Old 01-24-2024, 10:20 AM
Jay S's Avatar
Jay S Jay S is offline
Originally Posted by 67Lemons View Post
I’ve been considering the cam saver lifters over the Hylift Johnson’s but there’s no mention anywhere that the Crower lifters are made in the USA so I’m hesitant to purchase them.
Hylift Johnson no longer makes Crower’s cams saver lifters. They have not for several years now. I think Crower’s lifters are still made in the USA though. I think they are sourced from the same company that makes Compscams flat tappets lifters. One of Comp rep’s said it is in Michigan yet.
If you want to use a HR for a fraction of the cost I have very nice used HR set up with HLJ lifters that is close to size as the cam you were running (275DEH).
The Following User Says Thank You to Jay S For This Useful Post:
  #42
Old 01-24-2024, 10:23 AM
P@blo's Avatar
P@blo P@blo is offline
Sorry Paul I did not notice your post when I pecked out my reply.
  #43
Old 01-24-2024, 10:27 AM
mgarblik mgarblik is offline
We had a cam/lifter failure on the dyno about 2 years ago. Engine had about 1 hour of running time on it. Ford small block. A 260 CU In stock engine restoration for a Falcon Sprint. So low valve spring pressure, very careful assembly, loaded up with break-in lube on cam and break-in oil. Melling cam and lifters, stock grind. One lobe went away fast. Short answer to "where does the metal go?". Answer, everywhere. It was incredible where that iron paste and tiny granules end up. Specifically, quite a bit in the piston ring lands and around the rings. Also packed up behind the dead end oil gallery plugs, in the oil pump, in the links of the timing chain, in the fuel pump cavity, rocker arm pivots, inside push rods, just everywhere. On this engine, we cleaned absolutely everything with solvent and spray wash cabinet. Surprisingly, we were able to use the rings and bearings over. But remember we are talking about 1 hour run time. The owner decided to go the hydraulic roller route he was so spooked. That was against my recommendation, but it made him feel more secure. I really think these occasional cam failures are just pure bad luck in many cases.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
  #44
Old 01-24-2024, 07:46 PM
Formulajones's Avatar
I wonder how many HFT failures were using stock grind cams, or modern replicas of stock grind cams, as opposed to modern profile cams.
If you filter out high performance cams and high spring pressures I wonder what the failure rate would be.
I'm curious .... did high performance cams of 40 years ago use similar profiles to modern HFT cams, or are modern cams more abusive to the valve train?
Hard to say if one is more prone than the other, I just haven't seen the failures with flat tappets. I run as much as 130 lbs. seat pressure on some flat tappets without issue, using modern grinds from Comp, while other cars here have stock camshafts or even 50 year old grinds from Isky that still work fine. There are some benefits however to the more modern lobes. But like I said, I go through extra lengths on mine with nitriding and pressure lube lifters etc... so a typical flat tappet for me runs about $1000. A hydraulic roller for me runs about $2000, sometimes more by the time I get the $1100+ lifters, etc... So the price difference is about double. Not horrible but not in the budget for many.
Like Mgarblik said, I really think these failures are just bad luck with a few other reasons mixed in, many of which aren't the cams fault.
https://youtu.be/XqEydRRRwqE
  #45
Old 01-25-2024, 06:16 AM
dataway's Avatar
dataway dataway is offline
Very possible they have always failed at the same rate they do now .... it's just that now, with the internet, each failure is amplified as thousands of people read about it. 30 years ago you said awww shucks, went to the store and bought new parts and no one heard about it.
And of course you never hear about the hundred thousand that broke in fine and have worked for years.
  #46
Old 01-25-2024, 06:25 AM
Exactly my thoughts dataway. Only difference between then and now is that now the information highway lets everyone know about it.
Sometimes I think everyone would be better off putting the computer down and just get back to building cars again. Spread info the old fashion way by getting these cars out and drive them, mingle with the car crowd
  #47
Old 01-25-2024, 09:39 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Before Hy-lift Johnson there was just Johnson. They had one of the best lifters on the market. Every lifter they sold had been hardness checked. Around 1990 they stopped this process. It makes sense to me they performed this QC test "for a reason". I'm doubting it was to keep an extra person employed.
Now after thirty years of excuses we know that most lifter failures are due to soft lifters.
FWIW
Go fast, see Elvis!
  #48
Old 01-25-2024, 10:05 AM
i82much's Avatar
i82much i82much is offline
i wiped a 327/300 cam in a chevy 350, around 1995. engine had been built in the mid-80's. every now and again a flat tappet loses a lobe, no getting around it ...
The Following User Says Thank You to i82much For This Useful Post:
  #49
Old 01-25-2024, 11:07 AM
Yup
  #50
Old 01-25-2024, 12:33 PM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
There are too many recent failure stories with flat tappet cams that you just can't ignore. I've seen this on cars owned by mechanics I personally know. Whether it is the chit overseas metal so many of these cams are made out of, and/or assembly issues, there are more failures of flat tappet cams reported today than ever before! Last year, one of the family members of Butler Performance sat for an interview with Smoke Signals. He claimed in their engine building service, they experience almost a 50% failure rate on flat tappet camshafts. Now since Butler is a renowned engine building company and known well by Pontiac enthusiasts, if that doesn't convince you something is horribly wrong with the modern flat tappet camshafts, nothing well....
