Old 02-26-2024, 01:28 AM
Transamric's Avatar
I assume you removed the SoffSeal because it wasn't?
  #42
Old 02-26-2024, 06:48 AM
kencar62's Avatar
kencar62 kencar62 is offline
It was so tight my trunk wouldn't open. Being a solid profile vs. the Metro profile with air spaces, it wasn't compressing enough.
  #43
Old 03-04-2024, 05:10 PM
Transamric's Avatar
Time for an update/progress note. Decided to refinish the trunk gutter area due to many paint chips around the inner edge. Got a good paint match considering the rest is factory sprayed orig paint. Plus that gives me more time to mull over which weatherstrip I'm going to settle on. I make up my mind and then change it again. Now have a GM NOS strip coming that is not quite as tall as the later service replacement part I currently have.
Good input from all of you,...thanks!
Took these pics in a hurry just to show progress is being made. (Hard to take good pics of white & black with flash under fluorescent lights!)
Now on to the cleaning & restoring the taillights & installing the light harness (which is amazingly perfect).
Name:	'71 trunk prep #1.jpg
ID:	629835   Click image for larger version
Name:	'71 trunk prep #4.jpg
  #44
Old 04-27-2024, 04:59 PM
Transamric's Avatar
File this under "better late than never"! Finally posting some pics of the completed project on the trunk end of the '71 TA. Chose the Ames weatherstrip due to its being the closest in size/appearance to the original. It's a bit firmer than the latex coated GM part, but the lid still closes pretty well. No harsh slam needed, just a firm push.
Decided to use a repro mat even though my factory piece is intact. Just too worn looking to install with everything else being freshened.
BTW, criticisms welcomed for "incorrectness". We can talk about it.
Name:	71 TA trunk LH #1.jpg
ID:	632735   Click image for larger version
Name:	71 TA trunk RH #2.jpg
  #45
Old 04-27-2024, 05:02 PM
Rachelsdad's Avatar
I can't comment as to correctness, but it is certainly a beautiful job. Kudos.
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
  #46
Old 04-27-2024, 05:14 PM
grd777 grd777 is offline
i only want my doctor to be correct .looks great
  #47
Old 04-27-2024, 05:15 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Looks like it turned out well. i put my wife in the trunk for the water test....she's still my wife so i guess it went well lol jk
