#61
I figured that with "Uncle Tony" tuning, there could be 50 extra HP there.
I said 690 to 750 hp, where as others were guessing in the 800 HP+ range Like I said, the compression ratio bothered me. PROBIRD missed the RPM as did I, as I thought it also would be in the 6500 range. Still a 700 plus horsepower engine with low compression at only 468 CID is a strong Pontiac engine. I think the best that Marty P ever got NA was 735 hp with a 473 engine so you are in good company. Yep, PROBIRD gets the "honey baked ham" on this dyno guess contest. Tom Vaught
#62
Nice engine power on pump gas!!! Fun street ride or race car? Sorry, I'm new here and don't know what everyone has. Whatever you put it in should fly!
#63
Congrats Brad.......another sweet street engine!!!
#64
Sounds like a good solid build that will last with little maintenance.
#65
Simply awesome ...should run very well in the car...congrats...Gene
'66 GTO 3600lbs w/driver, e-heads,474 N/A . best 60' 1.305...best 1/8th ...6.205 @ 110.14...best 1/4 9.794 @ 136.15 through mufflers on e-85 |
#66
Congrats Brad!
Once you get it in the car we can review you info and do a final tune for the street. That way you can drop down on your primary jet size and go back to using a PV...providing you have vacuum. Do you know what the engine had for vacuum at idle?
Carburetor building & modification services Servicing the Pontiac community over 25 years |
