Old 04-25-2010, 08:57 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
The Pulley kits have released and are currently posted on the CVF Racing website. www.cvfracing.com
We have reached the 25 order minimum and we have the go ahead on the 15% discount code for ANY Pontiac pulleys.
The discount code is HFPONT15.
Just type this code into the discount code box upon completing your order and you will recieve 15% off of your order.
The discount code is good until July 30 2010.
There is also a single groove crank pulley and a single groove waterpump pulley available for release VERY soon. (Please contact CVF Racing directly for availability).
Please place all order expected to be discounted before July 30, 2010.
Again....thanks to all who are participating in this offering.
We can revel in the availability of a quality pulley kit at SBC pricing!
Thanks to all.
Brad
  #62
Old 04-25-2010, 11:07 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
This is good news, I wonder which groove the the single pulleys sets will use?
  #63
Old 04-25-2010, 11:12 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Picked up the CVF alt pulley last week, it's a nice piece. I'd be interested in the crank pulley if they had weight #'s.
Here is some info on the CVF alt pulley vs stocker.
CVF alt pulley 2.68" and 8 ounces (with bolt cover cap)
3 ounces (without bolt cover cap)
Stock alt pulley 2.81" and 5 ounces
Stock 8" crank pulley with the 2.68" CVF alt is a 14% increase over the stock pulley.
FWIW, stock 69 WP pulley (chromed) is 6.43" and 1lb 13 ounces
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
  #64
Old 04-26-2010, 12:02 PM
v869tr6's Avatar
Ordered my set today, Thanks Bnick166 for putting this together.
  #65
Old 04-26-2010, 12:18 PM
Bnick166's Avatar
Happy to do it!
I'm just glad we were able to get enough orders for the group buy.....and get these into production.
I'm going to look into some bracketry as well......
  #66
Old 04-26-2010, 12:21 PM
Bnick166's Avatar
What the weight on the stock 8" crank pulley you have?
I'll bring my stuff to work to weigh on accurate scales.
I meant to do it last week and forgot.
  #67
Old 04-26-2010, 03:27 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
If everything goes according to plan it will be the 1 you can't use. Atleast that's my luck
  #68
Old 04-26-2010, 04:42 PM
GOAT8U2's Avatar
I don't have the stock crank pulley weight, it's on the car and I don't really want to take it off to weigh it
I'd imagine that there's at least a 3lb difference since it's 8" of steel vs 7.9" of aluminum.
  #69
Old 04-26-2010, 06:13 PM
v869tr6's Avatar
My car now has the early 69 pulleys and a home made alt bracket, so I just went with the two pulley setup. I know I will need to move the alt. but thats normal for my car, 10lbs of sh*t in a 5 lb car, LOL
I did ask and was told the groove closest to the engine would be the one you would get on the water pump.
  #70
Old 04-26-2010, 06:14 PM
Bnick166's Avatar
Drop 'em an e-mail....maybe you can sway them to make them the way you want them....
  #71
Old 04-26-2010, 06:16 PM
Bnick166's Avatar
I'll weigh all of them anyhow....maybe someone else can chime in on the stock 8" crank pulley weight.
  #72
Old 04-26-2010, 09:49 PM
PLAY400's Avatar
Going to order 2 sets tomorrow, one for a local guy and I'm going to put a set on my Bird and put my Rodney Red under drives in the 55
  #73
Old 04-30-2010, 08:36 PM
64Leconvert's Avatar
64Leconvert 64Leconvert is offline
starting from scratch with the pulleys and alt. bracket.Have a 71 455 thats going into a 64 lemans convert.Pulleys seem to be easy choice with group buy.Will alt bracket from any year work with single groove pulleys?anyone with after market brackets?
  #74
Old 05-01-2010, 11:44 AM
PLAY400's Avatar
Got the pulleys yesterday. Look good. Should have ordered a fan for the alternator to finish it off.
  #75
Old 05-07-2010, 11:05 AM
Bnick166's Avatar
Single groove pulleys are now available and included in the group buy (15% discount if purchased before July 30, 2010.
  #76
Old 05-15-2010, 07:17 PM
GOAT8U2's Avatar
I'm a buyer with the weight difference, already have the alt pulley and it's nice.
  #77
Old 07-22-2010, 02:19 PM
Bnick166's Avatar
Anyone on the fence as to weather to buy a pulley/set of pulleys from CVF Racing are encouraged to do so soon. The current 15% Group Buy Discount expires July 30, 2010
  #78
Old 09-12-2010, 11:36 PM
PLAY400's Avatar
Getting ready to pull the underdrives off the Bird and replace them with this set. Anyone have fan belt #s of what fits what??
  #79
Old 10-03-2011, 09:48 AM
hectore3 hectore3 is offline
Does this company in the future plan on offering serpentine pulley kits for Pontiac engines?
