Old 08-03-2005, 03:15 PM
Teej's Avatar
Teej Teej is offline
Is that the #58299? The remanufactured one? (We don't have Kragen here in FL, so I'm looking online.)
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
  #742
Old 08-03-2005, 05:29 PM
60man's Avatar
60man 60man is offline
Do you have a NAPA. They used to carry a NEW water pump with a cast impeller, might have even been made by Cordone..NAPA is on line to..
ECM member.
MANDRA
  #743
Old 08-03-2005, 08:40 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Kragen goes under the names of Checker and/or Schucks on the east coast.
This is a 100% new pump, the part number sticker says:
B55-11145 Cardone
C130-1280 GMB
On the Kragen website (http://www.partsamerica.com/ProductL...r+Pump&ptset=A)
For a '69 LeMans, 350 cid:
Cardone B5511143 Water Pump: New Cardone Select W/3 31/32" Hub Ht.Lifetime Limited WarrantyShips in 1 day
Weight: 10 lbs.$69.99
Cardone B5511145 Water Pump: New Cardone Select W/4 15/32" Hub Ht. W/Cast Iron HousingLifetime Limited WarrantyFind in a store
Ships in 1 day
Weight: 11.3 lbs.$24.99
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
  #744
Old 08-04-2005, 01:32 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Great thread, for those like myself that have read pretty much all of this and have somehow forgot everything,
Could someone make a new version of George's chart that includes the part numbers and specs etc?
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
  #745
Old 08-04-2005, 09:16 AM
Teej's Avatar
Thanks PMD... I'll check out those links. I'll need one for a 67 326 and one for a 70 400.
Thad
  #746
Old 08-04-2005, 11:32 PM
can_am4me can_am4me is offline
I have posted on this topic before, and as it keeps coming around again and again, I will share my success story.
My '77 Can Am always ran a little on the warm side with the stock 400. When I replaced the 400 with a mid-performance 455, it only augmented the problem.
220 to 225 on the freeway, 200 around town, and fortunately stumbled on this threadbefore I waisted a lot of time and money. Went right to Checker Auto, had them bring out ALL the pumps, found a cast impellerunit,set the clearence with the seperator plate, and set out to test the set-up.
Never gets over 180 degrees, and we had our first 100 degree day in Milwaukee in years, so I thought I would give it a real test.
With the air on, NEVER got over 180 degrees! Even my wife said, " hey, didn't that little gauge used to go all the way to the right on a hot day?"
I have yet to hear of curing an overheating problem COMPLETELY by adjusting timing, richening the mixture, etc, etc. This worked completely and 100 percent.
Putting some "Can do" in my Can Am
  #747
Old 08-05-2005, 04:58 PM
george kujanski's Avatar
CAn_am: what was the state of the pump you replaced?
Success comes with a price; where's my buck?
George
  #748
Old 08-05-2005, 07:01 PM
PMDRACER's Avatar
Just a quickie update. As I mentioned, had to replace the water pump on the '69. Car always ran around 220 degrees on a hot day with the A/C on, and around 195 without it. Pulled the old one off that's been on the car for the past 10 years, and sure enough it was one with a stamped steel impeller. Replaced it with the new pump with the cast impeller. Didn't need to mess with the plate since it was pretty close to begin with.
Well, the A/C needs a charge so I cannot comment there, but it's pretty damn hot out there today and the '69 never went over 180 degrees.
That's a 15 degree reduction with only a change in pumps.
-RONALD REAGAN
  #749
Old 08-05-2005, 11:11 PM
The pump I replaced had the stamped steel impeller, the one that looks like an alternator fan.
  #750
Old 08-14-2005, 07:48 AM
GTOLou GTOLou is offline
I replaced my shory (early 69 w/ 4 inch length) with a reman. unit from Autozone - reman. by Fenco. It has a nice looking cast impeller. The unit I took out I bought from Year one 1-2 years ago w/ a stamped impeller.
  #751
Old 08-17-2005, 03:11 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Default Running cooler!!
I just finished checking/changing my pump to divider clearance from about 1/4 inch to damn tight without touching. Fired it up and it idles at 190 no higher no matter what! It used to heat up to 220-230 at idle if i let it!! I am running a milodon aluminum pump (11-hole). Thank goodness for that tip!!
