Living in south Florida on a cool night in the winter the 1967 428 HO loves the higher 93 octane with 10 % Alcohol but the next day it is 90 degrees and the Alcohol takes affect and starts vapor lock issues. Then I have to go to the Rec- 89-90 fuel, less Alcohol. Last edited by TRADERMIKE 2012; 06-30-2022 at 07:48 PM. |
| The Following 2 Users Say Thank You to TRADERMIKE 2012 For This Useful Post: | ||
| The Following 2 Users Say Thank You to 78w72 For This Useful Post: | ||
Please don't provoke the thread killer
'65 Tempest 467 3650# [email protected] |
| The Following 3 Users Say Thank You to Scott65 For This Useful Post: | ||
Tuning with an air/fuel ratio meter is tuning by BTUs or energy content of the gas you are using.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
For sure ethanol has properties that allow an engine to make more power without detonating, when tuned for it. Higher detonation resistance, and an extra cooling property that helps prevent heat buildup. On a Buick turbo V6, we can run some absolutely insane boost on E85, but it requires as much as 50% more fueling than with regular gas. That's a pretty dramatic increase. We also have the benefit of an ECU that can run different injection and ignition tables depending on what fuel is in the tank. None of that is easily achievable on a Pontiac V8.
Right now, you'll find blends with up to 15% ethanol at the pump, though 10% is most common. The biggest issue with that is the swelling it'll cause on some seals and floats if they're not ethanol-tolerant. If the carb is tuned right, it shouldn't affect idle quality enough to be noticeable. |
| The Following 2 Users Say Thank You to GoreMaker For This Useful Post: | ||
Boost for sure works well with E85.
I had a couple friends about 15 years back that was building N/A engines using E85. Knowing that was the fuel to be used these engines were purposely built with a lot of compression. I think they were 12:1 or a little more if I remember correctly, pretty radical camshafts, carbs setup for E85 and ran strictly an E85 diet. They ran extremely strong but the problem was E85 availability. It wasn't everywhere then and it's still not everywhere now. That really limited the distance these cars could travel and basically remained around the town where the E85 pumps were, because regular pump gas for these engines at that point wasn't an option anymore. |
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
Yep, In the grand scheme of things 10% really isn't all that much anyway.
10% Alcohol in the fuel is all the difference in the world in my case, any Alcohol in my fuel on a hot day will cause my engine to vapor lock. |
[QUOTE=GoreMaker;6353234]For sure ethanol has properties that allow an engine to make more power without detonating, when tuned for it. Higher detonation resistance, and an extra cooling property that helps prevent heat buildup. On a Buick turbo V6, we can run some absolutely insane boost on E85, but it requires as much as 50% more fueling than with regular gas. That's a pretty dramatic increase. We also have the benefit of an ECU that can run different injection and ignition tables depending on what fuel is in the tank. None of that is easily achievable on a Pontiac V8."
It's not easy, but it can be done. I'm happy to be able to mix E85 and regular unleaded with gas prices through the roof...
[QUOTE=Scott65;6353303]
" Long may we DRIVE !" |
[QUOTE=Formulabruce;6353396]
Mike, I live a half mile from that same train track. It's an unspoken rule in Memphis that we never discuss the fault line, and if we accidentally think about, we drink till we forget about it.
I see the OP’s options were 91 no ethanol and 93 w/ethanol. I was thinking just the opposite. In that case, I would not move up to 93 unless it was required.
We don’t get to choose the blend of 91 here at my small towns. Usually if a town has 3 stations, only one station will carry 91, and most often it is a ethanol blend. 93 is becoming further and further away. I just looked and the station that had it closest to me (45 miles) is now dropped to 91. I don’t even know where I would go for 93 now. |
You have not been through a earthquake until you see chunks of firewood bouncing 4" in the air and flipping over in your backyard. I was at work one time when we had three 7.2s in one day. The chain on the green chain was clacking, catching a little air when the first one hit. That night there was a light post outside my bedroom window. You seen it, then you did not see it, over and over.
Makes you feel like a insect. |
FYI - There are no federal subsidies or tax incentives for ethanol. There are federal mandates for required volume of renewable fuels which does force the oil companies to use ethanol since it seems to be the best solution.
There are long standing tax incentives for petroleum production which to some degree does affect taxes or the national debt and inflation. Last edited by Nobuddy; 07-01-2022 at 08:02 AM. Reason: X |
There's farm subsidies for growing corn that gets used for ethanol. From research over the years, ethanol corn wouldn't be profitable to grow without those subsidies. So because of those subsidies (which are entirely funded through taxes) farmers grow that instead of actual food.
But that's neither here nor there. That's a completely different discussion. As far as E85 giving worse mileage, that's entirely true. If you're injecting 35 to 50% more fuel, then you'll get 35 to 50% worse mileage. In the turbo V6 community, we usually do it for racing purposes, then we switch back to regular fuel for street driving. Basically the same way some people will run AVgas for a day of drag racing |
| The Following User Says Thank You to GoreMaker For This Useful Post: | ||
There are no subsidies to farmers for growing corn for ethanol. Virtually all US farmers receive some federal subsidies for almost every crop grown. But there is no difference in subsidies a farmer gets selling their corn for food compared to selling to an ethanol plant. The additional demand from the sustainable fuel mandates certainly raises the total demand and the commodity price for corn. Full disclosure, I am a farmer although no corn. |
| The Following User Says Thank You to Nobuddy For This Useful Post: | ||
| The Following User Says Thank You to Formulabruce For This Useful Post: | ||
There is a .45 cent per one gallon tax credit for fuel blenders to blend ethanol with gasoline. There are no direct subsidies to farmer’s to grow corn for ethanol any more than there is to grow anything else. The reason corn gets planted and used for ethanol is do to the demand from the RFS.
Here a list of all the specific federal energy subsidies. https://afdc.energy.gov/fuels/laws/ETH?state=US Run what ever fuel your car likes. I have never seen a disadvantage to running 93 octane over 91 octane. If it is with in the budget, and can buy it local, i definitely suggest using 93. Should be no problem dropping back 91 if need be for part throttle cruising until you can get back to your local 93. IMHO. 93 straight gasoline is a better fuel than any of the lower octane fuel no matter what the mix. Especially for guys who’s car sits more than it gets driven. Last edited by Jay S; 07-01-2022 at 05:02 PM. |
