this?
Originally Posted by charlie66 View Post
The way Wade told me was look at each half of the seal like it was a clock. So with the block upside down the block side would be the bottom half and the cap would be the top half. The block side would be 3 4 5 6 7 8 9. So to sand it you will sand mostly at 6 - 5 and 7 O'clock.Then from there you will taper the rest of the sanding past 8 an 9 and 3 an 4 . This sounds more confusing then it is. Haha..
If i was you i would call Wade and he will walk you through it . He is a real nice guy ...
Old 06-25-2020, 11:15 PM
The way I read it, I think they are talking about sanding 2 different things.
One talking about sanding the grooves on the crank, which is how I interpreted that, hence my comment quoting it, and the other is talking about sanding the back side of the 1 piece seal so it fits properly.
  #49
Old 06-25-2020, 11:34 PM
Correct, talked to Wade myself about it. Nice guy for sure, but might just use the Best seal if I do not feel great about the BOP once I get done with the fitting.
Heck, might just sell the one piece, they are 50$.
  #50
Old 06-26-2020, 05:34 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Rear seal choice for the engines I've done here was on a case-by-case basis. For each build I armed myself with a BOP and Best rope seal. I quick "mock-up" with the lip seal to see where it's going to be riding on the serrations on the crank push my decision whether to use it one way or the other.
Some factory cranks have pretty deep serrations and are NOT going to fair well with a lip seal that rides right in the middle of them. Been there a couple of times and ended up pulling those engines back out of the vehicle and going with a rope seal.
For aftermarket cranks with a smooth sealing surface the lip seal is the only way to go. Some will need some minor custom fitting but will be 100 percent leak free if installed correctly.
To avoid the "hit and miss" deal with stock cranks or any crank with serrations cut in them a correctly installed Best graphite rope seal will do the same. Never had one drop of oil get by one to date. Rest assured here IF you don't mock things up and make sure the lip seal you are installing is riding on a smooth surface some oil is going to get past it.......FWIW......Cliff
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
  #51
Old 06-26-2020, 06:19 PM
taff2's Avatar
Dragncar, I've just checked and have 4 sets of the asbestos seals (I gave one to my nephew), I can spare you one pair - do you want 3/8" thick x 6 1/2" long , or 7/16" x 6 1/4" long? Pm me your address and I'll pop them in an envelope to you, no cost.
  #52
Old 06-26-2020, 10:44 PM
You have a PM Taff, thanks. I really appreciate it.
  #53
Old 06-27-2020, 09:32 AM
PDC PDC is offline
This made my day and I’m not even the one in need of the seal.
So refreshing after some of the bickering that has crept into the forum.
The Following User Says Thank You to PDC For This Useful Post:
  #54
Old 06-27-2020, 06:13 PM
taff2's Avatar
I've had a few Pontiac guys on here help me out ,so I'm always willing to help back if I can.
  #55
Old 08-09-2020, 04:49 PM
Tim Corcoran's Avatar
When installing the one piece BOP rear main seal I've heard that after the seal is on the crank before lowering it into the block some guys put a drop of super glue at the parting line and hold it in place until it sets, then continue on with the installation. Also I watched a you tube video of installing this seal and the during the video the guy said to put a small amount of silicone sealant in the the seal groove in the block before installing the seal. Anyone here used either of those techniques?
Tim Corcoran
  #56
Old 08-09-2020, 08:13 PM
AG's Avatar
AG AG is offline
No I haven't used those techniques. I've installed several and the parting line goes into the block side of the #5 main cap, not in the cap side which will be in the bottom when the motor is oriented correctly. No leaks with out any sealant or crazy glue.
  #57
Old 08-09-2020, 10:25 PM
lust4speed's Avatar
If the seal has been properly fitted there is a bunch of compression pushing the ends together, and as AG said, the joint is at the top. While the anti-rotation holes need to be filled so there isn't a path for oil to get around the seal, additional sealant in the bottom of the groove could make the seal sit unevenly and bow out the lip of the seal on the crank.
I had one engine brought to me that had a lot of oil flow past the 2-piece Viton seal. When it was pulled apart the previous installer must have filled the groove and then pushed the seal in place. Seal was bent out of shape with the inner lip totally distorted.
Mick Batson
  #58
Old 03-29-2023, 11:22 PM
65sport 65sport is offline
Well this never dawned on me either, so glad I could read it and not live it. Thanks !
