Old 05-06-2023, 01:20 PM
Originally Posted by scott70 View Post
OPH...you spoke of the 12 bolts that came in the 455 A-bodies. My 70 455 gto still has its original 3.31 posi 12 bolt. What are the differences between that and the chevy 12 bolt? What parts will interchange? Thanks
On the 12 bolt c-clip axles that found their way under the '70-72 455 GTO's & '71-72 455 LeMans, they were all built of the McKinnon plant in Canada. There was also some usage of this style rear in '68 & 69 Olds A-body's & '69-70 Buick Skylarks. These specific 12 bolts had different axles, backing plates, different drums, and a 3R pinion yoke. All different than the common Chevrolet application 12 bolt rear.
The McKinnon cast 12 bolt housing will also not have a date code cast into the lower pass side webbing. Instead, the housing is date coded on the front of the lower "lip" area of the housing, visible from the front of the housing. On many McKinnon 12 bolts this date casting may not even be legible, the casting date is quite small.
McKinnon (GM of Canada division) also built some 12 bolt "Chevelle" rears for Chevy usage, I've ran across several out of '69 & '70 "Chevelles". These will have the Chevy specific ID codes, as well as the standard duty Chevelle ('70 F-body) length axles, smoothie style drums, & the very common style "Chevy" backing plates with the spotwelded flange.
  #42
Old 05-06-2023, 05:40 PM
Schurkey Schurkey is offline
The 8.5 rear design was introduced for 71 model GM passenger cars. GM 1/2 ton pickups would have to wait til '77 model year...
...B body:
for '71, most GM divisions used a c-clip axle 8.5 B series rear in their base B series models.
Originally Posted by Cliff R View Post
You mentioned someplace about 1977 half ton trucks getting 8.5's by 1977.
Well. Aren't I embarassed.
I have learned something new, and I wasn't expecting this.
I was sure that the 8.5" wasn't used on B-bodies until the major downsizing in '77, when the B-body was shortened and lightened; basically a boxy body on a modified A-body frame.
And I thought the first use of the 8.5 on pickups was for the '88 model year which started earlier than usual in '87. The 8.5 was upgraded in late '88 for '89 model year with 30-spline axles and side-gears, maybe bigger bearings.
I believed that the 8.5 was a wonderful axle for compact and intermediate cars using small-block engines, but had no business behind a big-block or under a full-size car; and the 8.5 is a hot mess under a full-size pickup. Seen too many 8.5s shattered and exploded under GMT400 trucks. Strangely, I've never seen a blown-up 8.5 under a Squarebody truck.
  #43
Old 05-06-2023, 08:52 PM
Abused Eaton Govenor locks have taken out more gearsets & 8.5 rears in pickup housings than anything else. Very rarely have I ran across a blown up 8.5 ring & pinion even in a street strip car build.
What i ran into alot years ago was many young owners thought with a lift & big tires, their "truck" was ready to go to the river. In the course of playing at the river, doing big donuts, etc, the Gov-lock rear was the weak spot. The Gov-locks just do not like two big rear tires/rear of the truck being thrown in an arcing manner.
When a Gov-locks blows & takes out the ring & pinion, they typ take out the drivers side cap, as well as many times taking out the cap mating area of the housing. From there, the owners typical action was a search for another rearend. The chance of finding just a core rear or housing in the cheap yards was usually very slim as the 4WD 8.5 housings & axles are of a different length than the 2WD variety. For a while, I pulled that particular 4WD pickup housing in a few Pick-N-Pulls, eventually rebuilding them with a new clutch type Eaton carrier, or in a few cases with used 30 spline Auburn posi carriers out of B series 8.5's (impallas & Roadmasters).
  #44
Old 05-06-2023, 09:27 PM
scott70's Avatar
scott70 scott70 is offline
Is the carrier the same as the chevy 12 bolt? Didnt know if a chevy 3 series posi carrier would fit if anything went wrong with mine.My diff cover looks identical to a chevy 12 bolt cover. Also the rear pinion yoke takes a U bolt and not a strap for the U joint.
