Old 09-16-2025, 12:23 PM
Tom Pugh Tom Pugh is offline
Originally Posted by GOAT8U2 View Post
As long as you are running a CS130 alt with single positive post and have the open hole for the external ground.
You can easily add an 8awg ground wire off the alt case. Pic 1
**My newer alt has the hole on the rear vs the side bracket like this Powermaster XS.
You can easily add a 6awg wire off the single alt positive post to the battery. Pic 2
You can now run any alternator and not worry about the wiring losses/efficiency.
I see. So you grounded it directly to the aluminum head and ran the charging lead directly to the positive post on the battery. Thanks
  #42
Old 09-16-2025, 12:26 PM
Originally Posted by KEN CROCIE View Post
Have you checked the pinion to flywheel clearance? Flywheels grow when they get hot.
I checked it cold when I installed the starter . But I don't think thats an issue because when it's hot I can easily start it by using my jumper box
  #43
Old 09-16-2025, 07:50 PM
Geoff Geoff is offline
Yes,
The flywheel grows when it gets hot. So does the block, on which the starter is mounted.
