Old 03-21-2017, 08:10 AM
frank.g frank.g is offline
Nice article. While we often see coverage in the specialty mags for our cars, it is difficult to get into the mass market ones. It's great to finally see a car that I know in the likes of Hot Rod. Congratulations, Steve, Enrico, and the New, newer project, part tres.
  #702
Old 04-24-2017, 08:15 PM
njsteve's Avatar
njsteve njsteve is offline
It's always something! I have been ignoring the SD lately, with all the mechanical attention I have been paying to the Gramma Car.
I took the SD out for its first drive of the year and the rear brakes locked and wouldn't release. I had to crack both bleeder screws to release the pressure and get the car rolling again. I spent the afternoon removing the proportioning valve to send it to Whitepost for rebuilding. Shipped it off this morning. Luckily I had another valve from a 1972 to install in its place to keep everything from leaking out completely.
Whitepost had previously sleeved the original master cylinder and rear wheel cylinders a couple years ago. Hopefully this is the final component that needs attention, and not the master cylinder (again).
ID:	452892   Click image for larger version
  #703
Old 04-28-2017, 08:42 PM
njsteve's Avatar
Whitepost does fast work! Even though they said it would take three days, I had it back in my hands on Friday, after they got it Tuesday. So I guess they mean including shipping time as well!
Once I got it back I plugged the openings and let it sit out in the hot sun and soak, in a bowl of Evaporust, so the surface rust would wash away. This is how it looked after an hour or so. I then removed the plugs and used brake clean to make sure all the internal passages were free of any residue. It's interesting how you can see the "3 170" date code stamped on both sides.
As for the original rear brake hose, I had a hunch that this was the actual cause...and I was right. I removed it and attempted to blow air through the hose - nothing came out. It is completely swollen shut inside. So let that be a lesson on survivor cars with original brake hoses! They are not to be trusted! The swollen brake hose led to the proportioning valve being activated which then jammed in the activated position and wouldn't reset because the pressure differential wouldn't balance. So at least all the wheel cylinders, the master cylinder, and the proportioning valave are all internally rebuilt and work as originally designed now. I guess I will keep an eye on both fron brake hoses to see if they need to be swapped out in the future.
And the combination valve reinstalled and brakes bled. I took her for a test drive and the brakes work great again.
  #704
Old 04-28-2017, 10:35 PM
Held for Ransom's Avatar
Steve, did White Post stamp the WP or was that a coincidence?
The rear brake line collapsed on my '73 TA years ago too.
  #705
Old 04-28-2017, 10:36 PM
njsteve's Avatar
Just coincidence. It was there before.
  #706
Old 04-29-2017, 08:02 AM
Norwood's Avatar
Norwood Norwood is offline
Great work Steve. You have inspired me as I have been neglecting my brakes for years. I to have original everything other than the master. I will address all of this very soon. Nice work safety should always be a top priority.
  #707
Old 04-29-2017, 09:59 AM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
Steve, I am very sorry to hear about your collapsed and swollen hose. Best of luck with the resurrection!
Sent from my XT1254 using Tapatalk
  #708
Old 04-29-2017, 10:06 AM
77 Canamman's Avatar
http://www.ebay.com/itm/1970-1973-Pontiac-Firebird-rear-brake-hose-NOS-9755607-/331906021177?hash=item4d4723f739:gN0AAOSwv0tVDLu A&vxp=mtr
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #709
Old 04-29-2017, 10:29 AM
njsteve's Avatar
Thanks for the link! I bought it. It is a more correct version than the one I installed. Excellent!
That takes some of the sadness out of having to remove my first original part on the car.
  #710
Old 04-29-2017, 10:30 AM
njsteve's Avatar
A double dose of penicillin and brake fluid has cured it, Thank you.
  #711
Old 04-29-2017, 10:36 AM
Norwood's Avatar
Isn't that nos a 40 year old part ?
  #712
Old 04-29-2017, 10:39 AM
njsteve's Avatar
Yes but it's the contaminated 40+ year old fluid that kills the hose from the inside, not necessarily the age.
  #713
Old 04-29-2017, 03:59 PM
Norwood's Avatar
Rubber doesn't deteriorate with age? I learn something new everyday.
  #714
Old 04-29-2017, 05:05 PM
njsteve's Avatar
Uh Oh. Is the sarcasm light now illuminated? :-)
Well, not in the way that these hoses are prone to fail. My original hose looked perfect on the outside. Not a crack to be seen even when you bent it 180 degrees.... like a 19,000 mile example should look. (wait a minute now THAT didn't quite come out right). But inside it was a solid core of petrified goop. I guess also, being so close to the hot muffler probably doesn't help it either.
If you go back to earlier in my thread from a couple years ago, and look at the photos of the pistons inside the master cylinder you can see what contaminated 40-something year-old original fluid did. It dissolved holes in them!
This is definitely a prime example of why you should flush and replace your brake fluid every few years... or every four decades whether it needs it or not.
Anyone happen to know the original part numbers for the front hoses now?
ID:	453457   Click image for larger version
  #715
Old 04-29-2017, 05:25 PM
Lightbulb
9753907 Discontinued 11/90.
  #716
Old 04-29-2017, 06:02 PM
njsteve's Avatar
Thanks! Now the search begins for the front hoses.
  #717
Old 04-29-2017, 06:19 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Don't get to excited. I fell for that e-bay sellers trap last year. Lists the right number in the ad but the actual hose you get is an incorrect #18002136 replacement. So.. It's NOS but not 40 years old.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
  #718
Old 04-29-2017, 06:43 PM
RAJ7395's Avatar
Most modern hydraulic hoses have an inner liner that is surrounded by reinforced (thread, steel wire, etc.) rubber. Once the liner becomes brittle due to age, exposure to elevated or arctic temperatures, repeated bending, etc. it will crack and allow the contained fluid to contact the rubber. Once this happens, the fluid will cause the rubber to swells up and eventually will work it's way into the reinforcement area and bulge the side of the hose resulting in failure.
  #719
Old 04-29-2017, 06:54 PM
Bentwheelbob's Avatar
Are you sure? My prop valve didn't have that stamp before going to White Post, but did after they rebuilt it. Same for the master cylinder.
  #720
Old 04-29-2017, 07:17 PM
Angry
That type of business practice is worthy of a bitch note and a negative feedback..
Hope Steve receives what is advertised...
