#41
Yes, with proper backspacing it is possible to get 315s in a 17, or even an 18. In general, it requires an 11" wide wheel.
It gets tight in there, and most would be more comfortable rolling the lips. The more narrow a wheel is, the more the sidewall bulges, and a side load can make it contact the lip (not good at speed, will slice the sidewall). And more bulge allows the tire to roll more side to side. There is only so much space between the leaf and the lip, so even if you narrow the rear you are still limited. If you do strip launches, and make it soft (shocks & springs) for weight transfer, you have the same issue as with side load. Lower tire psi and the transfer will make the tire bulge more. When that happens is debatable, but you can't deny it won't. And raising the car has it's drawbacks too, as already mentioned. It a fine line to walk. .
#42
Nice car by the way, solid roof car too.
#43
looks sharp tho...trade offs galore
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#44
My friend with the 75 TA said a pic of his car is on the Robmcperformance website under custrides.
Cool! Sent from my moto g power 5G - 2023 using Tapatalk
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
#45
I will be swapping out the rear brakes with an Aerospace Components pro-street low profile kit. https://shop.aerospacecomponents.com...3-1-1-2-2.aspx Figured I’d share my experience
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#46
I pulled the Weld drag lites and measured the backspace. They appear to be a 15x8 4.5” BS. I also discovered the inner part of the 30x12.5 MT tire was rubbing against the tailpipes. If you are thinking of trying this tire size you may want to consider something a little smaller.
#47
New wheels and tires.
Top 30 of 300 at show. ![]() ![]() Sent from my moto g power 5G - 2023 using Tapatalk
| The Following User Says Thank You to thepontiacman For This Useful Post: | ||
#48
Looks sharp
#49
My TA has M/T DOTs 275-60-15 on ProStars 4.5 BS. They fit on a 8" "snowflake" that is about 4.5 BS also
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#50
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
