Closed Thread
Old 06-24-2019, 12:09 PM
Va68goat's Avatar
Va68goat Va68goat is offline
Yes, thats correct Formulajones. My question is about the oil temperature. What does that mean?
  #642
Old 06-24-2019, 12:35 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Since the engine was full of oil, the guy setting up the engine didn't install the oil temp probe. It has to go into the drain plug hole.
First dyno pull was with one of Jeffs carbs built for another guys engine. This second dyno sheet was with the carb Jeff built specifically for this engine. First dyno was in the fall when temps were cool. Last pulls were done in the heat of summer.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #643
Old 06-24-2019, 12:39 PM
Default Nutshell?
So in a nutshell, from what I understand, in the last dyno session, they were able to use the carb that Jeff built specifically for your combo.
In a nutshell the OP doesn't know how much torque or HP the engine originally made "as delivered". Paul never shared that info. He did post that it made 517 HP, with the 870, "BEFORE" it got jetted up. Can't read numbers in the you tube vid after jetting. Only dyno printout the OP got was what the engine was "capable of" with a Jeff carb.
What it can do VS. what you've got didn't make any sense back then and still doesn't to me. You'ld think what the customer paid for would be more important.
Sheets posted now show power is down (way down in some areas) with the new Jeff carb compared to the first Jeff carb. That tells me the new "specifically for your combo" carb isn't doing what it was suppose to do.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
  #644
Old 06-24-2019, 12:50 PM
I don't understand that. When numbers are "lower" on a thermometer here in GA it means temps are cooler. Old dyno sheet shows 85°F and the new one shows 83°F. Baro close enuff but it was less humid this time.
IDK
Clay
  #645
Old 06-24-2019, 01:42 PM
Va68goat's Avatar
Maybe there was a mix up at the dyno shop. On the most recent dyno sheet he listed my carburetor as an "850 Brawler" but it should have been dyno'd with Jeff's carb. Me not knowing about cars I googled "850 cfm Brawler carburetor" and this came up. Maybe it was dyno'd with an 850 Brawler by accident. My name is on the 2nd dyno sheet as well!
https://www.holley.com/products/fuel...parts/BR-67201
- He may have to think of nicknames for carburetors that aren't really carburetors.
I noticed that the date of the 2nd dyno said October of 2018. My motor was in Virginia at that time. I spoke to the dyno guy this weekend and he said the battery for his computer that keeps the date and time must have been dead but the rest of the computer was able to produce the readings of the second dyno. He said he was going to go back and change the date for me! I have no idea how a dyno machine keeps date and time. Is it like every other computer?
  #646
Old 06-24-2019, 02:32 PM
proximity_alrt's Avatar
proximity_alrt proximity_alrt is offline
I imagine the Dyno computers are just windows computers with CMOS batteries (think the little disk batteries in your keyfob). If you have a power outage or pull the plug, it will reset the bios and the clock. There are plenty of little free programs out there to keep time, or even set windows to do it automatically.
Va68goat, when is the motor going back in? Have you worked out a date yet?
  #647
Old 06-24-2019, 02:45 PM
Formulajones's Avatar
Clay
I think you're looking at it backwards Clay or there is a misprint. Either way, As you can see Paul confirmed exactly what I remembered Paul told me. The carb specifically built for the combo is doing better than anything tested to this point. It's pretty common for Paul and Jeff to swap some carbs around for customers to show the differences and show what Jeff can do. Usually that means they use one that is available at that particular time that is tailored to another engine to give the customer an idea. Even with that said, many times they still produce better results than anything you pull out of a box.
Paul is a modest guy and won't brag, but I'll say it. Jeff is likely one of the best Holley carb guys in the country and I've been lucky enough to meet him. Super nice guy. He built Holley's for a few of the Nascar Cup teams before they went fuel injection and also ran his own Holley business throughout the 70's if I remember correctly. I wouldn't hesitate to run Jeff's carbs on my stuff..