  #45
Old 05-06-2023, 09:33 PM
the carriers & ring & pinions are the same.
  #46
Old 05-06-2023, 10:38 PM
alsalp alsalp is offline
what are the carrier breaks for bop 8.2's?
  #47
Old 05-06-2023, 11:33 PM
2.56 and 2.78
2.93, 3.08 and 3.23
3.36 and numerically higher.
  #48
Old 05-07-2023, 07:28 AM
Cliff R's Avatar
Cliff R Cliff R is offline
"Cliff, On the half tons, the base 1/2 tons began receiving the 8.5 10 bolts in '77, while the Big 10 Chevys & Heavy Half GMC's received the 12 bolt truck axle."
I've seen the 12 bolts as late as 1979 so knew they still offered them in some applications. My 1979 K-5 Blazer had a 12 bolt in it, and it was the only 12 bolt I've ever seen with the Eaton Locking carrier in it.. Those do get a bad rap for blowing up, but I've never had the first issue with one and have owned many GM trucks, Blazers and Suburbans with them. The death sentence for them is putting one wheel on wet grass and the other on pavement and whacking the piss out it. Over zealous youngsters also try to do hard right hard turn burnouts with them at every stop sign they come to and they don't last very long doing that either.
I've found them difficult to rebuild and service, and had to make special tools to press the governor and latch assembly out of them. I still consider them an excellent part for what they were designed for, but a very poor choice for drag racing diffs.......
https://www.youtube.com/watch?v=ftyJvIO0DZ8
  #49
Old 05-07-2023, 01:55 PM
NeighborsComplaint's Avatar
[QUOTE=So tell me... did Pontiac ever put an 8.5" in one of our beloved (Pontiac) A-bodies? [/QUOTE]
Short answer ... Nope. BOP 8.2" 10 bolt w. bearing flange axle retainers was specific to Buick, Olds and Pontiac. Chevy had its own 8.2" 10 bolt which utilized C clips for axle retention before the corporate 8.5" 10 bolt became the norm.
Good article here: https://www.hemmings.com/stories/art...o-p-rear-axles
Triple Black 1971 GTO
  #50
Old 05-07-2023, 03:28 PM
Quite a few errors in that "good" article.
Pontiac most certainly installed 8.5 rears in nearly every '73 A-body.
Mention "nearly every" as there were the 8 7/8 MP series rears that came in the SW's & for a few years in numerous 455 powered GrandAms, etc,
  #51
Old 09-29-2025, 01:55 PM
FullHawgPoncho FullHawgPoncho is offline
What is this? I thought it was a 10 bolt BOP 8.2, I just noticed today it has 31 spline axles instead of 28 splines like I thought it would. Came from underneath a 66 GP. RH tube is stamped UB. Haven’t opened it yet to see what’s inside, not a posi.
ID:	657938   Click image for larger version
ID:	657940   Click image for larger version
ID:	657942   Click image for larger version
ID:	657943   Click image for larger version
  #52
Old 09-29-2025, 07:07 PM
TXSTARFIRE TXSTARFIRE is online now
2.41 Ratio non locking differential from a full size Pontiac. Should have a 10 bolt cover with a 12 bolt ring gear. Fits 65-70 full size Pontiacs.
  #53
Old 09-29-2025, 09:54 PM
This has been confusing. Couple hours after I posted I found out it’s sometimes called a p type rear end but it’s a 12 bolt ring gear 8.875 with a 10 bolt cover.
I’m trying to find a posi for this, or figure out if I can use a GM 8.875 carrier if I axles that are splined to match. Is there any good reading on this or anyone here know?
  #54
Old 09-30-2025, 10:18 AM
rustyrelic rustyrelic is offline
Hawg,
What exactly are your plans for this 12-bolt? I think you will find that there is next to nothing in the aftermarket for alternative gear sets or even simple stuff like bearings. "performance" gear ratios are very limited and will require a different carrier.
I would suggest you sell this for whatever you can get and start over.
