Old 03-04-2022, 10:36 AM
Virtually all deals in the street sections end up in how much HP is being made or lost when street ability is way important in my mind.I deify someone to tell me the diff in 25HP peak HP from the ass dyno in a car that is 90% of the time driven from off idle to 3000.Just another day.Tom
Well said, Tom! Most people cannot tell the difference. What people SHOULD be obsessed with is does their street engine idle at a stoplight and NOT overheat, does it get reasonable fuel economy, and do you have to wear a gas mask to keep from suffocating from the unspent fuel fumes from the tailpipe.
Dr. Thomas Sowell
Old 03-04-2022, 04:43 PM
Joe-Touring Joe-Touring is offline
Definitely, I wanna drive the hell out of my car this summer. I’ve spent more than enough time wrenching on it, it’s turned out great, but I would like to take some big trips without any issues. And perhaps after enough seat time and tuning experience, make some more aggressive changes.
67 LeMans, 326, M20, 3.31 12 Bolt
Old 03-04-2022, 04:07 PM
Absolutely, everything is a compromise. You have to take all your drivetrain components into account, and determine what trade offs are worth it to you. And you’re right, most people won’t notice an extra 25hp at 5000 RPM, but they most definitely will notice if it doesn’t idle below 1000 or get better than 12 mpg.
Old 03-04-2022, 10:00 AM
PAUL K's Avatar
PAUL K PAUL K is offline
FWIW we have built a LOT (comparatively) of Pontiac engines using an SD455 block as the foundation. They have consistently had the thinnest cylinder walls of all the 455 engines we have checked. So any folks looking to get rid of those junk thin wall blocks, I would be happy to take them off your hands, I'll supply with a nice 455 block with thicker cylinders and even set up the freight on my end.
Go fast, see Elvis!
Old 03-04-2022, 10:39 AM
I sure you would, Paul! The idiocy of some knows no bounds. BTW....no disrespect toward you as an engine machinist and builder. Your omission was a brain fart on my part.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 03-04-2022, 04:38 PM
would his theoretical 800 horsepower stock block Pontiac engine with eight sleeves make more power compared to a block with no sleeves and thin cylinders?
I’ll take a crack at this. I’d say it would make more power due to the higher cyl rigidity resulting in better ring seal and less piston friction.
Interesting, do the SD’s have design characteristics that would make the thin cyl walls a non issue? If I did a short fill w/ hardblok and got lighter forged pistons/rods, would it hold up to 9.5 comp and a RAIV cam? Otherwise, it seems dropping the coin on good pistons/rods would be a waste.
Old 03-04-2022, 03:14 PM
highway star's Avatar
highway star highway star is offline
I'd first confirm the cylinder numbers on that sheet are correct, because they are switched sides?
Old 03-04-2022, 04:45 PM
The sleeve is at least marked in the right place, driver side rear, but other than that, I can’t say. The thin spots are all over the place, and at this point I can’t say that I want to sleeve the whole block and make a fire breather.
Old 03-04-2022, 06:34 PM
tom s tom s is offline
If doing custom pistons you can bore just what is necessary,dont have to do 30-60.Tom
Old 03-04-2022, 08:12 PM
74Grandville 74Grandville is offline
I’ve looked at the gap between the cylinders between a 400 vs 455 and there didn’t seem to be much different. Yet the STD bore on a 455 is larger. This does not take core shift into account.
I’ve heard 400’s going .060 with out to much issue, but I’m not sure I’d trust a 455 at .060. I think of a 455 as a 400 already .030 over.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
