Old 03-11-2013, 08:06 AM
2002Z4CSS's Avatar
Originally Posted by GETRIDAONE View Post
"the Lakewood cars often had them behind the lh door panel"
Lakewood plant was on the south side of Atlanta.
Thats where my GT-37 was built.
I removed the drivers door trim panel yesterday and sure enough...there was a build sheet found behind it.
1971 Pontiac GT-37
  #62
Old 03-14-2013, 02:34 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Im conflicted right now with my t-37. It is an original 350-2/2pd/open 2.78 car. it appears to be 90% original, and is in pretty good condition all things considered. Ive been thinking about taking all the original drivetrain out and setting in storage and updating the car with a 71 abody 455 -325 d port motor and correct 71 th-400 and install my 12 bolt with 3.73 gear. I cant quite make up my mind on what to do. Its not anything special, and it sure would be cooler and fun to drive with a # correct 455/th-400 combo vs the 350-2spd, but in light of the documentation ive found on the car, and the fact that the car is remarkably intact for a car of no real significance, im having a hard time pulling the trigger. most the cars ive ever owned were picked apart before i ever got them, so substituting better performance parts was never an issue, but im having trouble doing it to the T-37. I suppose i could always swap the original stuff back in easy enough. Something about hopping in the car with the 350-2 and 2.78 and being able to cruise anywhere i want is appealing. Ive always wanted to get in an old pontiac and roadtrip across the country. Much harder to do with a 455 and a 3.73 gear. Ive actually already got the 12 bolt installed, but the next step is changing the transmission and ive stalled.
  #63
sweet!
  #64
Old 03-14-2013, 02:39 PM
Old 03-14-2013, 02:46 PM
Judge273's Avatar
Judge273 Judge273 is offline
What's wrong with a 455D/12 bolt x-country trip? I heard that is a sweet setup for all conditions??
Mike/Illinois
  #66
Old 03-14-2013, 03:34 PM
nothing wrong with that. I might proceed with it and see how it works out. Nothing says i can put it back. besides, theres something about a 455 with poverty caps I might just buy a 3.08 or 3.42 gear for the 12 bolt and give it a shot. the extra torque of the 455 and the gear of the first and 2nd gear of the th-400, no sense in have the 3.73 in there anyway. It wont be a track car, thats what my beat up old LeMans is for
  #67
Old 03-21-2013, 03:26 PM
Old 03-21-2013, 03:33 PM
The bummer is, I took the car out for drive with the new rear end. The new rear was a used 12 bolt out of my 72 LeMans, which worked just fine before. As soon as I put it in the t-37, it has a loud howl. Not sure what my next step will be, most likely will pull the 12 bolt out and put the 10 bolt back in.
  #69
Old 03-21-2013, 03:51 PM
Eric71T37's Avatar
Eric71T37 Eric71T37 is offline
I say swap the drivetrain you want in, and store the original stuff. Your car looks great with the steelies BTW.
I have a 455-D with TH-400 and a 3.31 12-bolt in my '71 T-37. You might find the 3.73 gear to be a bit much on an extended highway trip.
_______________________________________
1971 T-37 Laurentian Green/Sandalwood buckets
455/1971 #96 heads/TH400/3.31 12-bolt posi/4-wheel discs
  #70
Old 03-21-2013, 04:03 PM
2002Z4CSS's Avatar
That car is just wanting to do a big smokey burnout!
1971 Pontiac GT-37
  #71
Old 03-21-2013, 04:30 PM
I would like to, but it wont. Haha
  #72
Old 03-21-2013, 07:44 PM
Eric71T37's Avatar
Adam, could you possibly post a picture of the nuts that are holding your trunk lid emblems on? Thanks!
  #73
Old 03-21-2013, 07:46 PM
Yes sir I sure will
  #74
Old 03-21-2013, 08:34 PM
Eric71T37's Avatar
Thanks. I've had mine off so long I can't remember what they look like. I think they are domed nuts (?)
  #75
Old 03-21-2013, 10:03 PM
YNOBIL's Avatar
YNOBIL YNOBIL is offline
Here's a shot of the underside of my '72 GTO Survivor trunk lid. As you can see they are the domed nuts
ID:	317045   Click image for larger version
Name:	72 GTO Trunk Lid Close Up.jpg
Bill Nawrot (Wino Bill)
1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019
Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot
HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/
YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU
1967 GTO Conv
  #76
Old 03-22-2013, 02:00 AM
Eric71T37's Avatar
Thanks, Bill!
Adam, do the same domed nuts hold on the T-37 emblem on the deck lid?
  #77
Old 03-22-2013, 07:15 AM
Keith Seymore's Avatar
I believe this car is improperly parked.
If the condition persists it will need to be towed.
K
'63 LeMans Convertible
'63 Grand Prix
  #78
Old 03-22-2013, 12:00 PM
2002Z4CSS's Avatar
K
Yep, illegally parked.
1971 Pontiac GT-37
  #79
Old 03-22-2013, 03:13 PM
Thanks, Bill!
The T-37 appears to be an adhesive backed emblem. Mine has the domed nuts for the Pontiac as well, but nothing coming through on the t-37
  #80
Old 03-22-2013, 03:45 PM
K
Hahaha very true. I haven't found my T-37 parking only sign yet.
