Old 09-11-2020, 10:34 PM
I couple I took this summer, a full rainbow over Toledo Ohio, and my Coupe in the UP of Michigan
ID:	549288   Click image for larger version
  #642
Old 09-20-2020, 11:11 AM
455firebird1969's Avatar
I traded my Challenger for a new EcoDiesel JLU Wrangler Jeep.
This 3.0 turbo diesel engine makes 442 torque at 1400 RPM, it’s a powerful little engine.
  #643
Old 09-20-2020, 01:31 PM
PontiacJim1959 PontiacJim1959 is offline
My brother owns 2 railroads, one is a commercial switching yard, the other a tourist/dinner car. I just made a visit to hang with him for a vacation and we took his Ford truck with its "hi-rail" gear out for a spin on the tracks.
We went north on his tourist line which goes 7 miles out from where we started. The first pic is his truck. Second pic -We had to wait for the "rail explorers," peddle cars, to zip by before we set the truck down on the rails. Third pic is traveling down the tracks, they run along the bay and is the scenic route the dinner train excursion takes. Pic 4 is the end of the line. There used to be a bridge, but it was taken down, so the tracks end at water's edge. The tracks are raised up fairly high so you can look down at a cove/beach area on the left and a marina on the right. We tailgated our dinner and hung out for a while.
The adventure began when we had to back down the tracks as no place to turn around. Sun had set and was getting dark, so on came the lights - at least for a while until the rear spot lights went out for no reason. But, no issues going back until we got near the terminal yard. They are installing a new switch track and siding, which was not yet completed. Going backward, we hit a rail that was higher than the on we were on. The small wheels of the "hi-rail" jumped the track and our truck tires came off the rails, dropping down on the railroad ties. The hi-rail system got a little tweaked. The idea was to get the truck tires back on the rails again, but first we had to get the hi-rail system up. It was bent & jammed and it took a little effort to get it lifted up. Next step is to block the truck tires so you can drive forward onto blocks, like stairs, and get back onto the rails, then drop the hi-rail.
It's now night, and dark. Being right at the edge of the terminal yard, we could not drive off the tracks with the Ford in 4-wheel drive due to our location and the terrain at that point. So using my brother's phone as a light, we drug up boards & flat concrete blocks, put them under the tires, pulled up on one level, then built the next level, and so on - just like stairs. The truck did not want to cooperate and go straight onto the tracks. So out came a railroad jack and we jacked up the rear bumper and lifted the tires up higher than the rails, and I gave a shove to topple the jack sideways, sliding the truck tires over just a few inches. Did this 3 times and the tires were now on the rails. Then we dropped the hi-rail back down on the tracks, locked them into place, an began back down the track. Took us about 1 1/2 hours - mind you this is my vacation.
We did not go 50 feet and the truck jumped the track again at a loose switch track which was part of the track work. So we drag our "stairs" from 50 feet away and proceed to do again what we just did to get the truck on the rails. Again, truck tires just would not get on the track enough to drop the hi-rail even though we did get the tires on the track. My brother said he had had it and we were in a place where he decided to 4-wheel it up and over the tracks and down a mild drainage ditch. The truck sits high enough it clears the train tracks and the engine/trans is tucked up high in the frame so no issues with taking off an oil/transmission pan. So he eased the truck up over the track at a time and off to the shoulder. I checked all the tires for any damages, got in the truck, and we drove off to go to his house. It was another adventure & memory with my brother.
ID:	549975   Click image for larger version
ID:	549976   Click image for larger version
ID:	549977   Click image for larger version
  #644
Old 09-21-2020, 03:38 AM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Decent weekend at "Castle Point" on the East coat of NZ, about 1. 5 hours from home
ID:	550033   Click image for larger version
ID:	550034   Click image for larger version
ID:	550035   Click image for larger version
ID:	550036   Click image for larger version
Working on going faster (and now staying dry at the same time !!)
  #645
Old 09-21-2020, 03:40 AM
455-4+1's Avatar
It's a small fishing village and camping destination
  #646
Old 09-21-2020, 09:17 PM
Old Man Taylor's Avatar
A local car show yesterday.
  #647
Old 09-23-2020, 05:36 PM
Another beautiful day. It's been like this for two weeks straight Temperature in the mid-seventies you don't feel hot or cold. I've been driving her every day to work and back. And everywhere on the weekend. Rang up the odometer a couple thousand miles, for a grand total of 44,500 or so. .
