Old 02-12-2011, 02:53 AM
72TAMAN's Avatar
72TAMAN 72TAMAN is offline
April 2010
Picture #175 inside left door standard interior
Picture #176 rust under left door
Picture #177 view of trunk lock ( will install a 76 TA power trunk unit in Trans Am)
Picture #178 rear view
Picture #179 rear glass date code
Name:	1972 TRANS AM   #175   4 APRIL 2010 LEFT DOOR INSIDE DOOR.jpg
ID:	234356   Click image for larger version
Name:	1972 TRANS AM    #176   4 APRIL 2010 RUST UNDER LEFT DOOR.jpg
ID:	234357   Click image for larger version
Name:	1972 TRANS AM    #177   4 APRIL 2010 TRUNK  LOCK.jpg
ID:	234358   Click image for larger version
Name:	1972 TRANS AM     #178  4APRIL 2010  BACK END.jpg
ID:	234359   Click image for larger version
Name:	1972 TRANS AM    #179   4 APRIL 2010 REAR GLASS MARKING  DOT 15_X72.jpg
ANDRE
1972 TRANS AM , UNDER RESTORATION
http://forums.maxperformanceinc.com/...d.php?t=656067
1972 FIREBIRD FUTUR PROJECT
http://forums.maxperformanceinc.com/...d.php?t=674551
1978 TRANS AM (PARTS CAR) MAYBE
1971 LEMANS T37 (PARTED OUT)
1976 TRANS AM (PARTED OUT)
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #62
Old 02-12-2011, 05:00 AM
Formulabruce's Avatar
I am going to name this car "FRODO" . It has been to there.. and hopefully back again....!!
" Long may we DRIVE !"
  #63
Old 02-13-2011, 12:27 AM
72TAMAN's Avatar
THAT'S ''MISTER FRODO'' TO YOU BY THE WAY HOW'S 'BARNEY'
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #64
Old 02-13-2011, 01:26 AM
72TAMAN's Avatar
APRIL 2010
Picture # 181 hard to see but the floor at the rear seat area has a double floor because the new frame was higher than the original floor ,I didn't want the new carpet to wear out right away so I cutted and welded a second floor on top of the new frame to make the floor flat again
Picture #184 76 Trans Am speedo was installed in the car because the mileage was at almost 100 000 miles 99298 to be more precise , used a drill and a piece of speedo cable to bring it to all back to 0's so the day the Trans Am is back on the road it will be plug back in . This time around I will put back the original 1972 speedo back in
Picture #180 view true through the rear glass
Picture #181 view of rear seats
Picture #182 right door jam
Picture #183 new old rocker panel
Picture #184 76 Trans Am speedometer at all 00000.0
Name:	1972 TRANS AM      #180   4 APRIL 2010   REAR GLASS.jpg
ID:	234472   Click image for larger version
Name:	1972 TRANS AM   #181   4 APRIL 2010 REAR SEAT VIEW LEFT SIDE.jpg
ID:	234473   Click image for larger version
Name:	1972 TRANS AM     #182   4 APRIL 2010  LEFT DOOR JAM.jpg
ID:	234475   Click image for larger version
Name:	1972 TRANS AM    #183  4 APRIL 2010 LEFT ROCKER PANEL NEW FROM GM.jpg
ID:	234476   Click image for larger version
Name:	1972 TRANS AM     #184   4 APRIL 2010 1976  TA SPEEDO AT ALL 000000.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #65
Old 02-13-2011, 02:05 AM
72TAMAN's Avatar
April 2010
Picture #185 to #189 View of inside the Trans Am with the 76 stuff . 76 AC assy, 76 cab wiring harness , 76 speedometer,76 intermittent wipers, 76 power door locks,76 power windows ,76 power trunk,76 front console,76 aluninium dash panel etc.
