Old 10-24-2010, 03:44 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Turbo HP and torque numbers also look like a table top, lots of power over a large RPM band.
  #62
Old 10-24-2010, 04:18 AM
Gas455's Avatar
Gas455 Gas455 is offline
Great build..... Been following it for a long time.
You are an inspiration.
Be safe with all that HP!
  #63
Old 10-25-2010, 03:10 AM
badassgoat's Avatar
badassgoat badassgoat is offline
Originally Posted by BruceWilkie View Post
Quite well. Conservative guesstimate approx 370 cfm head, At 15 psi no intercooler and carb restriction mediocre cam conservative tune at least 1150. Intercooled minimal restriction on intake and exhaust port 15 psi on the gauge around 1500. Thats on pump gas. (assuming turbo is at least supplying enough air at 65% efficiency 2.0 pressure ratio, modern turbo's are more efficient) Turn up the boost from there add octane as needed and you can get some huge numbers. You may not need to exceed 6000 rpm to get there either.
According to Dave B. my heads avg mid 370's @ .750 so I think the results would be quite satisfactory. Now all I have to do is figure out how to pay for it.
69 'Blackbird'
535 CID IA II SD Wide Port E-head Pro Systems Dominator
  #64
Old 10-29-2010, 06:07 PM
aronhk_md aronhk_md is offline
My 462 with 77mm Garrett turbo and ported 6x heads did 1064hp (converted from rear wheel hp) on the dyno for Mark when he owned it at 15psi and 5500 rpm. Doc's will eclipse that like Lou Ferrigno standing in front of Richard Simmons.
Way to go Doc, congrats at getting it on the pavement. I knew it was going to be a monster, but I wonder how many reading this understand that 1600 hp is very realistic for a setup like yours.
Be safe.
  #65
Old 10-30-2010, 01:59 PM
Something to keep in mind about head flow. NA its a matter of VE at a given rpm. Amount of flow capacity determines rpm point for peak power. Once you hit that point it becomes more difficult to make more power above that RPM.
Boosted engines, head flow capacity greatly determines what pressure would be required to move more than 100% VE at whatever rpm you chose to limit yourself. Mass airflow. Want 1500 hp? Then you need about 150 lbs/min airflow. If the turbo is up to it it can supply it.
Boost psi on the gauge is a measure of restriction. What pressure are you going to end up with to flow 150 lbs/min air?
The higher flow capacity head will move that 150 lbs/min at a lower pressure vs a more restrictive head.
With pressure comes charge heating. More psi for a given flow amount can still make same power up to the point charge heating affects preignition/detonation for the fuel being used.
Three examples 1500 hp. All three combos need 150 lbs/min airflow to acheive 1500 hp
455 6x head ported to 260 cfm. Its going to take a tid over 5700 rpm to use 100% CAPACITY of that 260 cfm NA! basically 100%ve.
What Boost pressure would it take to move 150 lbs/min air???
Nearly 29 psi on the boost gauge MINIMUM pressure.
535 370 cfm head. NA its going to take a tid over 6900 rpm to reach 100% capacity. At 6000 rpm you could potentially have a capacity of 15.5% above 535 cid at 6000 rpm.(115%ve potential)
So now what does MINIMUM boost pressure for 150 lbs/min airflow look like??
About 15.8 psi MINIMUM on the boost gauge.
Now lets put the 370 cfm head on the 455 and set rpm at 6000 rpm. 1500 hp goal.
Still needs 150 lbs/min airflow from the turbo.
At peak power whats the boost gauge going to read?
Now you are looking at 135.8% flow potential capacity over what the engine could consume 100% ve.
SURPRISE! Same as the 535! 15.8 psi minimum to move 150 lbs/min air through them.
Why? SAME FLOW CAPACITY.
The 535 will still be a better package. Better low speed and transient response, faster spool up etc. (greater liklihood of a turbo match as well)
So with boost pressures likely higher than estimated because your not likely going to be as close to those potential VE capacities to start with regardless, do you want 15.8 psi or 29 psi MINIMUM to do the job?
Which is going to be more fuel sensitive and preignition/detonation prone?
PLEASE NO HATE MAIL these are approximate GUESSTIMATES as there are many other factors to consider. I just wanted to illustrate the effect of head flow capacity on boost psi vs airflow through an engine.
  #66
Old 10-30-2010, 02:56 PM
bankbook's Avatar
bankbook bankbook is offline
Thats some good info Bruce.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #67
Old 10-30-2010, 04:31 PM
badassgoat's Avatar
Good info Bruce. Very tempting since I regularly spin my 535 that high and more. Hell that's right about where I'm making max HP with my heads and cam package and truth be told, I've spun that bastid up close to 8k on a few occasions. lol
69 'Blackbird'
  #68
Old 10-30-2010, 05:09 PM
bankbook's Avatar
I was shifting between 62-6400 on those runs.
DOC'S TA
Both 4 speeds!
  #69
Old 10-30-2010, 05:16 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Be safe.
yeah i think it could make close to that also.. cant wait till he stands on that thing!!! badass for sure..
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
