#41
We've also ran into this on a couple of BBC that we ran on the dyno, picked up intake flow considerably and found zero change across the board. |
#42
I'm quite certain that's a titanium valve in the picture I posted. Last edited by PAUL K; 01-05-2021 at 04:02 PM. |
#43
Tom what is your opinion on a tuliped valve? I'm seeing quite a few four valve heads that the OEM is stuffing tuliped valves in. |
#44
Flow is constant on a flow bench, Flow in a real engine it is pulsing ( stopping starting ) with each valve hit
You have pockets of air / fuel pushing and pulling each other ( pressure differentials ) making their way through the intake tract ( simplified ) Seemingly useless open areas may be a good place to bunch up ( storage of higher pressure) waiting for a place to go on the next hit And where the pulse is of lower pressure you would want minimal CSA to generate speed quickly Pulses can be thought of like a frequency on a oscilloscope display that change with rpm
........... The More You Follow The Herd The Less You Can Be In The Lead .......... Last edited by Formulas; 01-05-2021 at 06:04 PM. |
