Old 11-23-2022, 11:25 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
I ordered one with 2.20 journals and a set of their rods that way there is better bearing choices. I also decided to go with their 6.625 rods vs a 6.8 for more piston choices.
  #42
Old 12-29-2022, 03:48 PM
R 70 Judge's Avatar
Any updates?
James
1970 Trans Am
  #43
Old 12-29-2022, 07:12 PM
adamo adamo is online now
I messaged the guys at molnar. Told them I wanted a 4” stroke 3” main 2.25” Pontiac rod journal. They said they can make me one. I told them I would place a deposit in the new years and they said no problem. Said production scheduled to start in august
  #44
Old 03-06-2023, 08:25 PM
racerboy's Avatar
racerboy racerboy is offline
Look what arrived today!
Hopefully there’s a 4.00 in crankshaft on my doorstep before long.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
The Following 3 Users Say Thank You to racerboy For This Useful Post:
  #45
Old 07-28-2023, 02:06 PM
1_Wild_Cat's Avatar
4" stroke crankshaft arrived today. Man that package is heavy...
  #46
Old 07-28-2023, 02:33 PM
Gach's Avatar
Gach Gach is offline
If you get a chance weigh that crank and let us know what it weighs. Just curious of weight compared to Crower billet crank. Thanks
  #47
Old 07-28-2023, 03:13 PM
1_Wild_Cat's Avatar
I can tell you with packaging it weighs 88 lbs. I'll try to get a weight on the bare crank when I take it to the machine shop.
The Following 2 Users Say Thank You to 1_Wild_Cat For This Useful Post:
  #48
Old 07-29-2023, 11:01 AM
jkjudge jkjudge is offline
So what is the difference between the Molnar crank and rods compared to what Butler offers? Scat or Eagle.
  #49
Old 07-29-2023, 12:19 PM
I ordered one because they offered a pontiac Rod journal/pin. Haven’t seen any like that. Now if I wanted I could use the set of max-a-lite A-beam tomahawk Rods I have that are 706 grams and build a nice 4” stroke combo in a 400 GTO block
  #50
Old 07-29-2023, 05:02 PM
Gach's Avatar
One of the critical things you need to have your machine shop check…is check the crank for straightness.
  #51
Old 07-29-2023, 05:12 PM
mgarblik mgarblik is offline
It's kinda the "good, better, best" scenario IMO. Eagle= good if your willing to re-work some or all of the order. Scat= better but some minor re-work needs to be expected. Molnar= Every dimension +-.0001". Measure, wash and install on everything we have ever received from Tom Molnar. BTW, Butler supplies Molnar as well.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
  #52
Old 07-29-2023, 07:00 PM
Stan Weiss's Avatar
So put the crank in the block with only bearings for 1 and 5 and checking 2, 3, and 4 with a dial indicator does do that?
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
  #53
Old 07-29-2023, 07:36 PM
Stan
Checked many cranks for straightness; never did it the way you describe. We had an actual fixture that supported the crank on both ends while we sat a dial indicator on number three main journal. The fixture had roller bearings that allowed the crank to turn freely with minimal resistance.
Dr. Thomas Sowell
  #54
Old 07-29-2023, 07:45 PM
Gach's Avatar
Exactly how machine shops check them. Well the good machine shops.
The Following User Says Thank You to Gach For This Useful Post:
  #55
Old 07-29-2023, 08:08 PM
Dragncar Dragncar is offline
Tom Molnar told me himself, if any Molnar rod or crank is out of spec in any way they will send a call tag and pick up the product on their dime and send you a new one.
Can not ask any more than that.
  #56
Old 07-29-2023, 08:28 PM
Gach's Avatar
Initially quality control is good, but don’t take it for granted.
  #57
Old 07-29-2023, 08:35 PM
Stan Weiss's Avatar
Troy,
It is great to know If we checkout their product and it is not right they stand behind it.
Stan
  #58
Old 07-29-2023, 09:33 PM
For some reason my experience has been the opposite on the Chinese stuff. The first set of Eagle rods we had in the shop were 100% failure. Couldn't use any of them. Sent them back, no issue. The next set had 2 in spec. 6 out of spec. Called and asked for a supply of dowels so we could take them apart, cut them, hone them and use them. Good experience for the students. They were pissed on the phone but after calming them down they sent a little cloth bag of dowels. This was 10-12 years ago. As time has gone along, the rods have been better and better but we check every one for size, out of round and taper. About 5% or so now still need some touch-up in the hone to really be right. They almost always measure small when there is an issue so very easy to fix. Haven't had to cut an eagle rod in several years because it was too big. Press fit small ends are particularly tight. There is just no way to install them as delivered. Often have .003"-.004" press fit. That's just too darn tight. You would have to heat the small end to bright blue to get a pin in. That;s not the right way to do it. We hone them to .0016-.0018 press. That works great. Different shops have different methods. Some even press in at room temp. I don't want to move any metal installing wrist pins. Been using Molnar products for 3 years now. Have not had to machine anything. Still check every part though.
  #59
Old 07-29-2023, 09:36 PM
Gach's Avatar
How long did it take from day your order it, to actually get it in your hands
  #60
Old 07-29-2023, 09:59 PM
1_Wild_Cat's Avatar
The 4” stroke was a new product for them. They took preorders to justify the run/offering. That said I ordered 8/2/22 and received on 7/28/23. About 1 month sooner than the expected lead time.
