#41
Damn, I was planning flywheel. Would you mind sharing your build please?
#42
Sure:
428+.030, stock crank (cleaned and prepped), stock length maxxlite rods, Icon pistons, first generation edelbrock 72cc heads ported by SD Performance 315 cfm configuration, SD Old Faithful V 1.0 cam, crower hyd rollers, smith bros push rods, Harland Sharp 1.65 rockers, port-matched torker II, 1 inch spacer and Holley 950HP. I also have a vacuum pump set-up but that's not really necessary. I run an AutoGear M22 wide ratio 4 speed and ford 9 inch 3:70 out back to help prevent me from becoming a modern art masterpiece at the track.
Only a pawn in game of life. |
| The Following 2 Users Say Thank You to surfsama For This Useful Post: | ||
#43
Surf,
What gear spacing is your trans?
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#44
| The Following User Says Thank You to adamo For This Useful Post: | ||
#45
Correct, same as the M20 just built like an M22.
#47
In "normal" street driving not stop light to stoplight hurry up I just dont feel any diff in a 4in or 4.21 stroke crank in my stick shift cars.The way they are built can show more of the diff.A 428 with a set of RA V heads and a 428 with a set of average D ports with the same cam the Vs are more lazy IMO.Tom
#48
I plan on running the 12 heads. They are not ported yet, but I would like to get them ported this winter. I did order the 6.625 rod from Molnar. I just got the block back from the machinist. He’s happy to do any machine work, but doesn’t have any time for assembly. The block is already .030 over and it only needed a hone (there were only about 5k miles since the previous owner had it bored and rebuilt). Not sure about pistons yet. Paul K suggested cutting the 12s down to 65cc and then ordering the pistons with a dish in them. Now that I know my bore size is going to stay at .030, I really need to get the heads to someone. I don’t want to hijack your thread, but I just got the first photo of my intake that is being modified by one of Cliff’s disciples (fellow named Ray). It’s still a work in progress. He is also going to build my Q-jet. ![]() Sent from my iPhone using Tapatalk
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
