Old 03-13-2022, 02:23 PM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by racegto65 View Post
The port by the distributor is directly from the pump.
Im 98% sure the port by dist is after the filter, not directly from pump.
  #42
Old 03-13-2022, 02:31 PM
Elarson's Avatar
Elarson Elarson is offline
Pump flow goes directly out the bottom port at oil filter. Then comes back in engine at top port, goes across the top of #5 main to the vertical passage by distributor. From there it goes down and forward to the left side lifter galley, feeding all the mains. Feed from #1 main comes back up to right side lifter galley.
Eric
The Following User Says Thank You to Elarson For This Useful Post:
  #43
Old 03-14-2022, 05:38 AM
spectramitch's Avatar
spectramitch spectramitch is offline
Let me start by saying I did not build this motor. I have owned the car for 3 years and the previous owner (not builder) had no business owning a car like this. It was very neglected. This is the first time I have had it apart so I have the same questions as all of you. The bypass on the filter housing was plugged.
  #44
Old 03-14-2022, 09:04 AM
sdbob sdbob is offline
Drain oil, ck for shiny particles.
  #45
Old 03-19-2022, 02:19 PM
Has anyone ever seen mains on a crank with 'chamfers' this big?
  #46
Old 03-19-2022, 03:57 PM
tom s tom s is offline
I never put restrictors at the lifters for a street car.Tom
  #47
Old 03-19-2022, 05:08 PM
Steve C. Steve C. is offline
Note my comments in post #8 & #11 here:
https://forums.maxperformanceinc.com...=oil+pump+dyno
Old information here:
