Old 09-16-2011, 04:44 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Hi Tom,
I asked the fab shop about that, they claim there is plenty of room "~7 inches. I also asked them to take pictures from a few other angles.
  #62
Old 09-16-2011, 04:56 PM
T Syron's Avatar
T Syron T Syron is offline
Hi Tom,
I thought it might be a bad angle. Should be one hell of ride when its running.
Tom
  #63
Old 09-23-2011, 06:28 PM
RAIV-Z's Avatar
RA-V heads are done. Lynn can post the details on them when he gets a chance, no flow numbers yet. Bottom end is ready to be assembled. Headers will be done up to the collector V-band flange today.
ID:	257723   Click image for larger version
  #64
Old 10-03-2011, 08:19 AM
RAIV-Z's Avatar
Tom
Here's a better picture showing the clearance between the header and the head.
  #65
Old 10-03-2011, 09:52 AM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Default Example
Well, I cant wait to get this thing on the dyno. It is a street engine with street valve train and a street cam with multiport fuel injection. We will be able dyno a dual function. A street engine 535 FI normally aspirated, and then turbo charged.
This really gets me going! Casey won the Tbird dyno competition again! This is a street engine on a college kid budget. No money from dad.
http://www.youtube.com/watch?v=XekfzcgDe7s
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
  #66
Old 10-06-2011, 05:49 PM
RAIV-Z's Avatar
Engine assembly has begun!
ID:	259274   Click image for larger version
Name:	short block.jpg
ID:	259275   Click image for larger version
ID:	259276   Click image for larger version
Name:	FI intake.jpg
  #67
Old 11-01-2011, 06:51 PM
RAIV-Z's Avatar
Default McCarty RA-V Heads Ready for Assembly "almost"
Turbo Header should be complete this week.
Are any of you guys running a belt driven fuel pump with a rear mounted cell?
ID:	261861   Click image for larger version
ID:	261862   Click image for larger version
ID:	261863   Click image for larger version
  #68
Old 11-01-2011, 07:40 PM
Silver Judge's Avatar
All of those RAV go-fast shiny parts look GREAT !
With twin turbos, this thing is gonna be a wicked, wicked beast
What kind of vehicle is this going to be going in ?
501 HP, 554 ft lbs TQ
  #69
Old 11-01-2011, 10:35 PM
RAIV-Z's Avatar
Thanks Silver Judge, it will be installed in this 69 Firebird.
Are you guys in the northwest finished drag racing this year too, New England Dragway closed last week?
  #70
Old 11-01-2011, 11:03 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Beutiul car. That motor is going to be a beast. I don't know about the west side of the Cascades, but on the east we are done racing for the year.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
  #71
Old 11-02-2011, 12:04 PM
Thanks to Ed Page for his support on this project. It has taken a bit longer than projected as Tony was inundated with engine projects. We also have had a few set backs. It takes a lot of time to do things for the first time. For example, we had to write the valve placement program for alternate valve order, design CNC porting program, order RAV cam design for turbo engines, build special headers for the 69 Firebird. A big time investment has been the special RAV fuel injection.
This is a street engine with street valve train. It is designed to make 2200HP of a base engine that produces 751HP normally aspirated I fully expect to make way more horsepower base which should translate into an easier target with boost and a better number with pump gas. If we make the engine very efficient, then the higher numbers with pump gas can be achieved.
Attached is the design criteria from Dave Austin at Turbonetics.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #72
Old 11-02-2011, 12:22 PM
cgeise's Avatar
cgeise cgeise is offline
Dave -- looking at the sheet it would seem that 34 psi is in the boom boom range. I also read the psi ratio as becoming and issue -- over 2.5 at 25 lb of boost seems high --and could contribute to some problems -- only after we went to a larger turbine wheel and housing did the backpressure get fixed -- dont pay for it twice - look into this issue
  #73
Old 11-02-2011, 12:43 PM
Dave,
We dont expect 751HP normally aspirated, and we dont expect to do 34 PSI. We are just being conservative on our design. I am hoping to achieve 2200HP with a much lower boost number. My goal is 25-PSI. Of course the biggest goal is how much HP we can get with pump gas.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #74
Old 11-02-2011, 12:45 PM
andrewT's Avatar
andrewT andrewT is offline
This is going to be such a badass car when its done!!
The Educated Fool
  #75
Old 11-02-2011, 07:57 PM
That's a TASTY, TASTY looking 69 Bird, I love it!
So, I guess you're OK having a street car that only runs high 6's or low 7's in the quarter mile? LOL
Yeah, we're done with racing for the season (unless we tow to places like SoCal or Arizona)
  #76
Old 11-02-2011, 10:37 PM
RAIV-Z's Avatar
It better easily run in the 7's "6's once I learn how to drive it" or someone is going to get their butt kicked
Anything interesting going on in Seattle next week?
  #77
Old 11-03-2011, 11:38 AM
Well Stacys car is knocking on the 8's door with 700ish HP (9.11 is his best time.) This engine in Stacys car will run 7s if you leave the turbos off and install a Q-jet. It takes a lot of experience. With this kind of car it is necessary to be safe and do it conservatively.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #78
Old 11-03-2011, 11:51 AM
slowbird's Avatar
slowbird slowbird is offline
Did I miss it, what do the heads flow?
  #79
Old 11-03-2011, 01:30 PM
RAIV-Z's Avatar
Lynn or I will post the flow numbers once we have them from BES.
  #80
Old 11-11-2011, 01:21 PM
We are about 400 cfm with the emphasis on BIG. We believe that cross sectional area is what a turbo engine is going to want. Especially for these two 88MM Turbonetics!! The exhausts are around 260. We didnt spend huge bucks like racers do porting the heads. These are just CNC for about $2500 and similar to the street heads done. Tony charges three times that for a good set of race heads, ie Super Stock, and over $12k for our Pro Stock style heads.(Similar to Langer's)
We moved the intake valve over 0.050, but then it put us back to the same spot as stock by using the 2.300 intake valve. The bore 4.35 gives us about 0.100 clearance between the intake valve and the cylinder wall. However, we dont have intake port choke to deal with on the size of these ports. We would need Tom V to tell us the virtues of CSA of the intake port to see if it impacts a Turbo motor like this as much as a NA engine.
Tom Vaught has been so very instrumental in helping us with this Turbo project. We cannot thank him enough for putting us together with Turbonetics and helping us along of the way.
Here is an article Casey read that he thought might be similar"
http://www.chevyhiperformance.com/te...k/viewall.html
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
