#41
I don't trust that particular glossary from PHS. They have had goofs before. 37R - 3.73 sounds more in line , and jives with the option restrictions. Bird and Goat have always shared the same axle designator suffix when they were the same ratio. |
#42
for 1970 there was both a code number and a UPC code used;
The code number was used on the order sheet; You should have a copy of the master order sheet if you purchased a PHS packet for your car; In the middle column-top is the engines section "34" - look there for the following:
| The Following User Says Thank You to unruhjonny For This Useful Post: | ||
#44
754 would most likely show on your invoice for Mountain Performance Axle.
Hard to recall because think I have only seen one or two of these cars with it. Usually a Colorado thing. There was an orange Formula several years back that the seller made a lot of wild claims about. I think it was a mountain car |
| The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
#45
In the chart I posted, it shows 3.31 and 3.36 gears.
The 3.31 is 12 bolt rear and the 3.36 is the 10 bolt I believe? Don't know if they had other ratios? (as the Mountain Perf option)
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
#46
Right-
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#47
is mountain gear a 10 bolt then not 12 bolt? I thought it was a 331 open but im.no expert
#48
I think if it has a 12 bolt in car it would be 3.31, if a 10 bolt it would be 3.36.
12 bolt only in 400 engine Birds.
#49
What is code 348 ram air 3 400 code mean? is that for trans am only? This is interesting stuff.
#50
It would be WS for manual or YZ for TH400. Used in Formula/Trans AM or GTO.
#51
I had a very early build 1971 Trans Am with a 3.07 12-bolt limited slip. It was an automatic a/c car. It was very original, I don't think it had ever been modified. The roof was damaged after a tree fell across the garage it was stored in during a hurricane. Both the carb and distributor were dated early July 1970.
| The Following User Says Thank You to poncho-mike For This Useful Post: | ||
#52
348 is on your PHS Invoice for your Formula , Nacho.
Maybe someone with good books can break down code 754 Mountain Perf Axle. I don't know how it applies or why it would have such a special name. But it wasn't available with Ram3 engines. Meaning the ratio was probably comparable to what those already came with as standard. |
