Old 01-21-2013, 08:41 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
That is going to be another one of those A$z entry first, deals where you put your legs inside the cage first, bend over, kiss your a$z, then sit down in the seat types of things. Good thing Drag Racing does not have a rule like the SCCA where you have to be able to exit the vehicle in so many seconds.
Tom Vaught
I picked up a book on yoga. Now as for the "bending over and kissing", I do remember bending over, but I don’t recall being kissed.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #582
Old 01-22-2013, 02:55 AM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
If your steering wheel is removable I think you'll be ok. That car will be low enough that you should be able to step right in.
I angled my cage back just a touch and I cant remove my stock steering wheel. Im 280 and can pop right in. But I need the window down in the door to get out. I dont have anything to hang onto when I pull myself out.
The worst thing I had to overcome was turning the damn master switch on before I get in the car!
Looks good! But when its 100 degrees out you'll wish you had a 8.50 car with a swing out door bar!! LOL
Name:	Chassis 103 edited1.jpg
  #583
Old 01-23-2013, 07:36 PM
RAIV-Z's Avatar
The steering wheel will be removable and I’m going to try to keep my weight under control. Can you get a wireless remote for the master switch?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #584
Old 01-23-2013, 10:41 PM
A remote activation could be done with remote door lock solenoid(s) as long as its setup to allow the manual kill to work as intended.
  #585
Old 01-23-2013, 10:55 PM
lemans411's Avatar
lemans411 lemans411 is offline
guys from around here run a morse style cable . push pull deal to run the switch from inside via a chute lever or similar. pretty trick my next car will have this. how many times do you crawl in the car and realize the switch is off... too many lol
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #586
Old 01-24-2013, 04:58 PM
RAIV-Z's Avatar
Mechanical sounds like the best way to go.
I wouldn’t want unintentional interference to cause flakey issues and I don’t think spectators would be willing to turn off their cell phone and other electronic devices once I close the door…
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #587
Old 01-25-2013, 12:38 AM
lemans411's Avatar
Yea pretty simple setup but works flawlessly.
-Rob
68 gto
  #588
Old 01-26-2013, 04:09 PM
RAIV-Z's Avatar
Default RA-V Engine Disassembly
What’s up with piston #2?
ID:	311091   Click image for larger version
ID:	311092   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #589
Old 01-26-2013, 04:56 PM
RAIV-Z's Avatar
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #590
Old 01-26-2013, 06:02 PM
mysticmissle's Avatar
How about a pic of the chambers. What's it look like to you (in person)?
  #591
Old 01-26-2013, 06:47 PM
RAIV-Z's Avatar
Looks like casting porosity, then someone hit it with a grinder. I'll get a better picture of that one chamber. The combustion chamber does look ok though.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #592
Old 01-26-2013, 06:51 PM
Porosity in the piston? Highly unlikely it's definately a forging. Does it line up with spark plug hole? Looks like effects of a piston stop from degreeing cam. Not sure why other side would have sanding marks. Is that what it is?
  #593
Old 01-26-2013, 06:53 PM
Tom Vaught's Avatar
Boost Engineer
"Casting Porosity" on a Forged Piston? I do not think that should be the case with any quality Forged Piston. I guarantee that you would not see that deal on a CP Forged Piston.
Tom Vaught
  #594
Old 01-26-2013, 07:12 PM
RAIV-Z's Avatar
My mistake, I think you're right about the cause of the marks, not sure why there are 4 of them though. Those are sanding marks. I would have expected this done on #1, not #2.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #595
Old 01-26-2013, 07:18 PM
73 TRANSAM 73 TRANSAM is offline
It looks like a piston stop mark but why would you use a set screw that is pointy to dig a hole in the piston two holes instead of one? You figure one is a Goof but two!To all the money you spent on that engine build, everything should be spotless. It looks like you are finding stuff that is usually fine turns out bad. I hope this is the last bad thing you will find on it. I would remove the rods, crank and inspect the bearings if I were you. I would strip that block and inspect everything before putting it in your car. Goodluck on your build, looking forward of a happy ending.
  #596
Old 01-26-2013, 07:19 PM
RAIV-Z's Avatar
More disassembly pics.
ID:	311115   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #597
Old 01-27-2013, 08:37 PM
RAIV-Z's Avatar
Default Can you see what’s wrong in this picture?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #598
Old 01-27-2013, 08:43 PM
Tom Vaught's Avatar
Boost Engineer
Looks to me like the ARP L19 fastener does not sit flat on the connecting rod pad.
Diameter of the fastener is larger vs the rod pad surface diameter.
Tom Vaught
  #599
Old 01-27-2013, 08:47 PM
RAIV-Z's Avatar
Tom Vaught
All the rod bolts looked ok, that might just be the angle of the picture. All the rod bearing look great to.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #600
Old 01-27-2013, 08:50 PM
Tom Vaught's Avatar
Boost Engineer
Camera Angle deal, looked like the bolts were touching the pocket closest to the beam of the rod.
Tom Vaught