Name:	1972 TRANS AM    #185  4 APRIL 2010 1976 DASH WITH AC.jpg
ID:	234481   Click image for larger version
Name:	1972 TRANS AM    #186 4 APRIL 2010 VIEW OF 1976 TA DASH IN MY 72.jpg
ID:	234482   Click image for larger version
Name:	1972 TRANS AM    #187  4 APRIL 2010 LEFT SIDE VIEW OF DASH.jpg
ID:	234483   Click image for larger version
Name:	1972 TRANS AM    #188   4 APRIL 2010 VIEW OF PEDALS AND NEW CARPET.jpg
ID:	234484   Click image for larger version
Name:	1972 TRANS AM     #189  4 APRIL 2010 DRIVER SEAT.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #66
Old 02-13-2011, 02:31 AM
72TAMAN's Avatar
April 2010
Picture #190 to #194 Photo of outside the Trans Am ,Picture #193 is a home made tow bar that I made in mid 80 because I was tired of paying tow truck to move the Trans Am also I done a wiring harness for towing the car. I installed the back lights in the car connect the harness to the rear lights of the Trans Am and to the truck that tows the car
Name:	1972 TRANS AM   #190   4 APRIL 2010  BACK LEFT SIDE VIEW.jpg
ID:	234489   Click image for larger version
Name:	1972 TRANS AM  #191 4 APRIL 2010 FRONT LEFT VIEW.jpg
ID:	234490   Click image for larger version
Name:	1972 TRANS AM  #192  4 APRIL 2010  FRONT SUB FRAME.jpg
ID:	234491   Click image for larger version
Name:	1972 TRANS AM   #193  4 APRIL 2010 HOME MADE TOWBAR.jpg
ID:	234492   Click image for larger version
Name:	1972 TRANS AM   #194  4 APRIL 2010 FRONT SUB FRAME RIGHT SIDE.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #67
Old 02-14-2011, 12:00 AM
72TAMAN's Avatar
April 2010
Picture #195 to #199
Picture #196 AC box assembly from the 76 Trans Am. Picture #197view of top of cowl with surface rust, steel part of dash was repainted and now it peeled off in chunks
Name:	1972 TRANS AM    #195  4 APRIL 2010 TOW BAR RIGHT SIDE VIEW.jpg
ID:	234643   Click image for larger version
Name:	1972 TRANS AM    #196  4 APRIL 2010 AC ASSEMBLY FROM 76 TA.jpg
ID:	234644   Click image for larger version
Name:	1972 TRANS AM    #197  4 APRIL 2010 LEFT SIDE COWL VIEW.jpg
ID:	234647   Click image for larger version
Name:	1972 TRANS AM   #198  4 APRIL 2010 PASSENGER SEAT.jpg
ID:	234648   Click image for larger version
Name:	1972 TRANS AM   #199   4 APRIL 2010 RIGHT DOOR JAM.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #68
Old 02-14-2011, 12:11 AM
72TAMAN's Avatar
April 2010
Picture #200 to#204
More picture of inside of Trans Am
Name:	1972 TRANS AM   #200  4 APRIL 2010 RIGHT SIDE DASH VIEW.jpg
ID:	234650   Click image for larger version
Name:	1972 TRANS AM    #201  4 APRIL 2010 REAR SEAT RIGHT VIEW.jpg
ID:	234651   Click image for larger version
Name:	1972 TRANS AM    #202  4 APRIL 2010 RIGHT SIDE VIEW INSIDE.jpg
ID:	234652   Click image for larger version
Name:	1972 TRANS AM    #203   4 APRIL 2010 GLOVE COMPART MENT.jpg
ID:	234653   Click image for larger version
Name:	1972 TRANS AM   #204   4 APRIL 2010  DASH AND STEEL PART OF DASH.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #69
Old 02-14-2011, 12:25 AM
72TAMAN's Avatar
April 2010
Picture # 205 to #209
Picture #205 and #206 View of headliner
Picture #207 to 209 outside view of Trans Am
Name:	1972 TRANS AM   #205   4 APRIL 2010 HEAD LINER VIEW.jpg
ID:	234655   Click image for larger version
Name:	1972 TRANS AM   #206   4 APRIL 2010  HEAD LINER AGAIN.jpg
ID:	234656   Click image for larger version
Name:	1972 TRANS AM   #207  4 APRIL 2010  RIGHT SIDE VIEW BACK.jpg
ID:	234657   Click image for larger version
Name:	1972 TRANS AM    #208  4 APRIL 2010  FRONT RIGHT SIDE VIEW.jpg
ID:	234658   Click image for larger version
Name:	1972 TRANS AM    #209 4 APRIL 2010  FRONT VIEW.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #70
Old 02-14-2011, 10:31 PM
72TAMAN's Avatar
April 2010
Picture #210 to #214
#210 At the time I had the Trans Am on the road I didn't like the sitting on the ground feeling so I remove the 2 front seats . bolted eight 3/8"x2" long nuts to the floor. On top of the 3/8"x2" long nuts I used a 3/8 washer and cover the nut/washer with a spray can cap,a black one that I made a 3/8 hole in it . bolted the 2 front seats on the of the nuts/washer/cap to raise the seats by 2" and what a difference in the feel of the Trans Am . I'm about 5'8" tall so to me it was the perfect setting ,head about 1" away from the headliner .
