Old 01-14-2021, 09:58 PM
Originally Posted by JLMounce View Post
Technically speaking, unless you’re running a lockup converter, your DS rpm will still be less than engine RPM due to torque converter slippage, even if your final is 1:1
But that’s splitting hairs of course.
Not necessarily.
  #42
Old 01-14-2021, 10:06 PM
JLMounce JLMounce is offline
I guess if you're on the limit, knowing your slippage across the line would really be necessary. Or calculate backwards from mph and gear ratio to get true shaft rpm.
-Jason
1969 Pontiac Firebird
  #43
Old 01-15-2021, 09:27 AM
AG's Avatar
AG AG is offline
Originally Posted by Chief of the 60's View Post
Just curious. Some do not. That, obviously effects flywheel RPM vs. tail shaft RPM. That effects driveshaft RPM
My converter slips 6.8% across the line so my driveshaft rpm will be slightly lower than flywheel rpm.
