Old 01-12-2014, 04:15 PM
gavin gavin is offline
ozzieville I have been looking at your posts for a while and like your car. I see you are a rigger do you work on the energy projects as I do? North the 63 is a 42000 ml car in very good order. I have a 400 in it at the moment as the 336 has 10.25 cr and does not like our gas. I will put some more pics up as I have just learned how to do it. North your a GM man do you know what the red two door is in the end pic?
ID:	349085   Click image for larger version
ID:	349086   Click image for larger version
ID:	349087   Click image for larger version
ID:	349089   Click image for larger version
  #62
Old 01-12-2014, 09:43 PM
MCronkGTO MCronkGTO is offline
John - As I mentioned over in the Lemans/GTO tech section we have similar tastes. I have posted up some pics of my 67 GP. I had a 69 Bonneville Brougham 428 HO car I parted out many years ago. If I remember correctly the body side moulding had lights on each end. The car was Verdo green and loaded with options.
Incommunicado - I was in the same class as you at the POCI show this summer. I also drove the GP out to the drags that day.
MarkC
Name:	GP large.jpg
ID:	349139   Click image for larger version
ID:	349141   Click image for larger version
ID:	349142   Click image for larger version
ID:	349143   Click image for larger version
The Following User Says Thank You to MCronkGTO For This Useful Post:
  #63
Old 01-21-2014, 10:13 PM
Griffinspc's Avatar
Griffinspc Griffinspc is offline
So much work and so much pleasure.
Does it get any better than cruising? No!
The Following User Says Thank You to Griffinspc For This Useful Post:
  #64
Old 01-21-2014, 11:31 PM
I think it's a Holden Monaro 69-70ish, the GTS version? There was an article on them in CA a few years ago.
Old 01-21-2014, 11:45 PM
MarkC
You are correct, in 69 the moldings are capped at each end by the side marker lights. Those moldings are the weakspot of the exterior of the car, I never liked body side moldings as they break up the lines but in 69 they were standard equipment, if you remove them then the problem is that your side marker lights look weird because they were designed to be connected to the moldings.
The only exception to the side moldings being standard was the canadian 2+2 model, it had specific side marker bezels, good luck finding a set of non pitted ones from the great salty white north.
Old 01-22-2014, 06:56 AM
You are so right north but im not sure of the year myself. When I was a young man in New Zealand you would buy one because you could not afford a camaro . Now good ones start at $50,000 and go up from there.
  #67
Old 01-22-2014, 09:34 AM
blubomber's Avatar
blubomber blubomber is offline
Default New Zealand
Ahh, New Zealand. Land of my dreams. One day I'll get there ..........with my Bonneville no less. Drive cross country. Wrap it in plastic and put it on a slow boat to Auckland. I'll be the only one in the country with a '69 convertible with 52 options.
  #68
Old 01-22-2014, 12:23 PM
incommunicado incommunicado is offline
Default 67 GP 428 4 speed
Originally Posted by incommunicado View Post
Here is my recent project. It is now at the body shop for a frame off. Once done, it will be triple black, and loaded with every option available at the time. A correct code 428 has been rebuilt to HO specs along with a .068 cam. The seats and door panels are done, a rally gauge dash was sourced and is rebuilt along with the proper harness and a room full of NOS, new and used parts are waiting. Got to get the body and frame done this summer and begin the assembly. I hate this stage because one doesn't see much progress being made, just a big mess.
Thanks to many on this forum for help and with parts. There will be a lot of stuff left over if anyone needs anything.
Here is the car at the blast shop in December, 2012. Sorry for the poor picture quality but all I had at the time.
She will get some blasting (not all) and then back to the shop and off the frame. It will be a push, but I hope to have it back on the frame by fall.
Name:	GP blast shop 1, 12-2013.jpg
ID:	350405   Click image for larger version
Name:	GP blast shop 2, 12-2013.jpg
ID:	350406   Click image for larger version
Name:	GP blast shop 3, 12-2013.jpg
  #69
Old 01-23-2014, 08:36 AM
Blubomber if you go across country it wont take long you have to go down country. If you do it time it for the easter beach hop you will like that.
  #70
Old 02-02-2014, 02:22 PM
sidetrack sidetrack is offline
Default My wifes car
Here is a couple pictures of my wifes 1968 Bonneville convertible.
ID:	351603   Click image for larger version
  #71
Old 08-30-2014, 04:35 PM
64gp4spd 64gp4spd is offline
Default My 73 Grandville 12 Second Sleeper
My 73 Grandville 462 Turbo 400 and 3.42 Posi
  #72
Old 08-30-2014, 05:58 PM
I added a couple of shots of my 71 Catalina Freeway Enforcer, 37,000 miles, 455 4bbl, T-400, 3.23 open rear gears. I hope to have it back on the road this week, need to get the gas tank back in it, blow out the fuel lines, and replace all the flex lines.
Name:	71 Cat Lt Front.jpg
ID:	374801   Click image for larger version
Name:	71 enforcer Barrier.jpg
ID:	374802   Click image for larger version
Name:	71 Interior Front.jpg
  #73
Old 08-31-2014, 09:56 PM
Picked this up a couple of months ago.
  #74
Old 09-09-2014, 12:53 AM
68Catalina68 68Catalina68 is offline
So, I finally dusted off the Cat and drove her out to the cruise. Looking at the registration, I guess it hasn't been on the road since 07. Wow does time fly.
100MEDIA$IMAG0785 by chevellecarcass, on Flickr
  #75
Old 09-26-2014, 11:18 PM
Alvin's Avatar
Alvin Alvin is offline
Cool car. IIRC that was a WA or OR CL ad, someone was selling for elderly person or was precious owner, yes?
  #76
Old 09-26-2014, 11:30 PM
Alvin's Avatar
Ran across this sweet 1969 Ventura picture & wanted to share it. I know nothing about it other than I like it!
  #77
Old 09-29-2014, 12:41 AM
Car was on Portland craigslist and listed on this site as well. I purchased the car from a guy that bought the car from the guy that bought it from the elderly owner.
  #78
Old 09-29-2014, 05:53 AM
GpFreak's Avatar
GpFreak GpFreak is offline
Post
I have a nice front fender extension/headlamp bucket for it if you need one.
Steve Naresky
  #79
Old 09-29-2014, 12:49 PM
Thanks... There's a good one in the trunk waiting to be installed.
  #80
Old 10-03-2014, 10:33 AM
2+2+3x2's Avatar
2+2+3x2 2+2+3x2 is offline
Default '67 GP 428HO 4 speed
I posted some of these in another thread a while back but not here so here goes.
ID:	377858   Click image for larger version
ID:	377859   Click image for larger version
ID:	377860   Click image for larger version
ID:	377861   Click image for larger version
1967 Grand Prix convertible, 428HO 4 speed