Name:	Nice day 9 23 20.jpg
  #648
Old 09-23-2020, 07:22 PM
Shiny Shiny is offline
Originally Posted by 66sprint6 View Post
...I've been driving her every day to work and back. ....
That's a great photo for me as the contrast with modern vehicles is strong. At a glance I can easily see your Pontiac is not a Buick or Chevy but I'd be hard-pressed to tell you the brand of any of the others without an effort.
That's awesome you can enjoy driving it everyday.
  #649
Old 09-23-2020, 07:34 PM
shuffster shuffster is offline
Default 36 Ford pickup
Bought it in 1966 while in high school. Painted in 1972. Has SBC, T350, Ps, Disc brakes. Driven regularly
Shuffster
1965 GTO
The Following User Says Thank You to shuffster For This Useful Post:
  #650
Old 09-23-2020, 08:40 PM
Originally Posted by LStathas View Post
The Pics don't do it justice. It was breathtaking! I thought they were cool nonetheless.
There was a song about Red Skies in the 90's
Never knew they were talking about something real.
That is Wild
  #651
Old 09-23-2020, 08:59 PM
...It was another adventure & memory with my brother.
Cool episode.
The rail running pick-up trucks around here are much different.
Always wanted to ride the rails in one of them.
  #652
Old 09-23-2020, 09:01 PM
Those boat trailers are awesome.
Bionic versions of what we use around here at the lakes.
  #653
Old 09-23-2020, 09:02 PM
67drake's Avatar
67drake 67drake is offline
I’m jealous!
‘55 Catalina
  #654
Old 09-28-2020, 05:38 AM
455-4+1's Avatar
Yep it's a pretty cool spot, on very savage coastline, the boats launch from the sandy inlet, then head out through the swell in a gap in the cliffs, coming back in with a following sea is a real eye opener. Certainly not for the feint hearted.
The Following User Says Thank You to 455-4+1 For This Useful Post:
  #655
Old 09-28-2020, 07:05 PM
Denton Farm Park, Denton, NC. Annual Threshers 50th Reunion, July 2020.
This is a 5 day event which has a large camping area for campers which attracts people from various states who show their tractors, steam engines, hit & miss engines, and engage in the tractor pulls. They have food vendors, a flea market area, a stage with assorted bands that play during the day, a train that travels the perimeter with an "old west" show, various demonstrations of both steam and horse powered farm equipment, a steam powered machine shop, a building housing a number of live steam powered engines used in industry, historic buildings, and more.
My second year here. Last year was really packed and had more equipment on display, but the turnout was still good in spite of the virus. I went 2-days. They had the General Lee from Dukes of Hazard on display and you could walk right up and take a look and get a picture. I enjoyed the demonstration of the stem shovel and steam crane - both fully operational and built about 1910.
Just a few of the pics I took, but I got a ton of them. Tractors of all makes and years from lawn tractors to the big farm tractors - steam, gas, kerosene, and diesel. These guys put as much effort into restoring their tractors as we do our cars. I'll be there again next year.
ID:	550509   Click image for larger version
ID:	550510   Click image for larger version
ID:	550511   Click image for larger version
ID:	550512   Click image for larger version
  #656
Old 09-29-2020, 01:35 AM
Will Will is offline
Went to one of my favorite places. No one there but me and my dog, no sounds but the wind, water, and the occasional bird.
  #657
Old 09-29-2020, 08:45 AM
Denton Farm Park is a really cool place. Privately owned.
Its amazing to me the extent he went in building the place and providing all the camping provisions with electrical hook-ups and all in shaded areas. Bath houses, etc ...
It's only used a few times a year that i know of.
For a long time it was just for the Threshers
They do an Antique Motorcycle event, and Christian Outreach event.
  #658
Old 09-29-2020, 11:12 AM
Aspen season... this is a quarry yard in Marble
  #659
Old 09-29-2020, 12:03 PM
OG68 OG68 is offline
Grand Tetons from Jackson Lake Wyoming
ID:	550558   Click image for larger version
Old 09-29-2020, 12:13 PM
Bison crossing the road at Jackson Lake
He actually stopped and looked both ways before crossing.
Big! His shoulders were as high as the hood of my truck.
ID:	550560   Click image for larger version
