Old 12-30-2012, 05:03 PM
Formulabruce's Avatar
Grats! just the way my Grandpa showed me 40 years ago...
" Long may we DRIVE !"
Old 12-30-2012, 05:39 PM
njsteve's Avatar
njsteve njsteve is offline
What? The two artificial sugars?
I think they had outlawed Cyclamates as an artificial sweetener by then.
Old 12-30-2012, 06:48 PM
nah he drank it with REAL cream and REAL sugar...
was able to work at the same dealership with him for a couple years, was an honor
Old 12-30-2012, 09:42 PM
Here>>> Armasteel Rods
http://forums.maxperformanceinc.com/...d.php?t=716890
Here> Crane camshaft >
http://forums.maxperformanceinc.com/...d.php?t=716879
Old 12-30-2012, 11:57 PM
njsteve's Avatar
And here's the cam from the 455HO, the other cam was in Gramma's Firebird Esprit.
http://forums.maxperformanceinc.com/...d.php?t=716885
Old 01-05-2013, 05:32 PM
njsteve's Avatar
Got the heat riser hoses installed for the Ram Air air cleaner. Thanks to "PB" who sent me the correct beveled plastic elbows and original clamps, as well as the heat stove base plate and 90 degree steel elbow. I got the corrugated hoses from Performance Years for $6 each.
This is sure one Rube-Goldberg contraption once all those hoses are hooked up. No wonder everyone who had one of these cars ripped them out and tossed them in the garbage. It takes two people to remove or install the air cleaner now.
I also discovered that if you don't have the correct "thick" 1/4" carb to intake gasket, the air cleaner heat riser elbow on the drivers side will jam up against the valve cover and will hold up that side up, off the carb.
Old 01-05-2013, 05:50 PM
Held for Ransom's Avatar
I was actually going to suggest if you had the correct carb gasket in the other thread. It's still a close fit.
Old 01-05-2013, 06:00 PM
njsteve's Avatar
Thanks for the second opinion. Sometimes the obvious stuff escapes me. :-)
njsteve's Avatar
BTW, Here is a tip for the squeeling belt syndrome that Pontiacs have. These cars are very sensitive to belt thickness. If they are running multiple belts on the crank and water pump pulleys, the parallel running belts must all be of the same width or else they will scream at high RPMs.
The problem is due to the fact that they are trying to fight each other for traction while turning the same distance of water pump pulley at the same time. Because the thinner belt is sitting lower in the groove than the thicker belt, the thinner one is technically a longer belt by a few millemeters over the same distance of pulley groove.
Unfortunately, most manufacturers have gone to narrower belts for the old cars. I just bought two new belts for the Formula and had to search a while on rockauto.com for a matching set from Goodyear. Rockauto actually lists the widths for each belt, and they were cheap - around $10 total with shipping. The Goodyears were .44 width which is a little bit more than 14/32. The Gates and Delco belts were .4063 (13/32 width). Napa were the worst - they were around 12/32.
Here is the photo after the new same width belts were installed. As you can see, the inner, alternator belt only rides on about 3 inches of the water pump pully - just enough to create the scream if it is a different width. The power steering belt is what really operates the water pump pulley.
Compare that with this photo (courtesy of Steve Hoog) showing two different thickness belts on the water pump pully.
Old 01-05-2013, 08:36 PM
PB's Avatar
PB PB is offline
I posted this in your other thread Steve:
Steve, I see exactly whats going on...that tower clamp needs to be rotated toward the middle of the engine. If you look on the under side of the air cleaner, there are grooves that go around the openings. The grooves are beveled outward. There is a section that is open, allowing that tower clamp to clear the grooves. The clamp is on that groove, not allowing it to sit flush underneath. When you turn over the air cleaner, you'll see exactly what I'm talking about. The tower clamp should be orientated just like the pass side.
Pat Brown
Old 01-05-2013, 08:45 PM
njsteve's Avatar
I actually tried that first. The only groove is actually facing forward toward the radiator. The rear area is blocked by the Thermac mounting flap. When you have the clamp facing forward, the clamp bolt touches the radiator hose, with no change is air cleaner height.
Heres the underside photos from a couple months ago.
http://forums.maxperformanceinc.com/...695444&page=27
Ill do some more finagling tomorrow and update as I go along.
Old 01-05-2013, 09:00 PM
165th's Avatar
165th 165th is offline
Man that is one nicely detailed engine compartment! Great work Steve.
Old 01-05-2013, 09:02 PM
njsteve's Avatar
You know, the work is never done!
Old 01-05-2013, 09:14 PM
njsteve's Avatar
Heres my original owner photo from the 1980s
Old 01-06-2013, 01:14 AM
PB's Avatar
PB PB is offline
"This is sure one Rube-Goldberg contraption once all those hoses are hooked up. No wonder everyone who had one of these cars ripped them out and tossed them in the garbage. It takes two people to remove or install the air cleaner now."
No lie!! AND there's supposed to be a clamp on the both hoses too! One on the crossover elbow and one on the drivers preheater shroud. The hoses are literally screwed onto the air cleaner elbows. So just how are we supposed to remove the air cleaner?!! Lol. I'm guessing with the clamp on the crossover elbow, you were to loosen the set screw and pull the elbow off the stove base with the air cleaner assembly. Ridiculousness.
Pat Brown
Old 01-06-2013, 08:34 AM
njsteve's Avatar
It must have been another of their diabolical emissions anti-tampering efforts, just like the preset idle mixture screws and plastic caps!
Old 01-06-2013, 07:55 PM
PB's Avatar
PB PB is offline
Looks delicious Steve! Which way did you position Norwoods bracket? Bend up? Or bend down? It looks like you have it with the bend up. I've installed mine with it down, but looking at the assembly line pic, I think it goes upward. Got a close up shot of that bracket and stove base you can post?
Pat Brown
Old 01-06-2013, 08:34 PM
njsteve's Avatar
Actually, that is an original GM piece that was on the car already. It had no bend at all and I had to bend it up a little bit to mate with the tab on the collar.
Old 01-06-2013, 08:53 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Steve:
Looks great! I've fought this battle on my GTO since the day I bought it. As difficult as it was to get yours to line up just right - imagine adding to it the task of getting the two support brackets to line up with the studs on the bottom of the Thermacs! I notice your air breather doesn't have those studs -was that a GTO only characteristic?
BJ
Old 01-06-2013, 08:59 PM
njsteve's Avatar
I think the mountIng stud issue is still under debate, based on date of installation and whether its a later replacement piece or assembly line piece.