If you are intent on continuing to run this down, do some searches in the B-body sections and consider your options. Remember, these rears are pretty much unique to 65-70 and the mountings and such are usually only for a two year period. On-line parts listings for Pontiac big car 12 bolt are nearly always wrong and to the best of my knowledge the chevy truck and car stuff does not work leaving you scrounging for 50 + year old used pieces.
Sorry to paint such a bleak picture.
  #55
Old 09-30-2025, 01:25 PM
Originally Posted by rustyrelic View Post
Hawg,
No I appreciate you being honest, and have realized I was in a pickle ever since I noticed the 31 spline axles.
Just a fun drag and drive. Came with a 71 400. Found a locked up standard bore 1970 455 to cram in it. Cracked it open last night, it has 2.56 gears in it. Looking like it’s destined to be a cruiser.
Do you have any idea what quick performance or the like would charge for a rear end to be built for it?
Is it possible to get a GM 3.08 gear set and swap the yoke with one that’s correctly splined? I’ll weld them up if I can accomplish that.
  #56
Old 09-30-2025, 02:29 PM
Ok, we need to do a bit more research. Did this axel come from a '71? That creates additional wrinkles which I am not familiar with.
  #57
Old 09-30-2025, 02:43 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Default 8.2 Example
Nice information in the this thread!
Not sure if this helps post will help - but here is my rear end pics in my 69 gto which back in 2005 I asked a fellow I met off the PY board, i think, and he said mine is a :
FRONT DRIVERS 68D
Front PASSENGER SIDE 1385724-F
>>Yes, your rearend is an Olds rearend. Well, it's actually a
>>corporate
>>rearend, in that it was used on Oldsmobiles, Pontiacs and Buicks
>>of the
>>same era. It's the 8.2 10-bolt. I've got the same one in my '67
>>that
>>came from a '67 442 with a 4-speed.
>>Keith
ID:	658017   Click image for larger version
ID:	658018   Click image for larger version
ID:	658019   Click image for larger version
Name:	diagram ident.jpg
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
  #58
Old 09-30-2025, 03:59 PM
No I was just talking about the engine. I believe the year end is original to the car. Date code in picture ends in either a 5 or 6.
Mainly curious is GM and Pontiac 8.875 pinions interchange. If they do, those gear sets will be easier to source. Someone also makes a spacer to adapt series 2 gear sets to a series 1 carrier.
Anyone ever bought any of their products? Still researching, but I’m wondering if one of these spacers and GM gear sets would work if I could fix the difference in splines on the yoke.
https://fabcraftmetalworks.com/produ...-assyra5-0241/
  #59
Old 10-01-2025, 09:10 PM
Gov-Bombs
My understanding--perhaps I'm wrong--is that the 8.5 "corporate" axle was The Cat's Meow" in compact and intermediate cars powered by small-blocks. Big-block cars got something stronger--a "Chevy" 12-bolt, for example--and full-size cars got a stronger axle assembly until full-size cars were "downsized" to intermediate size.
GM had no damn business putting 8.5" axles under full size (1/2 ton) trucks.
Gov-Bomb or open, the '88-onward 8.5" differential cases EXPLODE, sometimes without being worked hard--just driving along. I see more exploded "open" differential cases, probably because there's at least ten open cases for every locking (Gov-Bomb) differential case. It makes me wonder if GM/AAM cheapened the 8.5" axle, leading to the diff cases blowing-up.
The 7.5" Gov-Bomb is just as bad, but under lighter vehicles.
The 9.5" and 10.5" Gov-Locks are sufficiently robust. No real problems with them except that given enough miles, they can just plain wear out the clutches.
The GMT400-series pickups in 1/2-ton (1500 series) almost always have horrible leading-trailing shoe drum brakes attached to the brittle, fragile 8.5" axle assembly. Swapping with a 6-lug 2500 (C for 2wd, K for 4WD, they're different widths) axle assembly of the correct gear ratio fixes both problems--crappy rear brakes, and weak axle.
  #60
Old 10-02-2025, 05:23 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Has anyone used the E-loc Auburn locker? It's a posi but via a switch you can lock it like a spool.
