Old 10-08-2013, 11:35 AM
MOJO Catalina's Avatar
MOJO Catalina MOJO Catalina is offline
Send a message via AIM to MOJO Catalina
Default Out she comes!
Pulled the engine and will remove the oil pan to see why she won't spin freely.
Sometimes towed but never trailered!
  #62
Old 10-20-2014, 01:59 PM
Couldn't get the original engine to free up so I got ahold of one from a '62 Bonneville..
Better 4 speed automatic too.. Hope to be rolling in this car soon.
It ain't pretty just yet but it will be stopping and going soon..
https://www.youtube.com/watch?v=8odAtSxBroE
  #63
Old 10-20-2014, 04:04 PM
Stuart's Avatar
Stuart Stuart is offline
The transmission tunnel on a Catalina is smaller than the tunnel on a Bonneville, so you may have to do a little sledgehammer therapy on it to get the four speed automatic to fit. I believe the rear crossmember mount for the transmission is different, I'm not sure if the driveshaft length will change or not.
  #64
Old 10-20-2014, 04:38 PM
I did this swap in a '63 GP a few years ago.. Same length trans, same mounts, same driveshaft, different yolk.. Just a small area where the tailshaft bolts on touching and pushing up on the floor a bit right now.. I'll probably cut a smile in the floor there, jack up the tail shaft 3/4 of an inch too much, then drop it back down and weld a small piece in.. Otherwise fine though..
