#61
we put one in the RA V short deck motor,maybe Ken can comment as he did the installation.Tom
#62
Can any send me a pic of the setup, the link wasn't availible on my pc. [email protected]
On the bumper or put it on the trailer |
#63
John, my server was down. Here are the pics:
#64
Just got mine. Looks like a quality piece! I'll be installing it this fall and will let you guys know how it fits.
Runner Up Q16 Norwalk 2013! |
#65
Thanks.... Scott Sims Sims Performance Machining
Scott Sims Sims Performance Machining LLC P.O. Box 184 Elizabethtown, Indiana 47232 phone... 812-350-8637 [email protected] |
#66
One other thing.....Tom S. Was that one of my cam plates on your RA V engine that I read about in HPP?
Scott
#67
Is this better than Butler's step design bronze bushing (the web site claims less wear on the plate because of the bushing)?
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
#68
Scott,yes it was in the motor.I need to talk to you.Email me from my profile.Dont PM.Tom
#69
Junkyard dog....I personally think its better. Mine gives you a roller bearing on both sides of the plate. It controls camshaft end play with those bearings. Its also is oiled using the factory oiling system with no mods to the block or cam.
#70
JunkYard Dog, my feeling is that the Sims Performance roller bearing cam plate is superior to the bronze bushing. I agree that the bronze bushing will decrease friction between the cam gear and thrust plate, but you still have the same friction between the cam and thrust plate. If memory serves correct, the cam tends to ride forward (toward thrust plate) under acceleration and rearward (toward rear of block) on deceleration. I do not believe the bronze bushing will improve friction or wear characteristics on acceleration. The Sims Performance setup provides roller bearings on both sides of the thrust plate which will decrease friction on both accel and decel. Food for thought...
P.O.S.I - It's not just a club...it's an addiction! |
#71
Thanks.
#72
How many people are running these. Has there been any issues with them. Im interested in one but it would go on a car that sees some miles and the last thing Id need is for it to come apart.
#73
I have one on the engine going to the dyno this month. Straight forward installation. Good quality pieces.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#74
So am I correct in my understanding that this setup controls front and rear movement? So true cam endplay can be set. Not relying on the rear cam galley plug or the stock retainer plate for end to end movement.
If so, I will be contacting you very soon as I am about to install a solid roller cam in my engine.
Jeff Ianitello |
#75
Pontiac Jeff...Yes it does control endplay both ways. When we dyno tested this concept, we concluded that this control helped in the HP gain that we saw on the dyno pulls. So it was probably a friction reduction and controlling the timing @ WOT that helped with the gain.
Slowbird.....I have sold 25 sets to date. With only one complaint. That was...And Iam ASSuming here...was with a setup that might have not been oiled correctly. The setup was with a roller bearing cam where the roller bearing replaced the standard cam bearing. In doing this .... you block off the oil passage going to the cam beaings and rely on "splash" to oil the roller bearing and this works. But, My setup relies on the oil supplied to the No.1 cam bearing for oil to the bearing in the cam retainer plate torrington bearings. It is a positive oiling system with oil being pumped through the bearing for positive oiling. When you use roller bearings for the cam....This positive oiling is lost. there is a way to correct this, but it is unproven so far. Again, I run this setup in a circle track car with Absolutly no problems. Thanks ....Scott
#76
So what all has to be done to run this? Would I have to send my gears to you to get fitted? What does the $220 include?
#77
I have the one that Scott is talking about.He is going to remachine the retaining plate to gather oil and feed the bearing.Great piece and want to get it back into the engine ASAP.Tom
#78
Slowbird...If you want... you can send me your cam gear(sprocket) and I'll machine it for you and send it back with all needed to reinstall on your engine for $150. $220 is for a complete new kit. So if you want ...I'll machine your gear, no problems. Please include about $10-$15 dollars for shipping back to you for a total of $160-$165 depending on where you live from zip 47232
Thanks...Scott Sims Performance Machining
#79
simsb52 I sent you an email.
#80
Hi Scott,
I am interested in one of your timing chain sets. After throwing away numerous cam retainer plates that were too chewed up to re-use, its time to step up. Looks like an excellent product, I can't believe nobody else thought of this years ago! 9 hp and 10 ft lbs of torque is amazing, its a win - win deal. Do you have any sets in stock? Todd |