Picture #213,#214 remove the lock knobs and covered the holes with the little caps that are used to cover the screw on the kitchen or bathroom taps
Name:	1972 TRANS AM   #210  4 APRIL 2010 VIEW OF SEAT SPACER WITH COVER.jpg
ID:	234754   Click image for larger version
Name:	1972 TRANS AM    #211  4 APRIL 2010 VIEW OF WINDOW HANDLE COVERRIGHT DOOR.jpg
ID:	234755   Click image for larger version
Name:	1972 TRANS AM   #212  4 APRIL 2010 VIEW OF WINDOW HANDLE COVER.jpg
ID:	234756   Click image for larger version
Name:	1972 TRANS AM   #213   4 APRIL 2010  RIGHT SIDE DOOR LOCK ARM REMOVE.jpg
ID:	234757   Click image for larger version
Name:	1972 TRANS AM    #214   4 APRIL 2010  LEFT SIDE DOOR LOCK ARM REMOVE.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #71
Old 02-14-2011, 10:49 PM
72TAMAN's Avatar
April 2010
Picture#215 to #219
Pictures of the front of the Trans Am.
Picture #219 is how I take the Trans Am in and out of the garage
Name:	1972 TRANS AM    #215   4 APRIL 2010 VIEW FRONT TRANS TUNNEL.jpg
ID:	234768   Click image for larger version
Name:	1972 TRANS AM    #216   4 APRIL 2010 SUB FRAME TOP VIEW.jpg
ID:	234769   Click image for larger version
Name:	1972 TRANS AM   #217   4 APRIL 2010  WIPER MOTOR.jpg
ID:	234770   Click image for larger version
Name:	1972 TRANS AM    #218  4 APRIL 2010 FRONT VIEW 76 AC ASSEMBLY  BOX.jpg
ID:	234774   Click image for larger version
Name:	1972 TRANS AM #219   4 APRIL 2010  EASY  WAY TO MOVE TA IN AND OUT OF GARAGE LEFT SIDE VIEW.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #72
Old 02-15-2011, 12:16 AM
72TAMAN's Avatar
Summer of 2010
Ordered my PHS and received it in May Check it out and was really disappointed,because no mention of rims (honeycombs or rally's) also transmission option was not mention even do I knew it was a auto. Two weeks later received my window sticker and on that it said transmission was 4-speed close-ratio or a auto transmission and for the rims it said 15" rally II wheels w/trim rings. OK so I purchase a set of 4-15" rally II rims at a swap meet in Ottawa, rims code JJ for pretty cheap , the guy mention the rims came from a Catalina or something like that. I know it not the proper rims for that car but before I spend that much money for the wheel I'll get the Trans Am almost finish . Also on all the papers it said Trans Am shipped to Oshawa plant ,I was hoping to find out what dealership it was shipped to
Name:	21-10-2010 08;07;14PM.jpg
ID:	234779   Click image for larger version
ID:	234793   Click image for larger version
ID:	234794   Click image for larger version
Name:	PHS  STICKER.jpg
ID:	234802   Click image for larger version
Name:	1972 TRANS AM #579 11 DEC 2010   #1 RALLY II RIM       DATE CODE #            B 15X7 JJ 888 DO  .jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #73
Old 02-15-2011, 01:54 AM
72TAMAN's Avatar
June 2010
In mid July 2010 ordered the GM of Canada package and received it within 2 weeks . Gm of Canada has a lot more info (codes) then the one for PHS so if you're car was shipped to Canada it is worth the $60 cdn for it . THe first page as all info to get in touch with GM of Canada, phone # or fax # or email
When I received the GM package this one confirm that my Trans Am came with a 3 speed auto and that the rims are honeycombs ,like what the hell!!! So I call GM of Canada and talk to the person in charge and he recheck the info I received. He said all info is right because when the cars are shipped to Canada they redo the invoices so everything is in canadian dollars . I though of this for about a week and decided to email PHS to ask why the difference in paperwork, he also said that he send the proper info also . He also mention that in 72 the no charge option for the rims and trans and that PHS could not tell if