#41
Also, if your RA manifolds are original factory pieces, don't try hogging them out since they are gray 'pig' iron and prone to cracking especially in the 'thinner' areas. The aftermarket RA manifolds are cast with ductile iron that is much better quality and can be opened up a bit (grinding and extrude honed). Dennis |
#42
Dennis |
#43
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
#44
I will also say that I'm swapping the '70 intake/7040764 combo this summer for a SD Performance phase 3 CNC'd iron intake (the 600 hp version) and a '71 7041267 'big' Q-jet to go with the SD Perf heads already on the engine. They're just meant to go together. Now I just need to get a pair of 2.5" D-port RA manifolds to complete the factory look.
Dennis |
#45
sheets.https://www.youtube.com/watch?v=-7vZwbCQlUw
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' Last edited by scott70; 03-21-2022 at 02:16 PM. |
#46
Here is a graph of the 2 HP curves together.
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#47
Just got back from my builders shop. Dropped off all the parts I had, heads, cam, lifters, etc. Laid eyes on my IAII block, that thing is awesome. He'll be starting on it within 2 weeks and should be done 3-4 weeks after that. Now I just have to get the car in to my mechanics shop to have the motor pulled because I still need to get the intake and exhaust manifolds and distributor to the builder, but at least he has what he needs to get started.
Can't wait for Dyno day, and I'm gonna be there for that.
The Following User Says Thank You to jhein For This Useful Post: | ||
