#581
Napa gold oil filter.
![]() Sent from my SM-G955U using Tapatalk |
#582
That's the brand and style I use on the vast majority of the cars I service and race. This includes the nitro funny car, (NAPA/WIX racing filters) IMO, the filter isn't a problem, a junk distributor shedding metal at a faster rate than the filter can trap all the debris, is.
#584
Can't necessarily blame an oil filter if the bypass isn't blocked. If the bypass is left open, which in some cases shops prefer to do this if they are uncertain the owner will frequently change the oil, then there is quite a bit of oil that doesn't pass through the filter in various running conditions.
Nothing wrong with the Napa Gold filters, same as Wix. Good quality filter. |
#585
promptcritical,
Hahaha..I'm not going down that path. mgarblik, This filter was suggested by a lot of guys here. That's why I went with it. I've tried googling problems with this distributor and didn't see much of the same problem. Of course I'm pretty new to cars and I certainly don't have the experience or knowledge to even have a thought on this. I know I'm learning a lot though! Formulajones, I don't know about the bypass. I know I've changed the oil 3 times with less than 200 miles. |
#586
NAPA gold is a 20 micron filter and is 50% efficient at a single pass, so 1 out of 2, 20 micron particles are caught with first pass. Typical of a full flow filter and blocking the bypass valve doesn't make the media any more efficient. It's still only going to catch 1 out of 2, 20 micron particles at the first pass. The other particle is going to make more circuits in the oil system. Anything under 20 microns will circulate indefinitely until the oil is drained.
The majority of engine wear is caused by 5-10 micron particles which are free to roam with any full flow filters, and are only removed most times when oil is changed. Just keeping the facts straight here. A by pass filter removes 100% particulate to 2 microns the first pass, I really have no idea if it would have saved the wear parts in this instance, but it at least would have a fighting chance as 100% of the oil runs through it every 5 minutes, even with the bushing deteriorating it would still only circulate in the engine for 5 minutes, not indefinitely. After close to 50 years in the automotive field I have never seen this problem arise with a distributor bushing failing. Paul and Jeff in my estimation have gone over and above to stand behind their work, even though it was no fault of their own. This is how a business is judged when the job has a failure and they stand behind it, even though any profit they made initially was eaten up, they still hung in there until the problem was solved. This is exactly the formula that separates a good business from a great business. Business ethics like this are tough to find today and refreshing to see someone still has the foresight to keep their reputation intact because they intend to be around for many years. Glad the problem has been solved, and the owner is going to be able to put some miles on his car this year. Good job to all who got their hands dirty trying to solve this elusive noise, I know you did it for the brotherhood of Pontiac owners out there.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated ![]() ![]() ![]()
#587
I run the Nappa Gold filter for a early 60s big car in my 69 GTO. Its longer so it has more capacity and filter area. Fits with my Hooker round port headers.
That said, its a fine filter for what it is. I know of no one who has run a 455 as long as I have and as hard as I have and never hurt a thing. But, if you want problems plug the by pass. foolish. You are asking a filter to do more than it can. It would take more than 2 filters set up to get it all under every engine condition. Pontiac engineers were not stupid. Seen too many guys have problems with plugged by pass with just a standard sized filter screwed on. Don't care what they say the filter flows. Know of guys who blew those big long tall deck BBC filters off too. Most of us drag race and oil never really gets dirty before its changed. |
#589
What's funny is the new MSD distributors come with a warning tag attached to them that says to block the oil filter bypass. I've been doing it for for over 20 years on engines I feel the customer will change the oil and filter on regularly. I have never had a bearing issue or any other issue from doing so. I do see a lot of scratched up bearings in engines running the bypass though.
#591
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#593
The point of my post was missed. I'm not surprised that would turn into a "to do or not to do" LOL
The point was that we can't blame a filter for catching everything if the bypass is open. There is oil that isn't being filtered AT ALL. Plain and simple. Doesn't matter how good the filter is with an open bypass. |
#594
The oil filter already has a By Pass built in. So blocking the one in the oil filter housing, is OK. The oil will get where it needs to be.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#595
mgarblik,
I think Paul would agree that I have been appreciative and understanding. I've never posted one negative thing on this forum. It's been a long, bumpy road to get to this point with a lot of up and downs. We just need to get through this so I can enjoy this motor and Paul and Jeff can get that motor out of the shop so they don't have to deal with it anymore. |
#596
I have no reason to doubt anything you say concerning your last post. I have been following this from the beginning and look forward to a happy end to the saga. Good luck with your car and engine. Summer is coming. Get some enjoyment out of it.
#597
This new engine is filled halfway up the pump holes so it will need synthetic. I plan on running Amsoil 20-50 in it. Right now I am thinking about plugging my by pass and going with that 150$ K&P screen type that is cleanable. The flow rate is huge and they make them with or without a bypass built it. I would think that if you plugged your by pass and ran the K&P with its own by pass it should not make it to that mode very often. Thats the plan right now. |
#598
Very easily could have oil starvation or media blown through with the wrong filter. |
#599
Full flow oil filters speced for a Pontiac Stratostreak V8 do not have internal by pass valves. The one in the oil filter elbow is the only safeguard in the oil system. Blocking that safeguard allows no bypass whatsoever. If the filter cannot handle full flow at high RPM is will do one of three things, leak externally at the sealing O ring, blow the canister out rupturing it, or collapse the filter media internally, possibly ripping holes in it. Unless you cut open each filter you'll never know if it collapsed the media rupturing it, rendering the filter in by pass mode 100% of the time. If the system overpressures the oil filter it will find the weakest link.
Smokey Yunick calculated that a SBC would need 4, 12 inch long full flow filters at full RPM to filter all the oil pumped through the engine. Anyone here with a blocked by pass have anywhere near that filter capacity? There are much safer ways to filter the oil to a higher standard than any full flow filter or combination of multiple full flow filters do, usually on PY this all falls on deaf ears, as I expect it will currently....
#600
Yeah we know. I don't think it falls on deaf ears, at least not some of us. But as much as I like what a by pass filter does and how well they work, (trust me, I'm an Amsoil user and they really push those filtration systems) most of us can't or won't put them on these classic cars. They either can't be fitted neatly and/or hidden on some cars where you don't want to look at something like that on a nicely restored car.
So we have to resort to frequent changes and try to keep things as clean as possible. |
| Closed Thread |
