Old 11-17-2009, 09:51 AM
blue71ta's Avatar
blue71ta blue71ta is offline
Originally Posted by giles View Post
I was NOT trying to rub it in! Those are just some of the best pictures of 235/60R15s on Rally IIs that I have. I am actually in the midst of painting two more wheels so I can put that set on my 71 TA (two of the wheels in those Formula pictures are junk). I think the Goodyear RWL tires and Rally IIs look great. 255s are too big IMO. They fill out the wheel wells, but are too "fat" around the sidewalls. Maybe they'd look OK on 15x8 wheels.
I agree, they bulge out beyond the rim too much. I have 245s on my '71 T/A and even those are a little fat...
  #62
Old 11-17-2009, 04:23 PM
LeighP's Avatar
LeighP LeighP is offline
Of course you could always get some 225/70x15's....we put a set of BFG's on a friends car and they look really good....very period "correct" and the right height.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
  #63
Old 11-17-2009, 05:16 PM
666 the legend's Avatar
666 the legend 666 the legend is offline
..So what is the RIGHT SIZE tire for the 70-72 's..??
  #64
Old 11-17-2009, 05:39 PM
CaptCrunch CaptCrunch is offline
I run 255/60/15 on a 15x8 .........but that's a repop wheel.........
  #65
Old 11-17-2009, 07:50 PM
The factory tire on a '70- '72 TA was an F60 x 15 (7" wide wheel). The closest metric equivalent to that would be a 235/60x15. See Tire Rack link below:
http://www.tirerack.com/tires/tirete....jsp?techid=45
  #66
Old 11-17-2009, 09:13 PM
Norwood's Avatar
Norwood Norwood is offline
Here are a couple of good views of the Goodyears on my 70 JW's. Front 235/60/15, Rear 255/60/15. I LIKE IT...But the rear will be coming down a bit over the winter when I put the new leafs in...I HOPE!
  #67
Old 11-20-2009, 12:01 PM
Here are some pictures of a friend's 70 Formula. He is running 255/60/15's on 15x8 rims.
ID:	188175   Click image for larger version
ID:	188176   Click image for larger version
ID:	188177   Click image for larger version
ID:	188178   Click image for larger version
  #68
Old 11-20-2009, 10:30 PM
Wow... Goodyear Eagle VR Gatorbacks. The good old days... when you could get serious performance rubber in a 15 inch size. They haven't been available for awhile...
Nice looking Formula.
  #69
Old 11-21-2009, 01:09 PM
Tazzz2's Avatar
Tazzz2 Tazzz2 is offline
eaglesan13, that Formula sure does look good in silver with that black gut..... Nice car my friend, nice car...
  #70
Old 11-21-2009, 11:52 PM
Tazzz,
You would really like this car. It sports a 70 RAIII block with lots of work done to it, Butler prepared aluminum heads, original (correct) ram air setup, hooker headers with 3 inch exhaust and an X-pipe, Richmond 5 speed trans with the original 12 bolt (3.55's I think), and lots of suspension work as well as 4 wheel discs. I bet it would be a blast at the dragon!
ID:	188288   Click image for larger version
ID:	188289   Click image for larger version
ID:	188290   Click image for larger version
ID:	188291   Click image for larger version
  #71
Old 11-22-2009, 11:27 AM
Tazzz2's Avatar
Ah now your just teasing me LOL...... I take it you'll be up for a little grudge match up the Dragon in the fall at the "Run Through The Hills" ;-)..... Sounds like way to much fun to drive my friend and your 100% right the mods are in keeping with the sort of handling improvements I love making on my own early birds.... I'll bet with that 3" inch main you can really spin that motor up and have a blast in the turns....
  #72
Old 12-13-2009, 02:47 PM
I took some pics of the formula yesterday. It is slow going, but at least they are working on it again. I took the fender bolts and shims to them and they hung the fenders. These pics show the body line on the drivers side. It looks pretty good, although the body line is too sharp right now. The body man said he will smooth it out in the next blocking. The passenger side will need some additional body work where the fender meets the top of the door and he will be working on that this week.
ID:	190673   Click image for larger version
ID:	190674   Click image for larger version
ID:	190675   Click image for larger version
  #73
Old 12-13-2009, 05:00 PM
cant wait to see some color on there...........
  #74
Old 12-13-2009, 10:18 PM
Chris, your car's going to be VERY nice looking! I can't wait to see it, either-
  #75
Old 12-24-2009, 04:57 PM
Another coat of primer. Painter says he will begin blocking it again on Saturday.
ID:	191783   Click image for larger version
ID:	191784   Click image for larger version
ID:	191785   Click image for larger version
ID:	191786   Click image for larger version
  #76
Old 12-25-2009, 07:45 AM
LeighP's Avatar
Looks good...can't wait to see mine in paint...
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
  #77
Old 12-25-2009, 02:17 PM
cant wait to see some color..........
  #78
Old 12-28-2009, 12:41 PM
unruhjonny's Avatar
this was a great read!
Regaurding the tire debate, iirc (I didn't click any of hte links) the 235/60/15 is hte closeste to section and height as the original F60/15, but the 245 is closer to the correct tire patch...
I have run 235's, 245's, and 255's;
I liked the 255's the most, but they're a smidge too big for the OE ralley wheels.
IMHO, the 245/60/15 is the best tire - is is only marginally taller than the F60/15 (not enough to make a significant speedo error, but a wide enough tire patch, that it looks right...
I liked the 245's enough (actually they're a rarely ordered tire size btw) that after seeing 245/60/14's on an early Firebird some years ago, I bought a set for my '73 Formula...
1970 Formula 400
  #79
Old 01-03-2010, 11:37 AM
The second blocking is done and the painter will prime it again this week, then wet sand it. He still needs to strip and prep the hood, front bumper and rear plastic body panel but it's getting closer. He bought the paint a few days ago so hopefully he will putting color on it soon.
ID:	192670   Click image for larger version
ID:	192671   Click image for larger version
ID:	192672   Click image for larger version
ID:	192673   Click image for larger version
  #80
Old 01-22-2010, 08:14 PM
In an effort to push this project along I brought some of the small parts (like the mirrors and side marker light bezels) home to sandblast them. The park light fillers are plastic and I didn't want to damage them so I turned the pressure down on the compressed air to my blast cabinet and hit the with the blaster. There is a "67" written on one of the fillers. Interesting, since my car is paint code 67. But why would this be under the paint?
ID:	194815   Click image for larger version
