Old 04-29-2025, 11:44 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
It was refreshing to see that I am not the only 1 who thought the Milidon gear drive set up is a PITA!!!. I GET it but jeez. I recall back in 91 when I first build the 400 I bought, (previous owner installed the drive) degrreeing in the cam...awesome but not fun!
  #42
Old 04-29-2025, 03:08 PM
Dragncar Dragncar is offline
Pontiac did have ideas on a canted valve engine.
They made less than a dozen of them.
https://www.hotrod.com/features/expe...d-october-1970
Name:	Screenshot 2025-04-29 at 12-05-04 Experimental Pontiac 427ci V-8 Engine Deep Dive HOT ROD Magazi.jpg
ID:	650994   Click image for larger version
Name:	Screenshot 2025-04-29 at 12-09-11 Experimental Pontiac 427ci V-8 Engine Deep Dive HOT ROD Magazi.jpg
  #43
Old 04-29-2025, 09:51 PM
Nobuddy Nobuddy is offline
That is not a cant valve but a SOHC semi-hemi. Would be pretty cool if someone in the aftermarket was to do a modern version.
But I'm kinda weird, I wish someone would make a "Pontiac" RAIV style wedge head for the LS blocks.
  #44
Old 04-29-2025, 10:21 PM
Just because its a SOHC Hemi head does not mean the valves are not canted, they are.
They had a 2.40 intake valve and a 2" exhaust valve......think about that !!
  #45
Old 04-29-2025, 11:36 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
My 370 c.i. hemi Pontiac still has the Milodon gear drive I installed in 1986 (retired the engine in 2001 after many 9,000 rpm runs). Simple to install, then forget it.
The Following User Says Thank You to Jack Gifford For This Useful Post:
  #46
Old 04-30-2025, 04:59 AM
steve25 steve25 is offline
Kaufman makes a Hemi head that could be a great starting point for a SOHC motor, but in the world of boost and making over 2000 hp where you need to possibly tare the motor down in between runs a overhead Cam motor is a pain.
This is why non of the top fuel car run overhead cams.
  #47
Old 04-30-2025, 08:55 AM
I don't pay attention to the Pro classes any more but last I knew, NHRA rules forbid overhead cams in Top Fuel and Silly Cars.
Geared cam drive like most race engines have would make head change easier. Old Ford SOHC chain would be a nightmare.
  #48
Old 04-30-2025, 11:12 AM
BILL BOWMAN1's Avatar
The last time I remember an OHC motor was the McGee car, driven by Gary Beck in the late 80’s.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #49
Old 05-01-2025, 12:27 PM
RA462's Avatar
RA462 RA462 is offline
Checkout the gear drive on this Pontiac build.
https://www.youtube.com/watch?v=DvH6btEP3S0&t=77s
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
The Following User Says Thank You to RA462 For This Useful Post:
  #50
Old 05-01-2025, 01:10 PM
Stan Weiss's Avatar
Thanks.
I see in the comments that nothing has changed. There is GTO George telling them what is wrong and how to make it better. lmao
Stan
Pontiac Pump Gas List
  #51
Old 05-01-2025, 01:54 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Stan Weiss View Post
Thanks.
Stan
Too funny
Go fast, see Elvis!
  #52
Old 05-01-2025, 02:55 PM
Elarson's Avatar
Elarson Elarson is offline
Thanks.
Stan
He criticized the AllPontiac solid cast block. They performed flawlessly in the Boss Bird. How bad can it be??
LOL,
Eric
The Following User Says Thank You to Elarson For This Useful Post:
  #53
Old 05-01-2025, 05:36 PM
That is good stuff. For race engines with no passenger car legacy, check out the gear drives on an old Honda F1. At 6:00 for just the gears.
https://www.youtube.com/watch?v=vWwUhxcZyqI
The Following User Says Thank You to Nobuddy For This Useful Post:
  #54
Old 05-02-2025, 09:10 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
ELarson: preponderance of original architecture
"I have George Washington's axe. Replaced the handle six times, and the head five times, but its still the same axe." For more info, google the "Ship of Theseus paradox".
Clutch Guys Matter
_______________________________________
53 Studebaker, 400 pontiac
72 4-4-2 Mondello's VO Twister II
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
  #55
Old 05-02-2025, 09:35 AM
opeliac opeliac is offline
LOL,
Eric
Dont forget he has a blown race car that barely runs in the 7s...That should play a role when trying to evaluate his opinions.
  #56
Old 05-02-2025, 03:44 PM
It does not have a KRE billet block, so it must be bad ?
  #57
Old 05-02-2025, 07:47 PM
Thanks.
Stan
I surely don’t miss that D bag.
  #58
Old 05-04-2025, 04:40 PM
So watching some of Morris's vids its apparent he "hates" timing chains. Thus the reason he is going with Milodon gear drives on both of these builds.
But here in the real Pontiac world we rarely use them.
What do you guys think ?
Most of us just get a good chain. My last engine has billet caps and a 3/4" wide Morse chain was tighter than than a Rollermaster .004 short chain so I ran it. (cam needed to be straight up) For short chains the Rollermaster and Cloyes use the same chain, Iwis. You can get a Cloyes "Z" chain but only in standard.
Why the hate for chains ?
That guy is a good a builder as they get so his opinion is worth a lot.
The BOP belt drive is great and all but only for max effort deals. Is it possible to make us one that fits under a stock timing chain cover ? Or maybe use a Chevy water pump and some sort of bolt on cover for the front of our oil pans ?
  #59
Old 05-06-2025, 11:39 AM
bluegoat65 bluegoat65 is offline
See post #16 Dragncar. You decide from there.
  #60
Old 05-06-2025, 01:29 PM
Elarson's Avatar
Different strokes for different folks.
But the Cloyes timing chain was simple and awesome in the Boss Bird. It got way more abuse than normal:
valvesprings over 1000# open
exhaust valves opening against combustion pressure
driving a 26 gpm fuel pump
and driving an MSD 44 amp magneto (the magnets are so strong in these that you need an 8" wrench on the shaft to turn one "by hand")
FWIW,
Eric
