Thought I’d start a new thread on my plans to build a 4.00 in. stroker out of the RA III in my ‘70 TA. I started the journey today with starting to get ready to pull the engine and transmission. It’s been a while since I’ve done this, and I definitely have some questions.
I stayed with draining the radiator, removing radiator, shroud, fan, pulleys. I just pushed the p/s pump to the side but did not disconnect any lines. Pulled the starter, oil filter housing and fuel pump. When I was removing the fuel pump, the gas line just kept draining? I’m not sure how much gas I have in the tank, but I filled up a 5-gallon gas container before I just plugged the line with a bolt. I also disconnected the exhaust. That was about it for today. Can the engine come out with the RA manifolds on? Should I remove the distributor? Since I’m rebuilding the trans as well, can that stay attached and just pull them as a unit? I’m sure I’ll have more questions as I go along. As always, appreciate the feedback I get here. ![]() ![]() Sent from my iPhone using Tapatalk
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
