Nice, Scott! Interesting the negligible hp/tq differences between headers and R.A.R.E. manifolds. Good stuff.
How far up into ME are you? Is your nearest track NE Speedway?
Mike '69 Midnight Green Judge 462 Ported 48s RAIII Exh Manifolds 4spd 3:73s |
| The Following User Says Thank You to RAIIIJudge For This Useful Post: | ||
Last time I was using standard ram air manifolds with 2.5” headpipes and I think it lost about 15 hp over headers . I was really surprised this time it only lost 4hp with the better manifolds and 3” pipes over headers.. It made the same 570 trq as it did last time but got a decent bump in hp. Peak rpms is now 200 rpms higher with the new HR cam.
The closest track to me is new Oxford dragway,about 50 miles. Looking at the 2019 dyno sheets it looks like it’s a little lower oil pressure this time. Maybe a 8 psi average lower now through out the pull. The mains are .0028 but the rod clearance is .0029,, last time it was like. .0023 rods. That might be causing the lower pressure. Idling today was around 19-20 psi at 800 rpm at temp.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' Last edited by scott70; 05-19-2026 at 04:11 PM. |
| The Following User Says Thank You to scott70 For This Useful Post: | ||
It now has a Cloyes double roller racing Z timing chain. Whats does the Z add over the standard racing double roller?
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
What oil viscosity?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Nice! Good job
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
Not bad for a junky old quadrajet,,, or so I’m told.
That’s a great build!! Congrats
| The Following User Says Thank You to grivera For This Useful Post: | ||
Looking at the 2 dyno sheets it looks like switching to the manifolds and pipes richend up the air fuel ratio some.
That may indicate there was a little more power left on the header test with some tuning. Probably not much though, 510HP with RA manifolds is really getting it done. Makes me want to try a set of those RA manifolds with the 3” outlets.
Yeah they call these 2.5”outlets but actually they’re a little smaller than that. Rare then adapts a 2.5” end to a 3” pipe. I run those into a 3” x pipe system with 2.5” mufflers and tailpipes.
A little shocked the headers were not worth more. On my 455 dyno yesterday the Tri Y headers lost a lot to the 2" and my cam was kind of close, bigger heads and intake runners though.
I had issues with my RARE 2.5 manifolds sealing at the head pipes on the 81 car. It is getting the 455 dynoed yesterday in place of the mild 400.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
The headers were 1 3/4 hooker super comp the engine shop has.
Do the 3" headpipes use different manifold flange adapters than a 2.5"?
I believe what he did was use the very beginning of a 2.5” pipe with flare, maybe 2” and then welded that onto a 3” mandrel bent head pipe. So the very beginning is necked down but the rest is all 3” . Not ideal I guess compared to 3” the whole way. I believe it’s the same flange as a standard 2.5”. Like I said they call these oversized but comparing the ID of these compared to my other standard aftermarket manifolds there wasn’t much of a upsize but there is some.
I was wondering what the difference was with the R.A.R.E. OS manifolds but the webpage is gone now. I wonder how they compare to the new Ames 2.5” outlet versions?
1972 GTO |
Maybe can get the old page using the wayback machine?
I asked today for some valve spring specs from the engine builder. Using my previous 995 comp springs they were shimmed to a height of 1.685 which resulted a 130 lb closed and 370 open pressure.
Did a 3/4 turn on the comp evolution which was .063 preload. Piston to valve clearance was .185 I asked about shimming the springs a little more but he said he really didnt want anymore than the 370 open pressure. Peak HP on the dyno was 5400 with the 236/244 .580 HR cam.
Got the engine home today, they had to replace a rear main seal and pan gasket from a leak on the Dino ,ran it for a a total of a couple of hours on the Dino. Don’t see any leaks so that’s good. Here’s the old bearings that came out of it from the 2019 rebuild. I was hoping they’d look a little better.. The engine doesn’t get babied
Looks like a cast steel 455 crank with full groove bearings. Do you have a bearing part number?
Congrats on the new progress as well Scott. Last edited by P@blo; 06-09-2026 at 09:34 PM. |
