http://pitposse.stores.yahoo.net/folduptirerack.html |
I have a factory rear spring chart. As soon as I can figure out how to get a good picture, I will post it. The part numbers translate different, it has the dimensions. I also have a factory blue print showing how to install the rear springs correctly.
Rear spring chart
I just put the CC501 springs on my 1972 LeMans vert and I'm not impressed. The tight coils at the top are almost all touching and the ride height is exactly the same as the old springs. As soon as the weather breaks I'll take a pic.
I have a set of variable rate coils in a El Camino. The tops of the springs bunch up in that too, that's the way they are made. Look at a set of stock rear springs and you will see the coils bunching up on top of those also.
It took me four months, but I thought I'd return to this thread to post pics of my GTO with the new coil springs.
First pic is from four months ago, with the cc507s. Way too high. The second pic is today, with the new cc651 - much better, perhaps perfect? The third pic is a few minutes later with a full tank of gas. |
I haven't had her on the road long as we just got the motor back in and now she has a broken lifter but the goat is looking alright in the stance department now.
285/40x17 on 10" Boyd wheels (junkyard dawgs) with 5.5" offset 245/45x17 on 8" wheels in the front 4.5" offset cargo springs in the rear, hotchkis "big block" springs in the front no rubbing issues If anything she sits a hair too high in the back but I think it's alright. I'll post more when I get the motor situation taken care of. Maybe one with a girl in a bikini as no one seems to do that anymore! |
Here's my '72 with CC501 coil springs on. The rear tire is a 275-60-15 and fronts are 235-60-15. This is a perfect ride height for me.
Thanks Maurader, but with 2 young boys, bikes, workbenches, tools, etc, I don't even have that much room...and there's no room to expand.
I'm stuck for at least 10 more years.
How many of you have driven over 340?
I did a bunch of research before i purchaced cc501s from advanced for about 47.00 .I installed bags to adjust preload and ride height.however dont know how it will look yet??The sway bar is an ATR off a G-body
BOB SLUSSER 937-286-4343 Last edited by 1970gpsj4speed; 12-09-2006 at 05:41 AM. |
I just measured the coil wire diameter and found it to be .565" diameter.
Ken, would the cargo coil, cc-510, have a softer initial rate even though the wire diameter is larger? I want/need some weight transfer at the initial launch on the dragstrip. I am wondering if, even though the wire is larger, the lower pitch (coils per foot) would allow some give first, then increase rate as the pitch increases...meaning as the compression goes more toward the tighter coils? Is this the proper way of thinking, or am I amiss?
Bump
Bump
