Old 05-17-2026, 09:19 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Just went through the same thing with a 389. Engine sat for around 25 years. No oil came out out when the drain plug was pulled. When the pan and water pump were pulled both the oil and coolant were jelly. Oil may have been dilluted with gas. When the the gas evaporated a solid was left. Disassembled it down to a short block, removed all the oil, freeze plugs, and main caps. Bearings looked good so the crank was lifted so all the oil feed holes could be cleaned. Had to use a steel rod to push the goop out of the oil galleries. Stood the block on end, used a long bottle brush and solvent, air and water hose to clean every orifice. Can be done. Engine is together and sounds great with good oil pressure. Is the juice worth the squeeze? You be the judge.
  #42
Old 05-18-2026, 08:25 PM
2BadZ 2BadZ is offline
Originally Posted by Skip Fix View Post
From looking at those rockers it needs to be pulled.
Thanks. From the look of the replies, don't have either "nothing to it sure"
I wasn't that inspired when I pulled the valve covers.
  #43
Old 05-18-2026, 08:26 PM
Originally Posted by Jim Moshier View Post
after seeing those pic......Yeah I too would pull it and do a complete tear down. The rust is too bad to let slide!.
Thanks. I appreciate the reply.
  #44
Old 05-18-2026, 08:34 PM
Originally Posted by zippy View Post
BWAHAHHAAAA!!!! Spoken like a true CANADIAN!!!!. Sicamous BC here, and yup, bout the same. Cars, sleds dirtbikes, RV trailers.
But any rate, Yeah that motor needs to come out and get opened up for inspection and cleaning at least.
Yep, and I could even throw an "eh" in there. Before the winter that we just went through, I shoved everything out in the back yard and tarped them over, and put the Trans Am in the garage with the other car. It's an attached 18' to 20' by 22' so not much room. Since the 2022 posts, I've added a kids quad, a tow behind trailer for the quad, a Pelican sleigh for one of the sleds, and a dirt bike. So it didn't get better.
Thanks for the reply.
  #45
Old 05-18-2026, 08:36 PM
That top end is shot!
Only the bare heads will be salvageable if they are not cracked.
Even if you get it started You will never get enough of that rust off to not have enough in the oil to not chew things up like bearings, rings. Cylinder walls , cam & lifters.
Time to yank it and tare it down.
As
Thanks. The 455 is a short block now, with the rest of it stored separate. So I'd likely work with that one.
  #46
Old 05-18-2026, 08:46 PM
Thanks for the reply. I'd likely go with the 455 if I have to tear it down, and the consensus is pretty much that I do, but I don't have the time to get into that right now. So for now I might try to clean up the heads, put the camera down the pushrod hole/s and up the drain plug hole and flush the hell out of it with whatever I have around. An hour here and there over a month or so.
I'd have to get rid of the Trans Am to have room to work on the Trans Am right now.
  #47
Old 05-18-2026, 09:49 PM
HWYSTR455's Avatar
Curious, what's the rest of the car look like?
  #48
Old 05-20-2026, 07:29 PM
I've attached a picture of the floor underneath. Pretty close to how it came from the factory. The two fenders will need repair to the bottom 6 or 8 inches, or I can replace them. Bottom of the quarters behind the wheels will need work, but I drove the car in Canada from 1979 to Oct 1995, so 16 years winters excluded. I turned the exhaust tips straight down when I replaced some exhaust sometime prior, and was advised that the exhaust would likely rot that area. I have the two repair pieces from roughly the marker lights down that I bought two, three, four?? years before I parked it. That area was going back then so no surprise there. Doors are excellent, hood is fine, trunk lid is good but I have two spares anyway. Wheel wells, cowl and upper cowl, lower corners of the dash at the windshield are all excellent. Roof has a Cars and Concepts T-bar that I added, aluminum frame with glass to glass panels, so the little bit of roof I have is excellent.
Name:	79 TA floor underneath.jpg
