Old 12-08-2022, 03:33 PM
77 Canamman's Avatar
That '74 is a nice driver quality car. Needs a cosmetic resto to get the huge dollars, and it's a 1974 non A/C Auto..
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #42
Old 12-08-2022, 05:58 PM
I am probably one of the few.. I prefer a non-A/C car as the A/C is just in the way. My '73 has working A/C and I never use it. These old A/C systems are kind of a waste on a 90+ degree day IMO. They don't perform like a modern car. When its 90+ out... my classics stay in the garage and I drive one of my modern vehicles.
1974 Formula 400 - Ram Air automatic
  #43
Old 12-08-2022, 06:01 PM
Do you want to trade for my non-working A/C...
  #44
Old 12-08-2022, 06:43 PM
jhein's Avatar
jhein jhein is offline
I'm with you. No AC for me.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
  #45
Old 12-09-2022, 08:46 AM
If the A/C system is fully charged with R12 and other parts are clean and proper, there should be no reason it can't chill you out of the cabin, even on a humid 90 degree day. Those systems were more than capable if the condenser is clean, and the correct refrigerant is used. I get 38 degree air out of the ducts on my 1977 T/A during a hot day.
The Following User Says Thank You to 77 Canamman For This Useful Post:
  #46
Old 12-09-2022, 10:00 AM
scott70's Avatar
scott70 scott70 is offline
I purposely looked for a non a/c car way back when I was looking for a classic car. I know I'm not driving it everyday so in the summer I don't mind just driving with the windows down. I don't like the extra clutter and weight under the hood.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
  #47
Old 12-09-2022, 01:12 PM
It's converted to 134. It blows 42 degrees. Yes I realize R12 would be better. Most of the system has been replaced. My biggest issue is that it doesn't blow hard enough... yes the blower motor is functioning properly. When its in the 80's its fine but I generally have the windows down when its in the 80's. When it gets up into the 90's/100's with the baking hot California sun it doesn't keep the car cool enough. It would probably work better if I lived further north where the sun is less direct. Even though the cooling system has been gone through. It runs warmer than I would like in heavy traffic with the A/C on... Its an old car. I tend to avoid baking sun with that car anyways... I don't want the dash .. etc.. to crack. Guess I'm spoiled with modern car HVAC systems.
  #48
Old 12-09-2022, 04:40 PM
Just curious. On a 2nd gen F Body, there is a large foam seal in the main ducting for the dash. The foam can disintegrate, and air can leak around the opening, lowering the intensity of the air through the vents. Also, the main duct under the glove box, which this seal is attached to, is a known weak spot, and can crack, leaking more air.
  #49
Old 12-09-2022, 08:30 PM
Its possible. Car is almost 50yo.
  #50
Old 12-12-2022, 01:32 PM
Default '70 T/A, RA III, 5speed, restored
https://bringatrailer.com/listing/19...d-trans-am-20/
This will go thru the roof...I like those 17's
  #51
Old 12-12-2022, 01:33 PM
Old 12-12-2022, 02:51 PM
jhein's Avatar
I'm really conflicted about the 17's. On some cars they look great, on others not so much. They either sit too high, or too low. This one looks fantastic, they got it just right.
But regardless, to get it right you have to lower the car some. That plus the fact that the overall tire height is less would seem to make the ground clearance too low for my comfort.
The Following User Says Thank You to jhein For This Useful Post:
  #53
Old 12-12-2022, 02:54 PM
I hear you - I'm conflicted as well
Luckly I have time on my side as I need a complete exhaust replacement anyway...lol
  #54
Old 12-12-2022, 08:47 PM
Wish it was blue..
  #55
Old 12-12-2022, 11:11 PM
Formulabruce's Avatar
All about "stance and looks?" Ever driven an original car, or worse one with poly bushings with taller wheels with no sidewall... over any bumps?
The stock suspension is SOOOO Slow, the car is on the next bump as the tire is just coming down from the last.. Result.. 1 ton truck ride...
GM Never put bigger wheels on these cars until they installed a much faster Strut system.
One way around this is to put on Global West Del A Lum Bearings in the control arms so they move freely, and use a good gas charged shock, OR
put Qa-1 adjustables in your converted ( to Global west bearings) control arms.
stiff suspension beats up the car and my back....
The Following User Says Thank You to Formulabruce For This Useful Post:
  #56
Old 12-13-2022, 12:40 PM
That's another good point...the roads are horrible here and I'm due for a stock suspension re-engineering...
  #57
Old 12-16-2022, 02:33 PM
58k and an hour to go...hard questions coming out lol
  #58
Old 12-16-2022, 02:39 PM
Unhappy
I can't recall a time where I have seen a more eaten up tag, meaning that this could have been a rotted turd at one point. The pop rivets are obviously wrong.
  #59
Old 12-16-2022, 02:40 PM
oh noes...u figure he is about to pay for a re-popped firebird?
  #60
Old 12-16-2022, 03:56 PM
reserve not met...wth!
It's not THAT nice...lol