those option were on or not ,so if PHS can't tell what was on the car why is it mention on the window sticker that unless specified the following items are standard on this model and it mention 15" rally II wheels w/trim rings. SO I have a window sticker that may be right or may be wrong but I pay for it . How could PHS sells info that may be right or may be wrong. I ask PHS to redo the window sticker so it said the car came with rally or honeycomb same as mention for the transmission auto or stick and his respond was the programming in the printing machine will not let them modify it but it able to mention the 2 transmission option so he send me aletter to explain it ,last pic
So with all of this I still don't know what wheels my Trans Am had new hoping that this resto somehow the billsheet will appear
Name:	14-02-2011 11;39;42PM.jpg
ID:	234817   Click image for larger version
Name:	GM OF  CANADA.jpg
ID:	234818   Click image for larger version
Name:	GM OF  CANADA  1.jpg
ID:	234819   Click image for larger version
Name:	21-10-2010 08;02;49PM.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #74
Old 02-15-2011, 03:40 AM
Originally Posted by 72TAMAN View Post
Summer of 2010
Check the bolt pattern on the ralley wheels, your car is a 4 1/2 on 5" . Those may be the bigger 5 on 5.
  #75
Old 02-15-2011, 03:41 AM
Love that the radio costs 2 times as much as the Ignition! Boy how things have changed!
  #76
Old 02-15-2011, 10:40 AM
x-bird2 x-bird2 is offline
based on the letters/info you've received, it looks as if it came with honeycombs, GM canada has the vin on the letter along with the PO5 option code listing them. Neat seeing the different wording used for some of the options between the US and Canada. It appears that the canadian cars were re-invoiced in a manner of speaking once they arrived at canada for distribution, perhaps some trade/customs regulation required that some of the no-cost options be more clearly specified.
  #77
Old 02-15-2011, 01:40 PM
His car should be 5on4.75... not 5on4.5.
As stated, the rallys you purchased could very well be 5on5 if they came from a Catalina. You may want to measure the pattern prior to restoring them.
  #78
Old 02-15-2011, 05:11 PM
Ugh I meant 4 and 3/4 , you are right!
  #79
Old 02-17-2011, 02:18 AM
72TAMAN's Avatar
Formulabruce and 71GP76TA
They fit ,I measured them and even tried them on the Trans Am tonight . The red ones (first picture) I bought at a swap meet in Ottawa for $20 for four rims w/caps (second picture) actually with 5 caps ,four stainless and one chrome . Picture 3 is a rims that I found at work last summer when we moved stuff in the backyard. It makes almost 16 years that I work there and never seen that rim there ,it was in a corner against the fence behind 4 skid of old loading dock bumpers and it matches the 4 red ones. Picture #4 damage to the front of the rim and Picture #5 damage almost all gone and rim almost all sandblasted , will used that rim for spare maybe . all 5 rims are 15x7 code JJ
Name:	1972 TRANS AM #573 22 MAY 2010 4 RALLY II RIMS BOUGHT 22 MAY 2010 AT RIDEAU CARLETON RACE TRACK .jpg
ID:	235039   Click image for larger version
Name:	1972 TRANS AM #569 22 MAY 2010 RALLY II RIMS CENTER CAPS BOUGHT  22 MAY 2010 AT RIDEAU CARLETON .jpg
ID:	235040   Click image for larger version
Name:	1972 TRANS AM   #611 22 MAY 2010  #5 RALLY II RIM FRONT VIEW.jpg
ID:	235041   Click image for larger version
Name:	1972 TRANS AM   #613 22 MAY 2010 #5 RALLY II RIM   FRONT VIEW DAMAGE TO RIM TO BE USED AS SPARE .jpg
ID:	235042   Click image for larger version
Name:	1972 TRANS AM #614 11 DEC 2010 #5 RALLY II RIM   SANDBLASTED FRONT VIEW.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
  #80
Old 02-17-2011, 02:58 AM
NICE! thats great no fit issues with those rims!