The Following User Says Thank You to Ram Air IV Jack For This Useful Post:
  #51
Old 01-25-2024, 02:24 PM
I think people just like to complain more than ever before lol
  #52
Old 01-25-2024, 02:31 PM
Schurkey Schurkey is offline
"Bad luck"? No.
SOMETHING(S) are responsible. The problem is figuring out "what" the problem(s) are.
There's so many possible causes of failure that it's hard to count 'em all. And there may be some number of small issues combining to produce a failure that any one single issue wouldn't have caused.
We've mentioned metallurgy including the hardness of the cam lobe and lifter bottom. We've mentioned the surface finish of both parts--ground correctly, proper taper, appropriate spherical radius. Valve spring pressure--too high, or too low. Oil and additives including assembly lube. Oil system variables--windage trays reducing oil splash, grooves and holes in lifters or lifter bores to supply additional lube to the lobe/lifter bottom interface. There's a likelyhood of "modern" cams being more-succeptible to failure due to the higher-intensity lobes compared to mild lobes of years ago.
I don't remember talking in this thread about oil temperature, or OEM machining of lifter bores out-of-position. Chevy big-blocks are kinda infamous for having the lifter bores moved out of position due to sloppy machining at GM. There's a potential for harmonics in the various vibrations the valvetrain is subject to, to provide unexpected, instantaneous loading at a certain critical speed. On boosted engines especially, popping-open the exhaust valve against residual cylinder pressure can cause enormous stress on the valve, rocker, pushrod, lifter, and cam. I don't think we've talked much about sloppy assembly procedures leading to dust/dirt/sparrows/gravel being left in the engine during assembly, although we've discussed the debris created when the cam/lifter failed.
  #53
Old 01-25-2024, 02:38 PM
i82much's Avatar
Back in my day, wiping a cam was like wiping your butt ... everybody did it, most people didn't feel the need to talk about it in public ...
  #54
Old 01-25-2024, 03:45 PM
MrArt2u MrArt2u is offline
Holy Smoke Signals, someone from Butler saying almost 50% failure rate on flat tappet camshafts is eye popping.
  #55
Old 01-25-2024, 04:38 PM
PAUL K's Avatar
It's not really happening. Just a figment of the imagination.
Many shops will not build an engine using a flat tappet set up.... Shops maintain this policy "for a reason".
Go fast, see Elvis!
  #56
Old 01-25-2024, 07:44 PM
Formulas's Avatar
Formulas Formulas is offline
Ive got one to break in when it gets warm again, I put new but weak Erson 1.58 IH valve springs on my round port E'heads for break in, but it is a old school NOS 284281 crane cam Rhoads extra lube lifters @.600 lift with 1.65 Harlans
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
  #57
Old 01-26-2024, 04:15 AM
dataway's Avatar
I'd bet about 90% of those shop builds are 100+ hp over stock figures and using pretty aggressive cams.
The demands on HFT components have increased, while the materials used have remained static, a logical consequence would be more failures.
I'd think if it was a matter of no one making quality lifters then failures would be universal, they would all fail within a few thousand miles. If it was only certainly manufactures then that would have become evident almost immediately.
I suspect it's a combination of demands being made on geometry and components they were never designed to withstand ... and I have a feeling a lot of clapped out old equipment is being used to machine these components ... how much high quality HFT cam grinding equipment is being made now?
I think the tolerances for lobe taper and lifter crown are way looser than they were 50 years ago. You get a cam with taper 0.0005 off, and a lifter with crown 0.0005 too low and combine them ... failure no matter how hard the lifter.
There is no cam manufacture out there now pumping out millions of HFT cams for OEMs that require a minimum failure rate .... so the quality slides, the machines are not worth replacing, the market gets smaller and smaller ... all this leads to sloppiness.
  #58
Old 01-26-2024, 08:49 AM
Formulas's Avatar
"There is no cam manufacture out there now pumping out millions of HFT cams for OEMs that require a minimum failure rate .... so the quality slides, the machines are not worth replacing, the market gets smaller and smaller ... all this leads to sloppiness."
I agree sloppiness will also add offshore productions i put a higher value on new old stock components that were probably manufactured before the mayhem for instance there is a juicey SFT General Kinetics cam on ebay currently that i would consider if i needed one, Its alot harder to tell with lifters the last set i bought was Rhoads, they were newer but i know they would sweat the source and quality more than Autozone
  #59
Old 01-26-2024, 09:06 AM
P@blo's Avatar
HFT + 1.65:1=poor man's roller. HRT+1.5:1=rich man's FT.
Cats out of the bag on the roller stuff and I keep hearing "this new version solves the problems" but they never do. Also, a shop with a policy on my money is a NOGO.
Pay me now or pay me later either way I'm getting paid.
  #60
Old 01-26-2024, 09:54 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Yep. I remember, back in the 80`s, the piles of mostly stock sbc cams around many shops. It was well known back then but, I wonder about the situation today?