  #648
Old 06-24-2019, 05:03 PM
Va68goat's Avatar
proximity_alrt,
The motor is in my garage now. I've never dropped a motor and bolted it in before so I think it's best for me to wait until one of my buddies help me. Hopefully we'll get this thing running in a few weeks!
As for the dyno...I have no idea what went wrong. The date and time is wrong, the rpm numbers are off the page, I was told the dyno guy makes up names for Jeff's carbs but apparently there is such thing as a 850 Brawler, the oil temperature gauge wasn't hooked up, it seems like the last dyno numbers are much different then the dyno run in September of 2017. Hell, I have no idea how to even read the dyno sheet.
  #649
Old 06-24-2019, 08:57 PM
Va68goat's Avatar
Here's a clearer version of the dyno sheet.
Name:	NEW dyno pg 2 copy.jpg
ID:	514774   Click image for larger version
Name:	NEW dyno pg 1.jpg
  #650
Old 06-24-2019, 09:45 PM
Took me a while going back and forth but I see the second pull definitely made more power. The first pull had more peak torque. Should be a tire-fryer for sure!
It would be nice if they exported all the results to excel or comma separated values for you. That would make it much easier to compare.
  #651
Old 06-24-2019, 11:32 PM
craigs69's Avatar
craigs69 craigs69 is offline
Originally Posted by Va68goat View Post
proximity_alrt,
I wish we lived closer, Joe. I would come over and get that engine in this weekend.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
  #652
Old 06-25-2019, 12:00 AM
Will Will is offline
Dyno dyno dyno... yadda yadda yadda.
Get that thing to a track. That's the only dyno that means anything. If you never intend to race it, then who cares what that dyno sheet says? Get it tuned well and enjoy driving it. Dyno sheets are for bench racing.
  #653
Old 06-25-2019, 04:31 AM
krisr's Avatar
krisr krisr is offline
This!
Get the motor in, running and just go enjoy it.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
  #654
Old 06-25-2019, 07:29 AM
Va68goat's Avatar
craigs69,
Thanks. I'm really hoping to have this thing on the road soon.
Will,
Hahaha..No, this won't be going to the track. It's just a fun street car. Who knows, maybe one day I'll see what it can do but for now, bench racing it is.
krisr,
I agree. It's been over 2 1/2 years dealing with this motor. I think it's finally time to enjoy!
  #655
Old 06-26-2019, 12:03 AM
64speed's Avatar
64speed 64speed is offline
I will never race mine either but with Paul’s cam help, my expert local machinist, and butlers rotating assembly and ported round port heads I should have a hell of a machine. My machinist/engine assembler said looking at the parts and the cam specs 600 ft/lbs is not off the table
  #656
Old 06-26-2019, 06:27 AM
redhawk44's Avatar
redhawk44 redhawk44 is offline
Awesome build. That thing is sure to break some dumb kids heart that thinks his mustang/camaro is the fastest thing around.
Let's make welfare as hard to get as Veterans benefits!
  #657
Old 06-26-2019, 09:14 AM
For anyone who's interested, I made a spreadsheet where you can see the differences in the two pulls and where the increase was (pretty much from 3000-5200).
https://docs.google.com/spreadsheets...it?usp=sharing
  #658
Old 06-26-2019, 12:46 PM
gtofreek's Avatar
IDK
Clay
I asked dyno guy about this. The temp probe is temp in the dyno room. The engine pulls air from outside, through the air meter in the ceiling, not dyno room air.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #659
Old 06-26-2019, 03:41 PM
Va68goat's Avatar
proximity_alrt,
Thank you for taking the time to do that spreadsheet. It certainly makes is easier to read. Any idea what caused the drop in power from 1,600 to 3,000? As I said before, this is just a fun street car. Actually, I've never owned a car with this amount of power. I'm pretty sure this is more than enough for me to have fun! Just wondering about the lower rpm power range loss.
  #660
Old 06-26-2019, 03:48 PM
Paul could explain it to you better than anyone, he built it and knows more about the details and differences between the two dyno sessions.
Closed Thread
