Old 07-06-2013, 06:49 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Ideal situation would have been to trim the lifter bosses before the whole assy went together. Would have to install cam bearings in the block and install the camshaft that would be used and measure the tie bar clearance at every position. Then if necessary put the .080" clearance milling in the block bosses. Not Rocket Science.
Tom Vaught
Let’s all be grateful this wasn’t a rocket.
I agree, BES should have done that. On a side note, if these heads are still being made, you might want to double check your intake pushrod tube location.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #762
Old 07-06-2013, 09:37 PM
67'7F6'Bird's Avatar
The cam has been changed, the rocker bar clearance does look tight on a #1 and #3 which are the only 2 which have been installed with the new cam. The block has some marks indicating clearance issues which I don’t believe happened while the new cam was being degreed using test springs.
But were you using a 3/4 inch drive to turn the motor over or a 1/2 inch drive when you were degreeing the Cam in? We all know how forceful you can be.
  #763
Old 07-08-2013, 09:47 AM
RAIV-Z's Avatar
Originally Posted by cgeise View Post
Call Crower - you want a raised seat lifter with pin oiler and offset if you need them - they now have the bushing style also -
Were any lifter or additional block modification required to run these?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #764
Old 07-08-2013, 09:54 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
I had to grind my IA block the first go around so the bars would not hit.
I would rather grind a little on the block then the tie bar.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #765
Old 07-08-2013, 10:06 AM
RAIV-Z's Avatar
I agree with you Jack, grinding the lifter tie bars is not the right way to fix this. Where there were obvious clearance issues when the engine was initially built, not sure why it wasn't done right the first time...
The current lifters are Crower 66260:
Full Body Mechanical Roller Lifters (.842" dia. / .750" Bearing) V8 (Pontiac/Oldsmobile) Pontiac 1955-Up 326-455ci, Oldsmobile 1964-1984 260-455ci (Set of 16) Full Body Mechanical Roller Lifters
Looks like these will be ending up in the spare parts drawer. I think I'm going to need a bigger drawer.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #766
Old 07-08-2013, 10:58 AM
johnta1 johnta1 is online now
Haven't you tore this engine down again?
Why didn't you grind the block this time, especially since you knew this was a problem?
  #767
Old 07-08-2013, 12:19 PM
RAIV-Z's Avatar
Yes, the McCarty/BES Racing Crate Engine after only 2 N/A dyno sessions which were performed by BES was torn down after I received it.
I have no excuse for not having the 2nd machine shop fix an issue that would have been a non-issue if either the first shop addressed the problem or simply used another lifter like a Crower 66294. These roller lifters feature a special alloy body, a lightweight design, and a heavy-duty blade that has been moved up to fit late model blocks.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #768
Old 07-08-2013, 05:24 PM
cgeise's Avatar
cgeise cgeise is offline
it is a .903 lifter - but it clears everything
  #769
Old 07-08-2013, 06:01 PM
RAIV-Z's Avatar
Did you perform the oil hole to oil band scribe line mod?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #770
Old 07-08-2013, 07:00 PM
cgeise's Avatar
The lifters are made by Crower for pressure pin oiling - We have bushings in the block with a .030 oil hole and get PLENTY of oil up top
  #771
Old 07-11-2013, 07:17 PM
RAIV-Z's Avatar
Crower Enduramax lifters (66294E) arrived today, just as Curt said no block clearance issues with these. I will need a slightly longer "0.050" pushrods, they should arrive tomorrow. The original pushrods were 9.750 long.
ID:	329409   Click image for larger version
ID:	329410   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #772
Old 07-11-2013, 07:39 PM
cgeise's Avatar
And thats not even the raised seat unit
  #773
Old 07-12-2013, 04:39 PM
Was BES looking to see the effects of gasket material going through the Oil Filter Housing.
  #774
Old 07-13-2013, 12:12 AM
PonchoV8 PonchoV8 is offline
On the oil slotted mains, didn't I read a couple yrs ago that Dude does that mod? Anyone else remember that?
  #775
Old 07-15-2013, 04:00 PM
cgeise's Avatar
these are the raised seat style
  #776
Old 07-15-2013, 04:44 PM
RAIV-Z's Avatar
I believe Crower calls those Hi-Seat.
I ended up with the SEVERE-DUTY CUTAWAY ROLLER LIFTERS Crower’s Severe-Duty
Cut-Away style rollers feature a superior, billet alloy body, lightweight design and a heavy-duty blade, raised to fit late model blocks.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #777
Old 07-15-2013, 05:16 PM
cgeise's Avatar
I believe you can get the hi-seat in severe duty also- just have to talk to the right guy -- good luck the hi-seat is nice for a shorter pushrod ---
  #778
Old 07-17-2013, 09:02 PM
RAIV-Z's Avatar
Just about ready to run it on the dyno NA to break it in again...
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #779
Old 07-17-2013, 10:30 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
I must be living life wrong. You have a pool right at the door of your garage? Holy smokes!
Id never get anything done if I had that staring at me every day. LOL
Good luck, see you at Norwalk.
  #780
Old 07-18-2013, 12:56 PM
David Holmberg's Avatar
Looks good!
