Old 01-27-2013, 09:28 PM
johnta1 johnta1 is online now
What rods are those?
Is that cap all the way down?
(tight?)
  #602
Old 01-27-2013, 09:36 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is online now
(tight?)
They are callies ultra. The caps were all tight.
Here is a better picture. The other one was a little dark.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #603
Old 01-27-2013, 09:53 PM
Tom Vaught's Avatar
Boost Engineer
I looked at the better picture, How much side clearance do you have with the rods right now? Put a feeler gage between the 2 caps and give me a number, please.
Tom Vaught
  #604
Old 01-27-2013, 10:16 PM
RAIV-Z's Avatar
Tom Vaught
All rod clearances matched the build sheet .018 to .020.
Hint: The front of the engine is to the right.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #605
Old 01-27-2013, 10:27 PM
Travis Q Travis Q is offline
#2 rod's in the #1 hole.
  #606
Old 01-27-2013, 10:34 PM
Was the piston installed with the correct orientation to be #1?
  #607
Old 01-27-2013, 10:37 PM
RAIV-Z's Avatar
You got it.
1,2,3, and 4 were in the wrong holes.
5-6-7-8 were correct.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #608
Old 01-27-2013, 11:44 PM
rodneybutler's Avatar
rodneybutler rodneybutler is offline
I see a few engines come through the shop labeled that way done by chevy builders. Label the front rod as no 1. It shouldn't matter if they are all the same size.
  #609
Old 01-28-2013, 07:50 PM
RAIV-Z's Avatar
I would have expected if the first 4 banks were swapped the last 4 would have been as well.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #610
Old 01-28-2013, 11:11 PM
Tom Vaught's Avatar
Boost Engineer
If we go thru each rod, step by step, Ed.
On a Chebby the Front Cylinder on the driver's side bank is closest to the front bumper of the car (or Crank Snout/Balancer for reference point). This cylinder is called #1
On a Pontiac, the Front Cylinder on the passenger side bank is closest to the front bumper of the car (or Crank Snout/Balancer for reference point). Pontiac guys call this cylinder #2 but the rod closest to the snout/balancer is normally called the #1 cylinder.
Pontiac followed the spark plug wiring cylinder numbering but not the actual front most cylinder "naming convention".
So the guy initially numbered the rods and installed them like a Chebby.
Big Chamfer in the rod to the front on the #1 rod and Big Chamfer to the rear on the #2 Rod. So in order for the rods to be in the right spots for the chamfers on the Pontiac crank the Chebby #1 rod (Chamfer to the front) was moved to the Pontiac #2 cylinder. The #2 Chebby rod (chamfer to the rear) was moved to the Pontiac #1 cylinder.
So that takes care of the first two cylinders.
Same deal happens with the #3 and #4 Cylinders (they had to be swapped side for side to be in the right locations on the Pontiac crank (chamfer wise).
So about half way thru installing the rods and pistons apparently the guy noticed that the rods were not right and puts #6 & #8 in correctly and puts #5 & #7 in correctly in the block in relation to the chamfers on the crank and the rod location on the crank (front or rear position on each rod journal).
Hope that makes sense.
Tom Vaught
  #611
Old 01-28-2013, 11:51 PM
RAIV-Z's Avatar
Tom Vaught
Makes sense, although I would have expected a little more attention to detail from a shop like BES regardless of what the engine cost to build. I’ve had a few milder engines built locally and have never run into issues like this. What makes issues like this look worse than what they might really be is when someone screws up and doesn’t mention anything. A simple note on the blueprint sheet indicating rods numbering/placement in the block would have sufficed.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #612
Old 01-29-2013, 12:02 AM
RAIV-Z's Avatar
Default Who else has used this IA-II Main oiling mod?
Just curious to see if anyone else has had this done to their block and what the results were or if there are any other mods which should be considered while the engine is apart.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #613
Old 01-29-2013, 01:20 AM
blueghoast's Avatar
I have seen that done before, You have to drill some
holes in the slot of the bearings too to get any advantage
from the slot in the block under the bearing.
GT.
  #614
Old 01-30-2013, 12:05 AM
rod cole rod cole is offline
The numbering is not a big deal as long as the wide chamfer faces the crank weight. But on another note WHOLE E BAT POOP that engine is a disgrace to even a rebuilder much less a race engine. You good sir deserve a award for not at least maming someone. Rod
  #615
Old 01-30-2013, 09:46 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Mine are this way. Just not as deep as yours I would say.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #616
Old 01-30-2013, 02:31 PM
RAIV-Z's Avatar
Did you modify the main bearings in any other way besides adding another oil hole?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #617
Old 01-30-2013, 05:43 PM
Tom Vaught's Avatar
Boost Engineer
I could see where this would be a great mod on a Supercharged Engine with a high belt load. I do not understand what value it would be on a turbo motor as the front main has very little extra load under boost vs a belt driven boosted device.
Tom Vaught
  #618
Old 01-30-2013, 06:57 PM
RAIV-Z's Avatar
Tom Vaught
This mod was done to all the mains.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #619
Old 01-30-2013, 09:32 PM
RAIV-Z's Avatar
Who performed the machine work on your block and did your main bearing look anything like this?
This engine has only had a few NA dyno pulls.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #620
Old 01-30-2013, 10:48 PM
Marty Palbykin Marty Palbykin is offline
[QUOTE=RAIV-Z;4842287]Just curious to see if anyone else has had this done to their block and what the results were or if there are any other mods which should be considered while the engine is apart.
My question would be why !!!!
If you have good pressure this has never be a problem in my experience.
This may be a good procedure but I do not think it is really necessary under 1600 hp.
Marty P.