Thanks to all (especially george i believe!) for that tip.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
  #752
Old 08-17-2005, 04:13 PM
Thumbs up
Where's my dollar? Glad you improved your temps!
George
  #753
Old 08-21-2005, 07:35 PM
cruzn68's Avatar
cruzn68 cruzn68 is offline
I wish I had seen this thread a year ago. I just happened to read a letter in HPP about the machined impeller vs. stamped. Probably written by one of you guys... I went to a Milodon pump now the temp stays under 195 pushing it 75-85 MPH. Before it would keep climbing until I let off it. I read somewhere else that overheating at idle speeds is lack of airflow thru the rad, overheating at hiway speeds is lack of coolant flow.
  #754
Old 08-28-2005, 02:12 PM
73ta's Avatar
73ta 73ta is offline
Well I don't know for sure which one did the trick, but thanks George for getting me started on the solution. Added factory Ac to my car and had heat problems with my new motor, 500HP. Added an aluminium rad, flowkooler pump, 160 stat, two 10" electric fans & a heavy duty clutch fan. Temp would still climb on hot days, especially in stop & go traffic. Did so research and changed my pulleys to AC versions. These overdrive the water pump fan. Massaged the divider plate to close the massive gap. Now on a 100 degree day in stop & go traffic with the AC on, temp never got over 185!
  #755
Old 08-28-2005, 02:14 PM
73ta's Avatar
Also forgot to mention, I removed the HD clutch fan, it was just too noisy. Went back to the stock non-AC 5 blade flex fan.
  #756
Old 09-02-2005, 11:15 PM
Shep_1966 Shep_1966 is offline
Great thread!!! Unfortunately I have not had the results of most people that have tried this. Here is some info.... I have had a 1966 Pontiac Tempest for 18 years(since I was 16). It came with a 389 that is bored .030 over. It has always had a problem with running hot. 220+ We first started with a fabricated fan shroud and a new fan 16 years ago. That didn't really help much. In college I found a posi rear end with 3:23's instead of the stock road gear's. That only made things worse.(Go figure!) About 8 years ago I purchased a 4 core radiator and put a new water pump in. That helped a little bit, but not much. I have pretty much lived with it ever since.
I started reading this thread and was hopefull that massaging the divider plate and checking to see if I had a cast impeller would help. I took it apart to find that I had about a 1/4 inch gap and a cast impeller. I closed the gap and put a new 160 degree thermostat in and took it for a drive.
It seemed to help about 5-7 degrees out on the highway at 70+ mph. Better than nothing. It still ran about 217 degrees when it was 87 degrees outside. Once I backed it down to 55 mph it went down to about 195 -200. Once I got home, I let it idle in the driveway for 5 minutes and it jumped up to 230+.
Sorry for the book, but I was wondering if you guys have any other suggestions. I would say that I am a rookie mechanic, so please be patient.... George, I still think this was a good idea and would gladly pay the buck for the suggestion!!! Thanks!
  #757
Old 09-02-2005, 11:24 PM
Shep, too bad it's not totally fixed. What temp gauge are you using and is it accurate?
Make sure you don't have trapped air.
Airflow and coolant flow.....anything that lowers either can be a culprit. Did you check your state of tune?
George
  #758
Old 09-02-2005, 11:56 PM
When I made the change to the divider plate, I put a new temp gauge in. I didn't go with the cheap model either. How do I tell if there is air trapped? What did you mean by "check your state of tune"? I'm a rookie..... I appreciate the help.
Shep
  #759
Old 09-03-2005, 12:20 AM
STate of tune: check your timing, make sure you're not running lean, connect your vacuum advance to manifold vacuum rather than ported vacuum.
George
  #760
Old 09-04-2005, 11:26 PM
RevGTO RevGTO is offline
This is a follow-up to my previous post #734. After about a month and a half of occassional summer driving, I can say that the cast impeller/divider plate mod has been worth about 15-20 degrees. For example, today I was caught at the tracks by a train and sat there idling with the A/C on. Checked when I stopped with the infrared sensor and I was at 185. Before it would have been 205 and climbing - and 220 before long. George, it was a dollar well spent!
