Old 11-19-2021, 07:39 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Man that’s great ! Good luck and have a great time .
When I wore a younger man's clothes
  #602
Old 11-20-2021, 11:01 AM
64speed's Avatar
64speed 64speed is offline
And we’re on the way home
ID:	578178   Click image for larger version
ID:	578179   Click image for larger version
ID:	578180   Click image for larger version
ID:	578181   Click image for larger version
The Following User Says Thank You to 64speed For This Useful Post:
  #603
Old 11-20-2021, 02:07 PM
gtospieg gtospieg is offline
I'm glad to hear it...now if someone could just fix the pics please.
  #604
Old 11-20-2021, 02:23 PM
misterp266's Avatar
No problem . . . .
Car came out awesome BTW!
ID:	578217   Click image for larger version
ID:	578218   Click image for larger version
ID:	578219   Click image for larger version
ID:	578220   Click image for larger version
" Darksiders Rule "
The Following 4 Users Say Thank You to misterp266 For This Useful Post:
  #605
Old 11-27-2021, 05:59 PM
64speed's Avatar
Got her in and only scratched the firewall in a place you can’t see so I call success
  #606
Old 11-27-2021, 08:49 PM
EVERYTHING really looks Fantastic
One helluva car you have built.
  #607
Old 11-27-2021, 09:14 PM
grivera's Avatar
grivera grivera is offline
looks awesome!!
Will Rivera
  #608
Old 12-07-2021, 07:19 PM
64speed's Avatar
Well I’ve always known my Tempest had a hard life but it’s apparently had at least 3 different length transmissions in it in its life. I mounted my crossmember today and and had to drill a FOURTH set of holes. I’m really not pleased about that but it is what it is. I used good grade 8 bolts and washers with blue loctite. It’s ugly but you can’t see it so I guess its ok.
  #609
Old 12-07-2021, 07:28 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
You're nailing it for sure!
  #610
Old 12-09-2021, 08:20 PM
64speed's Avatar
Just in case you were wondering there is pros and cons to using M&H harnesses. Pro...they are plug and play and very easy to follow, Con...they are almost impossible to hide. They follow factory routing so my hopes for a totally wireless engine bay are dashed. Oh well it does not look bad they are just visible.
  #611
Old 12-10-2021, 09:16 PM
64speed's Avatar
I know it was a GTO option only but I am putting the engine turned insert around the gauges in my dash because it just looks a lot better. All that black needs some lightening up
  #612
Old 12-10-2021, 11:09 PM
Tom Vaught's Avatar
Boost Engineer
Some of the cars had A WOODGRAIN INSERT OVER THE SWIRL GTO DASH PLATE.
You could install a 65 Woodgrain dash piece and it would be unique like the very few
woodgrain dash inserts that I have seen over the years. The first woodgrain over the
swirl dash was a April Built car.
Tom V.
  #613
Old 12-11-2021, 10:02 AM
HWYSTR455's Avatar
More pics please! Like seeing progress!
  #614
Old 12-12-2021, 04:40 PM
geeteeohguy's Avatar
No Worries. Your car is a custom and the engine turned dash looks great. You didn't install an LS engine, so you you have a ton of artistic license you can use with your car! LOL...
Jeff
  #615
Old 12-13-2021, 02:23 AM
64speed's Avatar
I have tried everything but I can’t get my pictures to turn out. Nothing sexy or exciting going on here right now just wiring and doing little tedious details like getting sanding dust out of…well everywhere 😂. That radio has been completely gutted, rechromed, and all apple car play features except the screen obviously added including Bluetooth, no wires to dash but charging cable if needed. Now to hide the mic!
ID:	579558   Click image for larger version
ID:	579559   Click image for larger version
  #616
Old 12-13-2021, 02:44 AM
Old Goat 67's Avatar
I'm betting you have a Apple phone.
ID:	579561   Click image for larger version
ID:	579562   Click image for larger version
  #617
Old 12-13-2021, 02:51 AM
Wouldn't it be easier to connect the harness wires to the cluster on the bench and then put the cluster in?
Easier and less chance of scratching things up or getting something connected wrong while hanging yourself upside down?
  #618
Old 12-13-2021, 02:54 AM
One more...
  #619
Old 12-13-2021, 03:06 AM
64speed's Avatar
I suppose you could do that but I have help at the present time to hold stuff so this just seemed easier. I have installed the tach etc before in another 64 I had years ago and this is how I did it. I don’t know which would be easier, this is just the way my brain works, plus I was able to mount the fuse box then snake the wires up behind the pedals etc. seems like a pain in the ass to get that fuse box down from the top
  #620
Old 12-14-2021, 09:13 PM
64speed's Avatar
I am gonna admit a fault. I got a little too ambitious. I wanted to have the perfect car for me and I am on my way to that but this is a lot of **** to wire up. The Detroit speed wiper setup required a HUGE hole in the firewall that I was able to hide BUT I can’t hide the wiring or the huge motor. Getting a little crowded under here.
